Dashboard Outlook
J'ai besoin de votre aide afin de créer un dashboard dans EXCEL pour outlook sous le format suivant
J'avais trouvé un code (ci-dessous) mais qu'il m'affiche les résultats dans un msgbox alors que j'en ai besoin dans excel lui même
Sub CountDatedEmails()
'Declare Outlook app and folder object variables.
Dim objOutlook As Object, objnSpace As Object
Dim objFolder As Object, objFolderA As Object, objFolderB As Object
Set objOutlook = CreateObject("Outlook.Application")
Set objnSpace = objOutlook.GetNamespace("MAPI")
'Verify existence of MIS folder as direct subfolder of Personal Folders.
On Error Resume Next
Set objFolder = objnSpace.Folders("Account1").Folders("Sent Items")
If Err.Number <> 0 Then
Err.Clear
MsgBox "No such folder named MIS.", 48, "Cannot continue"
Exit Sub
'Verify existence of Enquiries folder as direct subfolder #1 of Personal Folders.
Set objFolderA = objnSpace.Folders("Account1").Folders("Inbox").Folders("Folder1")
Err.Clear
MsgBox "No such folder named Enquiries exists in the Inbox folder.", 48, "Cannot continue"
Exit Sub
'Verify existence of Enquiries folder as direct subfolder #2 of Personal Folders.
Set objFolderB = objnSpace.Folders("Account1").Folders("Inbox").Folders("Folder2")
Err.Clear
MsgBox "No such folder named Application exists in the Inbox folder.", 48, "Cannot continue"
Exit Sub
'All folders are present, OK to continue.
'Declare and define the myDate variable to be yesterday's date.
Dim myDate As Date
myDate = DateSerial(Year(Date), Month(Date), Day(Date) - 1)
'Declare and define the count and date variables for all 3 folders.
Dim iCount As Integer
Dim EmailCountInbox As Integer, EmailCountEnquiries As Integer, EmailCountApplication As Integer
Dim DateCountInbox As Integer, DateCountEnquiries As Integer, DateCountApplication As Integer
'Count total and yesterday's received emails in the Inbox folder:
EmailCountInbox = objFolder.Items.Count: DateCountInbox = 0
For iCount = 1 To EmailCountInbox
With objFolder.Items(iCount)
If DateSerial(Year(.ReceivedTime), Month(.ReceivedTime), Day(.ReceivedTime)) = myDate Then DateCountInbox = DateCountInbox + 1
Next iCount
'Count total and yesterday's received emails in the Inbox > Enquiries folder:
EmailCountEnquiries = objFolderA.Items.Count: DateCountEnquiries = 0
For iCount = 1 To EmailCountEnquiries
With objFolderA.Items(iCount)
If DateSerial(Year(.ReceivedTime), Month(.ReceivedTime), Day(.ReceivedTime)) = myDate Then DateCountEnquiries = DateCountEnquiries + 1
Next iCount
'Count total and yesterday's received emails in the Inbox > Application folder:
EmailCountApplication = objFolderB.Items.Count: DateCountApplication = 0
For iCount = 1 To EmailCountApplication
With objFolderB.Items(iCount)
If DateSerial(Year(.ReceivedTime), Month(.ReceivedTime), Day(.ReceivedTime)) = myDate Then DateCountApplication = DateCountApplication + 1
Next iCount
'Advise the user of all counts for the three folders.
