Explication d'une macro
Voilà une personne m'a faite une macro malheureusement je ne comprend pas tout de celle-ci
Elle fonctionne parfaitement mais ça m'embête de l'utiliser sans comprendre de façon général ce que tout ce charabia veut dire.
Private Sub ImpExp_Click()
Dim LastLig As Long, TheLig As Long
Dim Tmp As String
Tmp = Range("REF")
If Tmp <> "" Then
    With Feuil2
        LastLig = .Cells(.Rows.Count, 1).End(xlUp).Row
        TheLig = TheRow(Tmp, .Range("A4:A" & LastLig))
        If TheLig > LastLig Then .Range("A" & TheLig).Resize(, 177).Borders.LineStyle = xlContinuous
        Export Tmp, .Range("A4:A" & LastLig), .Range("B:HP"), Range("DESC")
        Export Tmp, .Range("A4:A" & LastLig), .Range("I:DP"), Range("CAUS")
        Export Tmp, .Range("A4:A" & LastLig), .Range("DQ:ER"), Range("VERIF")
        Export Tmp, .Range("A4:A" & LastLig), .Range("ES:FT"), Range("ACT")
    Range("REF") = ""
    Range("DTE") = ""
Dim Tmp As String
If Target(1, 1).Address = Range("REF")(1, 1).Address Then
    Tmp = Target(1, 1)
    Range("REF") = UCase(Tmp)
    ClearForm
    With Feuil2
            Target.Font.Color = 255
            With ActiveSheet.OLEObjects("ImpExp").Object
                .Caption = "Enregistrer nouvelle référence"
                .ForeColor = 255
            Target.Font.Color = 0
                .Caption = "Modifier référence"
                .ForeColor = vbBlue
            Import Tmp, .Range("A:A"), .Range("B:H"), Range("DESC")
            Import Tmp, .Range("A:A"), .Range("I:DP"), Range("CAUS")
            Import Tmp, .Range("A:A"), .Range("DQ:ER"), Range("VERIF")
            Import Tmp, .Range("A:A"), .Range("ES:FT"), Range("ACT")
Private Function TheRef(ByVal What As String, ByVal Where As Range) As Range
If What <> "" Then Set TheRef = Where.Find(What, LookIn:=xlValues, lookat:=xlWhole)
End Function
Private Function CLookUp(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Num As Integer)
Dim c As Range
Set c = TheRef(What, Where)
If Not c Is Nothing Then
    CLookUp = Intersect(c.EntireRow, From(, Num).EntireColumn)
    Set c = Nothing
End Function
Private Function TheRow(ByVal What As String, ByVal Where As Range) As Long
Dim c As Range
    TheRow = c.Row
    Set c = Nothing
    TheRow = Where.Offset(Where.Rows.Count).Row
End Function
Private Sub Import(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Inside As Range)
Dim i As Integer
Dim c As Range
Dim j As Long
    For Each c In Inside
        If c.MergeArea(1, 1).Address = c.Address Then
            i = i + 1
            c = CLookUp(What, Where, From, i)
    Next c
    j = TheRow(What, Where)
    Range("DTE") = Where.Worksheet.Cells(j, 177)
Private Sub Export(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Inside As Range)
Dim i As Integer
Dim c As Range
Dim j As Long
If What <> "" Then
            i = i + 1
            From(j, i) = c
    Next c
    With Feuil2
        .Cells(j, 1) = What
        .Cells(j, 177) = Range("DTE")
Private Sub ClearForm()
Range("DESC").ClearContents
Range("CAUS").ClearContents
Range("VERIF").ClearContents
Range("ACT").ClearContents
J'explique un peu le but de la macro : en tapant une référence dans la feuille quick kaizen, si la référence existe déjà ça reprend les données de la feuille BD et si je modifie et je valide, ça remet à jour le tableau BD sur la ligne de la référence. Si j'aoute une nouvelle référence elle se met à la suite dans le tableau.
Je préviens je suis un grand débutant. Donc j'ai essayé de chercher par moi même pour essayer de comprendre.
1- Que veut dire : Private Sub
2- Dim XXX As YYY ça permet bien de définir une variable?
3- Que veut dire Application.ScreenUpdating?
4- Que veut dire Rows.Count?
5- je comprend pas l'expression
6- Que veut dire Application.EnableEvents
7- Je ne comprend pas l'expression
8- La fonction OLEObjects, ça sert à créer le bouton sur la feuille quick kaizen?
C'est mes questions sur les deux premiers private
Si quelqu'un pouvait m'expliquer de façon sommaire ce qu'on font chaque private car je suis totalement perdu.
