Menu déroulant saisie rapide
Je viens d'installer un menu déroulant. Je souhaiterai en plus pouvoir me faciliter la saisie en commençant la saisie dans la cellule afin de sélectionner plus rapidement le terme rechercher dans le menu déroulant (environ 300 termes).
Est-ce que vous comprenez ma demande et est-ce possible d'y répondre?
Ci joint solution proposée dans OZGRID:
Data Validation
Those that have used Data Validation will know that it is a very handy feature, especially the List option. The List option allows us to have a cell show a drop-down arrow, which the user can then select from.
Draw-Back
However, when we do the above we must either scroll to the needed item in the Validation list, or type the whole word. What would be really nice is if Excel would AutoComplete based on our list! Unfortunately no such standard feature exists in Excel.
The Solution
Go To Tools>Options - Edit And Check Enable AutoComplete For Cell Values
Move Your List Of Items Is In The Range Immediately Above The Validation Cell.
Hide The Rows Above Your Validation Cell.
Now, as you type Excel will look at the list above the Validation cell and AutoComplete based on it.
List is Dynamic and/or Resides on Another Worksheet
Lets say your list is on Sheet2 and you wish to use the Validation List with AutoComplete on Sheet1.
On Sheet1 A1 Enter =Sheet2!A1 and copy down including as many spare rows as needed (say 300 rows total). Hide these rows and use this formula in the Refers to: for a dynamic named range called MyList:
=OFFSET(Sheet1!$A$1,0,0,MATCH("*",Sheet1!$A$1:$A$300,-1),1)
Now in the cell immediately below the last hidden row use Data Validation and for the List Source use =MyList
Colonnes C & D : données.
E3 : saisir l'initiale ( A ou B dans le fichier joint).
Menu déroulant en G7.
mbbp
Je n'ai pas compris la réponse.
Je vous envois le fichier concerné.
Merci,
1. Dès le départ joindre le fichier.
2. "Je n'ai pas compris la réponse."
J'ai pourtant utilisé des mots simples.
3. Remercier les participants à ta discussion même si les solutions proposées ne sont pas satisfaisantes.
mbbp
apres avoir trier par la colonne des noms de a à z
nommer la colonne c colc ; la 1ere cel "deptt
dans validtion la formule est
DECALER(dept;EQUIV(E16;GAUCHE(colc);0)-1;;SOMMEPROD(--(GAUCHE(colc)=E16)))
desormai tu saisi la 1ere lettre et tu choisis
71claire.7z (69.00 Octets)
desolé je dois zipper pourtant c'est pas lourd ........
oubli :ne pas mettre de $ a E16 afin de pouvoir tartiner la colonne avec la validation
Voici un exemple :
https://www.cjoint.com/c/DHlrfuTGHCg
Les données peuvent se situer une autre feuille (plages nommées), par contre il faut impérativement qu'elles soient triées par ordre alphabétique.
Rechercher des sujets similaires à "menu deroulant saisie rapide"
