Setsourcedata
voici, une proposition, à tester. pas très élégante, mais j'ai les neurones bouchés.
nom = ComboBox4.Value
Feuil1.Select
Range("7:7").Find(nom, , xlValues, xlWhole, , , False).Select
ActiveCell.Select
Colonne = ActiveCell.Column
ligne = ActiveCell.Row
Set graphdata = Sheets("saisie").Range(Cells(ligne + 3, Colonne), Cells(ligne + 1949, Colonne))
For Each w In graphdata
 If w.EntireRow.Hidden = False Then datafound = True: Exit For
If datafound = False Then MsgBox "pas de données pour cette sélection": Exit Sub
Sheets(ComboBox4.Value).Select
Dim wsData As Worksheet, wsChart As Worksheet
Dim rngChart As Range
Dim objChart As ChartObject
Dim objLE As LegendEntry
ActiveSheet.Unprotect Password:="toto"
    Set wsData = Feuil1
    Set wsChart = ActiveSheet
    On Error Resume Next
    wsChart.ChartObjects(1).Delete
    On Error GoTo 0
    Set objChart = wsChart.ChartObjects.Add _
            (Left:=wsChart.Columns("c").Left, _
            Top:=wsChart.Rows(9).Top, _
            Width:=800, _
            Height:=280)
    With objChart.Chart
        .ChartType = xlColumnClustered
        .SetSourceData Source:=graphdata
        .HasTitle = True
        .ChartTitle.Text = ComboBox3.Value & " - " & ComboBox4.Value
        .HasLegend = False
Unload Me
    Set objChart = Nothing
    Set rngChart = Nothing
    Set wsChart = Nothing: Set wsData = Nothing
ActiveSheet.Protect Password:="toto", DrawingObjects:=False, Contents:=True, Scenarios:=True
Merci.
tu sais ... moi et l'élégance....
Rechercher des sujets similaires à "setsourcedata"