Bonjour Hvegung, bonjour le forum,
Le code commenté :
Option Explicit 'oblige à définir toutes les variables (sinon ça plante)
Private Sub ImpExp_Click() 'cette macro doit, je pense, être associée à un bouton
Dim LastLig As Long, TheLig As Long 'déclare les variables LastLig de type long, TheLig de type long
Dim Tmp As String 'déclare la variable Tmp de type texte
Application.ScreenUpdating = False 'masque les rafraîchissements d'écran
Tmp = Range("REF") 'définit la variable Tmp (correspond au contenu de la plage nommée "REF")
If Tmp <> "" Then 'condition : si Tmp n'est pas vide
    With Feuil2 'prend en compte l'onglet "Feuil2"
        LastLig = .Cells(.Rows.Count, 1).End(xlUp).Row 'définit la variable LastLig (ligne de la dernière cellule éditée de la colonne 1 (=A)
        TheLig = TheRow(Tmp, .Range("A4:A" & LastLig)) 'définit la variable TheLig à l'aide de la fontion [TheRow] (plus bas)
        'si TheLig est supérieur à LastLig met une bordure aux cellule de la ligne TheLig à TheLig + 176 dans la colonne A
        Export Tmp, .Range("A4:A" & LastLig), .Range("B:HP"), Range("DESC") 'voir fonction [Export] (plus bas)
        Export Tmp, .Range("A4:A" & LastLig), .Range("I:DP"), Range("CAUS") 'voir fonction [Export] (plus bas)
        Export Tmp, .Range("A4:A" & LastLig), .Range("DQ:ER"), Range("VERIF") 'voir fonction [Export] (plus bas)
        Export Tmp, .Range("A4:A" & LastLig), .Range("ES:FT"), Range("ACT") 'voir fonction [Export] (plus bas)
    End With 'fin de la prise en compte de l'onglet "Feuil2"
    Range("REF") = "" 'vide le contenu de la plage nommée "REF"
    Range("DTE") = "" 'vide le contenu de la plage nommée "DTE"
End If 'fin de la condition
Private Sub Worksheet_Change(ByVal Target As Range) 'au changement dans l'onglet
'(ce code ne doit pas se trouver dans un module standard mais dans un onglet, par exemple : Feuil1(Feuil1), sinon il ne fonctionne pas !
'il agira chaque fois que tu modifieras le contenu d'une cellule
'condition 1 : si la cellule modifiée correspond à la première cellule de la plage nommée "REF"
    Tmp = Target(1, 1) 'définit la variable tmp (valeur de la cellule active)
    Application.EnableEvents = False 'empêche les procédure événementielles de se produire (évite la boucle sur cet événement si le code modifie une autre cellule)
    Range("REF") = UCase(Tmp) 'met le contenu de la plage nommée "REF" en majuscule
    ClearForm 'lance la procédure [ClearForm] (voir plus bas)
        If TheLig > LastLig Then 'condition 2 : si TheLig est supérieur à LastLig
            Target.Font.Color = 255 'colore la police de la cellue modifiée (je ne sais pas quelle est la couleur)
            With ActiveSheet.OLEObjects("ImpExp").Object 'prend en compte un objet nommé "ImpEXP"
                .Caption = "Enregistrer nouvelle référence" 'modifie le texte
                .ForeColor = 255 'modifie la couleur
            End With 'fin de la prise en compte de l'objet "ImpExp"
        Else 'sinon (condition 2 : si TheLig n'est pas supérieur à lastLig)
            Target.Font.Color = 0 'colore la police de la cellule modifiée (je ne sais pas quelle est la couleur)
                .Caption = "Modifier référence" 'modifie le texte
                .ForeColor = vbBlue 'modifie la couleur
            Import Tmp, .Range("A:A"), .Range("B:H"), Range("DESC") 'voir fonction [Import] (plus bas)
            Import Tmp, .Range("A:A"), .Range("I:DP"), Range("CAUS") 'voir fonction [Import] (plus bas)
            Import Tmp, .Range("A:A"), .Range("DQ:ER"), Range("VERIF") 'voir fonction [Import] (plus bas)
            Import Tmp, .Range("A:A"), .Range("ES:FT"), Range("ACT") 'voir fonction [Import] (plus bas)
        End If 'fin de la condition 2
    Application.EnableEvents = True 'autorise les procédure événementielles (il faut toujours remettre à true à la fin !)
End If 'fin de la condition 1
Private Function TheRef(ByVal What As String, ByVal Where As Range) As Range 'fonction TheRef avec les attributs "What" et "Where"
If What <> "" Then Set TheRef = Where.Find(What, LookIn:=xlValues, lookat:=xlWhole) 'définit la plage TheRef en fonction de la première occurrence trouvée de "What" dans "Where"
End Function
Private Function CLookUp(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Num As Integer) 'fonction CLookUp avec les attributs "What", "Where", "From" et "Num"
Dim c As Range 'déclare la variable c de type range (cellule ou plage de cellules)
Set c = TheRef(What, Where) 'définit la page c à l'aide de la fonction [TheRef] voir au-dessus
If Not c Is Nothing Then 'si il existe au moins une occurrence trouvée
    CLookUp = Intersect(c.EntireRow, From(, Num).EntireColumn) 'définit CLookUp 'Heu pas vraiment compris là...
