Suppression de ligne quand il y a un texte
J'aimerais comment faire pour que dans mon code VBA, que celui-ci détecte les mots "Heure" et "Locale" pour par la suite supprimer les lignes en question.
Merci par avance de votre aide.
Sub tt()
    a = Feuil1.UsedRange.Rows.Count
    With Feuil1
        For i = a To 2 Step -1
            If .Cells(i, 2) = "Heure" Or .Cells(i, 2) = "locale" Then Rows(i).Delete
Une autre proposition.
Public Sub CleanData()
Dim ws As Worksheet, lastRow As Long, rw As Long
    Application .ScreenUpdating = False
    Set ws = ActiveSheet
    With ws
        lastRow = .Cells(Rows.Count, 1).End(xlUp).Row
        For rw = lastRow To 2 Step -1
            If UCase(.Cells(rw, 2)) = "HEURE" Or UCase(.Cells(rw, 2)) = "LOCALE" Then
                .Rows(rw).Delete
        Next rw
        'lastRow = .Cells(Rows.Count, 1).End(xlUp).Row
        '.Range(.Cells(2, 2), .Cells(lastRow, 2)).Replace " h", vbNullString
        '.Range(.Cells(2, 3), .Cells(lastRow, 3)).Replace " °C", vbNullString
    Set ws = Nothing
J'ai une erreur dans le code.
Ou est mon erreur ?
Sub Macro1()
' Macro1 Macro
  Cells.Clear
'  Range("B2").Select
'  ActiveCell.FormulaR1C1 = ""
'  Range("B3").Select
  For j = 0 To 1
    For i = 1 To 31
      ligne = Range("B" & Rows.Count).End(xlUp).Row + 1
      Range("A" & ligne) = DateSerial(2014, j + 1, i)
      With ActiveSheet.QueryTables.Add(Connection:= _
                                       "URL;http://www.meteociel.fr/temps-reel/obs_villes.php?code2=7005&jour2=" & i & "&mois2=" & j & "&annee2=2014" _
                                       , Destination:=Range("B" & Rows.Count).End(xlUp).Offset(1, 0))
        .Name = "obs_villes.php?code2=7005&jour2=3&mois2=3&annee2=2015"
        .FieldNames = True
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .WebSelectionType = xlSpecifiedTables
        .WebFormatting = xlWebFormattingNone
        .WebTables = "10"
        .WebPreFormattedTextToColumns = True
        .WebConsecutiveDelimitersAsOne = True
        .WebSingleBlockTextImport = False
        .WebDisableDateRecognition = False
        .WebDisableRedirections = False
        .Refresh BackgroundQuery:=False
      Range("A" & ligne).AutoFill Destination:=Range("A" & ligne & ":A" & Range("B" & Rows.Count).End(xlUp).Row), Type:=xlFillCopy
    With ws
                .Rows(rw).Delete
        Next rw
    Set ws = Nothing
  Columns("C:E").Delete
  Columns("D:J").Delete
'  Columns("C:E").Select
'  Selection.Delete Shift:=xlToLeft
'  Columns("D:J").Select
Un espace s'est crée sur la ligne :
Modifie en conséquence :
J'ai toujours une erreur :/
RE,
A qui t'adresses-tu?
Quelle ligne comporte une erreur (ligne surlignée)?
L'erreur est dans le lancement du code.
Ci-joint l'erreur.
2015 11 19 16 33 36
Commence par ajouter End Sub, avant Public Sub CleanData().
Cela me créer deux maccros,, j'aimerais tout dans la même maccro, cela n'est pas possible ?
Bon pas grâve, j'ai appel cette macro thx
Rechercher des sujets similaires à "suppression ligne quand texte"
