Ajouter une checkbox à un formulaire
Dans un Userform j'ai toute une série de CheckBox. Je voudrais en rajouter une, dont l'information devrai se retrouver dans une nouvelle colonne créé entre la colonne "I" et la colonne "K" de ma feuille actuelle.
Ajouter la case à cocher je sais faire. Par contre comment modifier mon code:
Public Derlig As Integer
Private CTRL As control
Private L&, I&
Private Sub ComboBox1_Change()
    Dim J&, k&
    On Error Resume Next
    If Flag Then Exit Sub
    With Feuil1
        k = Application.Match(ComboBox1, .Columns(1), 0)
        On Error GoTo 0
        If k <> 0 Then
            L = ComboBox1.ListIndex + 12
            For I = 1 To 26
                Controls("CheckBox" & I) = IIf(.Cells(L, I + 4) = "", 0, 1)
                Controls("CheckBox" & I).BackColor = IIf(Controls("CheckBox" & I), vbGreen, vbWhite)
            TextBox1 = .Cells(L, 4)
    Me.Height = 600
    Me.Width = 700
    Me.Top = Application.Height / 2 - Me.Height / 2
    Me.Left = Application.Width / 2 - Me.Width / 2
    Enregist.SetFocus
    Unload Me
Private Sub CommandButton3_Click()
    PERMIS_ET_FORMATIONS.PrintForm
Public Sub Enregist_Click()
    With Feuil1
        For I = 1 To 26
            If k <> 0 Then
                .Cells(L, I + 4) = IIf(Controls("CheckBox" & I) = 0, "", "ü")
                .Cells(Derlig, I + 4) = IIf(Controls("CheckBox" & I) = 0, "", "ü")
        .Cells(L, 4) = TextBox1.Value
    Unload Me
    PERMIS_ET_FORMATIONS.Show 0
Private Sub Nouv_valid_Click()
    Unload Me
    Nouveau.Show 0
    With Feuil1
        lig = .Range("A" & Rows.Count).End(xlUp).Row
        If lig < 12 Then Exit Sub
        If lig = 12 Then ComboBox1.AddItem .Range("A12") Else ComboBox1.List = .Range("A12:A" & lig).Value
Private Sub CommandButton4_Click()
    Dim I As Byte
    With Me.ComboBox1
        If .Value <> "" Then
            If MsgBox("Attention, vous allez débarquer " & .List(.ListIndex) & vbLf & _
                      "Confirmez-vous ce débarquement?", vbYesNoCancel) = vbYes Then
                Sheets("LUTIN").Cells(.ListIndex + 12, 1).Resize(1, 27).ClearContents
                Flag = True: .RemoveItem (.ListIndex)
        If Flag Then
            Call Tri_Base
            Me.ComboBox1 = "": Me.ComboBox1 = ""
            For I = 1 To 26
                Me.Controls("CheckBox" & I) = 0
                Me.Controls("CheckBox" & I).BackColor = vbWhite
            Next I
    Flag = False
    Unload Me
Merci par avance
, comme on ne sait pas où sont les autres
il y a déjà la colonne J
Il faut ton fichier, tu y indiques ce que tu as et ce que tu veux
Bonjour Banzaï64,
Milles excuses de mettre mal exprimé.
Le case à coché se trouvent sur le formulaire "PERMIS ET FORMATION"
Pour y acceder cliquez sur "FORMULAIRE"
Identifiant: Administrateur
MP:0000
La ou les case à cocher à rajoutés se trouverons dans permis
donc les colonnes seront sur la feuille "LUTIN" à la suite de la colonne "I" (la colonne "J" à déjà été rajoutée).
Mon fichier:
https://www.cjoint.com/c/EHskcZrJSYi
Merci par avance.
Je n'arrive pas à comprendre quel est le problème
Pour moi le programme fonctionne bien
Il faut que tu indiques ce que tu fais pour arriver au problème
Il n'y a aucuns problèmes, je voudrai juste rajouter une case à cocher dans la section permis.
Mais je ne sais pas comment modifier le code
Dans la section permis tu as bien une case à cocher qui ne sert à rien car elle est invisible
Dans l'éditeur VBA tu affiches l'userform "PERMIS_ET_FORMATIONS"
Tu cliques 1 fois sur la checkbox6
Dans les propriétés tu modifies la valeur de la propriété Visible: De False tu passes à True
Dans la feuille Excel tu affiches la colonne I
C'est tout
A tester
Ok jusque la pas de soucis, mais je voudrais en rajouter encore une voir deux et dans ces cas la je pense qu'il faut modifier le code afin que les infos rentrés dans l'Userform se retrouvent à la bonne place dans la feuille et que les informations soient également transmissent aux feuille "SYNTHESE" et "IMPRESSION"
Dans cette version je t'ai ajouté 6 checkbox
Ce qui sont en trop tu peux les rendre invisible et masquer la colonne correspondante
Pour ajouter (ou enlever) le plus simple (bien sur si tu as 200 contrôles à gérer cela sera moins pratique) c'est de renuméroter les contrôles
C'est ce que j'ai fait dans ce programme
Ensuite j'ai modifier les boucles de 1 To 26 ---> 1 To 32
Je t'ai modifié le tri pour qu'il prenne en compte les colonnes ajoutées
Bonjour Banzai64 ,
Un grand merci je regarde dès cette après midi à mon retour à la maison.
Bonjour Banzaï64,
Super tout fonctionne comme je le voulais.
Un grand merci à toi.
Rechercher des sujets similaires à "ajouter checkbox formulaire"
