Copier - Coller par VBA
Quelqu 'un a t'il une idée , pour transverse ca fonctionne mais pour gauche et sigmoide ca ne fonctionne pas!!!!
les cellule ne se copie pas en c18 et en d18
merci d'avance pour votre aide inestimable!!!
greg954
ps suis debutant !:!!
Sub copieindexmoteur()
'transverse'
If Sheets("Calculs").Range("I21").Value = "V1" Then
Range("F2:F31").Select
Selection.Copy
Sheets("Tableaux patient").Select
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V2" Then
Range("F33:F62").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V3" Then
Range("F64:F93").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V4" Then
Range("F95:F124").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V5" Then
Range("F126:F155").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V6" Then
Range("F157:F186").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V7" Then
Range("F188:F217").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I21").Value = "V8" Then
Range("F219:F248").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
'gauche'
ElseIf Sheets("Calculs").Range("I22").Value = "V1" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V2" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V3" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V4" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V5" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V6" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V7" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I22").Value = "V8" Then
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
'sigmoide'
ElseIf Sheets("Calculs").Range("I23").Value = "V1" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V2" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V3" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V4" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V5" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V6" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V7" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
ElseIf Sheets("Calculs").Range("I23").Value = "V8" Then
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Edit Dan : modification du sujet
Tout d'abord: BONJOUR,,
essaies ce code:
Sub test()
moteur = Sheets("Calculs").Range("I21").Value
Select Case moteur
Case Is = "V1"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V2"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V3"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V4"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V5"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V6"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V7"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Case Is = "V8"
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
End Select
gauche = Sheets("Calculs").Range("I22").Value
Select Case gauche
Case Is = "V1"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V2"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V3"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V4"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V5"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V6"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V7"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
Case Is = "V8"
Selection.Copy
Range("C18").Select
ActiveSheet.Paste
End Select
sigmoide = Sheets("Calculs").Range("I23").Value
Select Case sigmoide
Case Is = "V1"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V2"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V3"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V4"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V5"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V6"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V7"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Case Is = "V8"
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
End Select
C'est normal que gauche et sigmoide ne fonctionnent pas dans le tien, puisqu'il trouve déjà une valeur dans transverse... il arrête donc la procédure...
J'attends ta réponse,
Souri84
Bonjour Souris 84 ( desolé pour le bonjour mais j'en suis au 3 eme poste deouis ce matin
et dans la précipitation je n'ai pas redit bonjour
en tous cas MERCI BEAUCOUP de m'avoir aider ( ca fait plaisir lol)
ca bloque tjs
Mais j'ai bricoler ca et ca marche Attention c'est de la bidouiille mais ca marche maintenant je vais essayer de bricoller t'on code qui me parrait beaucoup plus cllair que ma bidouille
merci encore
voici le code (bidouiille qui fonctionne)
encore merci
greg954
Sub transverse()
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Sheets("Calculs").Select
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("B18").Select
ActiveSheet.Paste
Range("I18").Select
Sub gauche()
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Selection.Copy
Range("c18").Select
ActiveSheet.Paste
Range("I18").Select
Sub sigmoide()
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Selection.Copy
Range("D18").Select
ActiveSheet.Paste
Rechercher des sujets similaires à "copier coller vba"
