VBA rename file when cell of another workbook is updated
I have a file "cargoes 2016" as a database where the datas are sorted per "REF"(column "C"), I would like that when the cell of the colum "AI" is updated for a specific "REF", it goes to a specific folder and rename automatically the file whose name include "ref". However being totally new in vba, I don't know how to refer to the good cells/column.
Basically, if I update the cell of the column "AI" (=date) in the row of ref "2016xx001", the file in the specific folder who includes in its name "2016xx001" is automatically renamed (without opening)
what I did until now is create a module with the action "rename file" and insert code under the worksheet that if cell ai is updated, "rename file" macro runs
Here below both codes
Sub RENAME_FILES()
Dim LR As Long, i As Long, Filename As String, OldName As String, NewName As String, DIRECTORY As String, REF As String
LR = Workbooks("CARGOES 2016").Worksheets("RECAP").Cells.Find("*", searchorder:=xlByRows, searchdirection:=xlPrevious).Row
On Error Resume Next
For i = 2 To LR
DIRECTORY = "C:\Users\mciavaldini.TAMOILCY\Documents\test\"
REF = Workbooks("CARGOES 2016").Worksheets("RECAP").Range("C" & i).Value
OldName = "CALC(P) - " & REF & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("L" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("M" & i).Value & " + " & "CALC(S) - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("W" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("X" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("F" & i).Value & ".xlsm"
NewName = "CALC(P) - " & REF & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("L" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("M" & i).Value & " + " & "CALC(S) - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("W" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("X" & i).Value & " - " & Workbooks("CARGOES 2016").Worksheets("RECAP").Range("F" & i).Value & Format(Workbooks("CARGOES 2016").Worksheets("RECAP").Range("AI" & i).Value, "dd-mmm-yy") & ".xlsm"
Filename = Dir(DIRECTORY & "*" & REF & "*" & ".xlsm")
If Filename <> "" Then
Name DIRECTORY & OldName As DIRECTORY & NewName
On Error GoTo 0
End SubPrivate Sub Worksheet_Change(ByVal Target As Range)
For i = 2 To LR
If Not Intersect(Range("AI" & i), Target) Is Nothing And Range("AI" & i) <> "" Then
RENAME_FILES
On Error GoTo 0
End SubcodePlease note that my table has around 100 rows, each "ref" being "2016xx001", 2016xx002, 2016xx003 etc
so if I update the column AI of the ref 2016XX003, then my code goes to find the file which includes "2016xx003" in its title, and rename it adding at the end of the name the column Ai value....
I know my problem is how to refer to the good cell....can someone help?
Hello and welcome
To test
If not it must be the main file and the macros and 2-3 to rename files
Sub RENAME_FILES(Ligne As Long)
Dim LR As Long, Filename As String, OldName As String, NewName As String, DIRECTORY As String, REF As String
With Workbooks("CARGOES 2016").Worksheets("RECAP")
LR = .Cells.Find("*", searchorder:=xlByRows, searchdirection:=xlPrevious).Row
REF = .Range("C" & Ligne).Value
OldName = "CALC(P) - " & REF & " - " & .Range("L" & Ligne).Value & " - " & .Range("M" & Ligne).Value & " + " & "CALC(S) - " & .Range("W" & Ligne).Value & " - " & .Range("X" & Ligne).Value & " - " & .Range("F" & Ligne).Value & "*.xlsm"
Filename = Dir(DIRECTORY & OldName)
NewName = "CALC(P) - " & REF & " - " & .Range("L" & Ligne).Value & " - " & .Range("M" & Ligne).Value & " + " & "CALC(S) - " & .Range("W" & Ligne).Value & " - " & .Range("X" & Ligne).Value & " - " & .Range("F" & Ligne).Value & Format(.Range("AI" & Ligne).Value, "dd-mmm-yy") & ".xlsm"
Name DIRECTORY & Filename As DIRECTORY & NewName
On Error GoTo 0
If Not Intersect(Columns("AI"), Target) Is Nothing Then
If Not IsDate(Target) Then Exit Sub
RENAME_FILES Target.Row
End Subit works perfectly, thank you so much
Just I replaced "ligne" by "row" so now the code is
Sub RENAME_FILES(row As Long)
DIRECTORY = "\\192.168.2.6\elenalouroutziati_document\B R E A K D O W N S\BREAKDOWNS 2016\"
With ThisWorkbook.Sheets("RECAP")
LR = .Cells.Find("*", searchorder:=xlByRows, searchdirection:=xlPrevious).row
REF = .Range("C" & row).Value
OldName = "CALC(P) - " & REF & " - " & .Range("L" & row).Value & " - " & .Range("M" & row).Value & " + " & "CALC(S) - " & .Range("W" & row).Value & " - " & .Range("X" & row).Value & " - " & .Range("F" & row).Value & ".xlsm"
NewName = "CALC(P) - " & REF & " - " & .Range("L" & row).Value & " - " & .Range("M" & row).Value & " + " & "CALC(S) - " & .Range("W" & row).Value & " - " & .Range("X" & row).Value & " - " & .Range("F" & row).Value & " - " & Format(.Range("AI" & row).Value, "dd-mm-yy") & ".xlsm"
On Error GoTo 0
RENAME_FILES Target.row
End SubHello
Avoid using "row" because it is a reserved word by VBA
uses LRow
Sub RENAME_FILES(LRow As Long)
LR = .Cells.Find("*", searchorder:=xlByLRows, searchdirection:=xlPrevious).LRow
REF = .Range("C" & LRow).Value
OldName = "CALC(P) - " & REF & " - " & .Range("L" & LRow).Value & " - " & .Range("M" & LRow).Value & " + " & "CALC(S) - " & .Range("W" & LRow).Value & " - " & .Range("X" & LRow).Value & " - " & .Range("F" & LRow).Value & ".xlsm"
NewName = "CALC(P) - " & REF & " - " & .Range("L" & LRow).Value & " - " & .Range("M" & LRow).Value & " + " & "CALC(S) - " & .Range("W" & LRow).Value & " - " & .Range("X" & LRow).Value & " - " & .Range("F" & LRow).Value & " - " & Format(.Range("AI" & LRow).Value, "dd-mm-yy") & ".xlsm"
On Error GoTo 0