    Set c = Nothing 'vide la variable c
End Function
Private Function TheRow(ByVal What As String, ByVal Where As Range) As Long 'fonction TheRow avec les attributs "What" et "Where"
If Not c Is Nothing Then 'condition : si il existe au moins une occurrence trouvée
    TheRow = c.Row 'TheRow correspond à la ligne de l'occurrence trouvée
Else 'sinon
    TheRow = Where.Offset(Where.Rows.Count).Row 'redéfinit la ligne TheRow
End Function
Private Sub Import(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Inside As Range) 'procédure avec les attributs "What", "Where", "From", "Inside"
Dim i As Integer 'déclare la variable I (incrément)
Dim c As Range 'déclare la variable c (Cellule)
Dim j As Long 'déclare la variable j
Set c = TheRef(What, Where) 'définit la cellule c (ou pla plage) à l'aide de la fontion [TheRef] voir plus haut
If Not c Is Nothing Then 'condition : si il existe au moins une occurence trouvée
    For Each c In Inside 'boucle sur toutes les cellues c de l'attribut "Inside"
        If c.MergeArea(1, 1).Address = c.Address Then 'condition : si la l'addresse de la première cellule de la palge c est la même que la cellulle c (pas compris là non plus)
            i = i + 1 'incrément i
            c = CLookUp(What, Where, From, i) 'redéfinit c avec la fonction [CLookUp]
    Next c 'prochaine cellule de la boucle
    j = TheRow(What, Where) 'définit la ligne j à l'aide de la fonction [TheRow]
    Range("DTE") = Where.Worksheet.Cells(j, 177) 'définit la valeur de la plage nommée "DTE"
Private Sub Export(ByVal What As String, ByVal Where As Range, ByVal From As Range, ByVal Inside As Range) 'voir explication dans la procédure au dessus
Dim i As Integer
Dim c As Range
Dim j As Long
If What <> "" Then
            i = i + 1
            From(j, i) = c
    Next c
    With Feuil2
        .Cells(j, 1) = What
Range("DESC").ClearContents 'vide la plage nommée "DESC"
Range("CAUS").ClearContents 'vide la plage nommée "CAUS"
Range("VERIF").ClearContents 'vide la plage nommée "VERIF"
Range("ACT").ClearContents 'vide la plage nommée "ACT"
Bonjour ThauThème,
Merci beaucoup pour l'explication de la macro, c'est déjà un peu plus clair,
Il reste quelque partie encore un peu sombre mais tu m'as déjà beaucoup aidée
Tu dois surtout remercier la personne qui t'a fait le code car il est remarquable !...
Re-bonjour,
Je l'ai bien remercié, et ça fonctionne bien mieux que la macro que j'avais fait mais beaucoup plus difficile à comprendre aussi
Je cherchais ce type de macro et il me convient très bien.
Toutefois j'aurai besoin de l'adapter et je ne suis pas un grand expert de VBA.
Il faudrait que cette macro soit active sur uniquement sur certaines plages variables de la feuille.
Je voudrais par exemple que cette macro fonctionne :
A34; A41
puis
A45;A52
puis
A56;A63
sachant que chaque plage peut s'agrandir de façon plus ou moins importante...
Merci pour votre aide.
Bonjour Beno et bienvenue...
Mieux vaut commencer par de bonnes pratiques !
Ça ne se fait pas de squatter un sujet pour poser une autre question...
Tu ouvres ton sujet, tu pose ta question, en fournissant les éléments utiles et autant que possible un fichier d'illustration sur lequel il soit possible de travailler.
Si tu y tiens tu peux toujours récupérer la macro qui t'intéresse et la soumettre dans ton propre sujet, mais cela reste tout à fait secondaire. L'important est ta problématique et ta configuration propres qui pourront conduire à un éventail de propositions peut-être très différentes de la bouée à laquelle tu essaies de t'accrocher.
Bonjour MFerrand,
Je comprends bien l’idée de squatter le sujet d’un autre. je ne voulais pas faire mal et j’ai même pensé faire bien
Mais vu que j’ai utilisé les macros proposées ici (puis retenue l’une d’entre elle) je me suis dit que choses :
  • que faire une nouveau sujet sur alors qu’un poste existe déjà ce n’était utile (et je pensais que ça allait alourdir le forum)
  • ça pouvait servir à d’autres qui avaient déjà regarder et/ou suivi le sujet.
Pour l’envoi d’une fichier d’exemple le fichier que j’utilise est assez lourd, et comporte des coordonnées (société et collègues) que je ne souhaite pas diffuser.
Mais comme je viens de me faire taper sur les doigts, je vais essayer de déposer un fichier un peu similaire retiré de toute info perso.
Le temps de le constituer et je reviens ici
Rechercher des sujets similaires à "explication macro"