MsgBox _
"Inbox folder email count - -" & vbCrLf & _
"Total: " & vbTab & vbTab & EmailCountInbox & vbCrLf & _
"Yesterday: " & vbTab & DateCountInbox & vbCrLf & vbCrLf & _
"Inbox > Enquiries folder email count - -" & vbCrLf & _
"Total: " & vbTab & vbTab & EmailCountEnquiries & vbCrLf & _
"Yesterday: " & vbTab & DateCountEnquiries & vbCrLf & vbCrLf & _
"Inbox > Application folder email count - -" & vbCrLf & _
"Total: " & vbTab & vbTab & EmailCountApplication & vbCrLf & _
"Yesterday: " & vbTab & DateCountApplication, , "Email counts:"
'Release object variable memory
Set objFolder = Nothing
Set objFolderA = Nothing
Set objFolderB = Nothing
Set objnSpace = Nothing
Set objOutlook = Nothing
End Subautre problème que j'ai c'est que j'ai besoin que ces données soit actualisé chaque 2 minutes (genre refresh)
Merci infiniment pour votre aide
cdt
Soufiane
avant d'automatiser le refresh, regarde si ceci fonctionne et peut te convenir
For Each acc In objnSpace.Folders
nacc = nacc + 1
Set objFolder = acc.Folders("Sent Items")
Err.Clear
Exit Sub
Set objFolderA = acc.Folders("Inbox")
Err.Clear
Exit Sub
Dim myDate As Date
'Count total nimber of mails received today
EmailCountInbox = objFolderA.Items.Count: DateCountInbox = 0
Next iCount
'Count total number of mails sent today
EmailCountEnquiries = objFolder.Items.Count: DateCountEnquiries = 0
Next iCount
Cells(nacc, 1) = acc.Name
Cells(nacc, 3) = DateCountEnquiries
Cells(nacc, 2) = DateCountInbox
Next acc
End SubMerci inifniment pour l'aide
mais malheureusement sa ne fonctionne pas, il m'affiche l'erreur " MsgBox "No such folder named MIS."
il me donne le nom du compte dans A1 et le un nombre 2784dans B1 et 0 dans C1
alors que le chiffre 2784 n'existe sur aucun de mes repetoire
autre chose, il m'affiche un seul compte alors que j'ai 4
merci d'avance
bonjour,
je t'ai fait une nouvelle version, je suppose que tu as une version FR de outlook et que les noms de ses répertoires sont en français.
si c'est le cas dans le code ci-dessous tu devras changer les noms anglais par leur équivalent en français. (je pense que cela doit s'appeler "messages reçus" et "messages envoyés" mais je n'en suis pas sûr.
nomfolders = Array("Inbox", "Sent Items") '<- changer nom des dossiers outlook ici
Dim myDate As Date
myDate = DateSerial(Year(Date), Month(Date), Day(Date))
ctrf = 1
nacc = nacc + 1
If nacc = 1 Then
Cells(1, 1) = "compte"
Cells(1, 2) = "Messages reçus"
Cells(1, 3) = "Messages envoyés"
nacc = nacc + 1
For Each nomfolder In nomfolders
ctrf = ctrf + 1
Set objFolder = acc.Folders(nomfolder)
Cells(nacc, ctrf) = "Non trouvé"
EmailCount = objFolder.Items.Count: DateCount = 0
If DateSerial(Year(.ReceivedTime), Month(.ReceivedTime), Day(.ReceivedTime)) = myDate Then DateCount = DateCount + 1
Next iCount
Cells(nacc, ctrf) = DateCount
End SubNon j'ai un Office anglais
as-tu essayé cette nouvelle version ?
il me donne un compte et il tourne en infini, il veut pas s'arreter :/
combien as-tu de messages dans ta boite mail ? il lui faut le temps de tous les passeer en revue pour sélectionner ceux qui correspondent à la date du jour.
une version qui te permet de voir par folder, le nombre de messages et de sous-folders, si tu pouvais me l'envoyer pour que je me fasse une idée de la structure de ta boite mail.
Dim myDate As Date
ctrf = 1
nacc = nacc + 1
If nacc = 1 Then
Cells(1, 3) = "sous folders"
nacc = nacc + 1
For Each f In acc.Folders
nomfolder = f.Name
'For Each nomfolder In nomfolders
'ctrf = ctrf + 1
ctrf = 2
nacc = nacc + 1
Cells(nacc, 1) = acc.Name & " " & nomfolder
'For iCount = 1 To EmailCount
' With objFolder.Items(iCount)
' If DateSerial(Year(.ReceivedTime), Month(.ReceivedTime), Day(.ReceivedTime)) = myDate Then DateCount = DateCount + 1
' End With
'Next iCount
Cells(nacc, ctrf) = EmailCount
Cells(nacc, ctrf + 1) = acc.Folders(nomfolder).Folders.Count
Est-ce que je peux avoir le même truc qui me compte les emails dans ceratin repertoire (je peux déplacer les message des jours qui m'interesse pas et comme ça le resultas sera rapide.
merci encore une fois
compte Messages reçus sous folders
Compte1 Deleted Items 0 0
Compte1 Inbox 3607 24
Compte1 Outbox 0 0
Compte1 Sent Items 807 0
Compte1 Calendar 13 0
Compte1 Contacts 4 0
Compte1 Conversation Action Settings 0 0
Compte1 Drafts 13 0
Compte1 Journal 0 0
Compte1 Junk E-Mail 0 0
Compte1 Notes 0 0
Compte1 Tasks 1 0
Compte1 Sync Issues 1 3
Compte1 RSS Feeds 0 0
Compte1 Quick Step Settings 0 0
Compte1 Conversation History 2 0
Public Folders - Compte1 Favorites 0 0
Public Folders - Compte1 All Public Folders 0 7
Compte1 Outbox 0 0
Compte1 Drafts 13 0
Compte1 Journal 0 0
Compte1 Notes 0 0
Compte1 Tasks 1 0
Compte2 Deleted Items 7 4
Compte2 Inbox 2 23
Compte2 Outbox 0 0
Compte2 Sent Items 135747 0
Compte2 Calendar 3 0
Compte2 Contacts 7 0
Compte2 Conversation Action Settings 0 0
Compte2 Conversation History 0 0
Compte2 Drafts 0 0
Compte2 Journal 0 0
Compte2 Junk E-Mail 5 0
Compte2 Mail Delivery failed 0 0
Compte2 News Feed 0 0
Compte2 Notes 0 0
Compte2 Quick Step Settings 0 0
Compte2 RSS Subscriptions 0 0
Compte2 Suggested Contacts 0 0
Compte2 Sync Issues 0 4
Compte2 Tasks 0 0
Public Folders - Compte2 Favorites 0 0
Public Folders - Compte2 All Public Folders 0 7
re-bonjour,
regarde si ceci peut te convenir.
Sub CountDatedEmailsv1()
nomfolders = Array("Inbox", "Sent Items") '<- mettre ici la liste des folders à prendre en compte
Dim myDate As Date
lig = 0
browsefolder acc, nomfolders, 1, lig
Sub browsefolder(folder, nomfolders, n, ByRef lig)
lig = lig + 1
Cells(lig, n) = folder.Name & "(" & folder.items.Count & ")"
For Each f In folder.Folders
For Each tod In nomfolders
If tod = f.Name Then
browsefolder f, nomfolders, n + 1, lig
Exit For
End SubLe resultats il est TOP tu es un génie!!!
serai t'il possible que le resultats soit affiché comme dans la solution d'avant ? au fait le dernier code s'affiche comme suit
dans le colonne B j'ai :
Inbox(3630)
Sent Items(811)
Inbox(3630)
Sent Items(811)
Inbox(2)
Sent Items(135860)
serait-il possible d'avoir dans "B" le nom des repertoire et dans "C" le count sans parenthèses.?
aussi comme je peux le faire un refresh chaque 2 minutes ?
merci infiniment
bonsoir,
voici les adaptations demandées
attention tu ne pourras pas travailler en excel tant que cette application est ouverte.
Dim myDate As Date
lig = 0
nr = Now() + TimeValue("00:02:00") 'refresh toutes les 2 minutes
Cells(lig + 1, 1) = "next refresh at " & Format(nr, "hh:mm:ss")
Application.OnTime nr, "CountDatedEmailsv1"
lig = lig + 1
If n > 1 Then Cells(lig, n + 1) = folder.items.Count
Exit For
End SubSa fonctionne a merveille; derniere aide si c'est possible;
l'objectif c'est d'afficher que les chiffre que je veux dans sheet 2 alors que sheet 1 où les données s'exécutent reste invisible malgré la réactualisation comme ca j'aurai un Dashboard avec les couleurs et le design que je veux dans le sheet 2
est-ce possible ?
merci ennormement d'avance
bonjour,
voici
Set ws = Worksheets("sheet1")
Dim myDate As Date
lig = 0
browsefolder acc, nomfolders, 1, lig, ws
ws.Cells(lig + 1, 1) = "next refresh at " & Format(nr, "hh:mm:ss")
Sub browsefolder(folder, nomfolders, n, ByRef lig, ws)
lig = lig + 1
ws.Cells(lig, n) = folder.Name
If n > 1 Then ws.Cells(lig, n + 1) = folder.items.Count
browsefolder f, nomfolders, n + 1, lig, ws
Exit For
End SubOhhhh sa fonctionne à merveille
merci bcp pour ton aide
