VBA: consolidation des diverrs données dans une meme feuille
J'ai une macro qui fonctionne parfaitement avec mes conditions actuelles!( un non unique de feuilles a chercher qui est "Actual GB AAA")
Maintenant, j'ai trois noms de feuille differents a aller chercher( "Actual GB AAA","Actual GB BBB","Actual GB CCC")
A partir de ma macro, pourriez vous svp me donner une ecriture qui puisse prendre en compte les trois noms de feuilles.
Merci d'avance cella me sera d'une grande utilité.
Ci-dessous mon code de base.
Sub HC_Global()
'Variables Declaration
Dim Path As String, File As String
Dim Worksheet As Worksheet
Dim Target_Worksheet As String
Dim OK_Worksheet As Boolean, Start As Boolean
Dim Name As Name
Dim FirstLine As Long, LastLine As Long, LastLineTarget As Long
Dim FirstColumn As Long, LastColumn As Long
Target_Worksheet = "Actual GB AAA"
ThisWorkbook.Sheets(Target_Worksheet).Cells.Clear
Path = ThisWorkbook.Path
Start = True
'If unsaved file, then no path => always save the file before executing the macro
If Path <> "" Then
'Filters only on Excel files
File = Dir(Path & "\*.*xls*")
'Only "esthetic" : improves speed and processing appearance (deactivating sreen update)
Do While File <> ""
If File <> ThisWorkbook.Name Then
Workbooks.Open Filename:=Path & "\" & File, ReadOnly:=True, UpdateLinks:=False
'Test if worksheet exists
OK_Worksheet = False
For Each Worksheet In Workbooks(File).Sheets
If Worksheet.Name = Target_Worksheet Then OK_Worksheet = True: Exit For
'If worksheet OK => copies worksheet content to "Global" file
If OK_Worksheet Then
Worksheet.Unprotect Password:="FCII"
Worksheet.Columns.Ungroup
Worksheet.AutoFilterMode = False
'Sets the range to copy in "Global"
FirstLine = Lookforfirstline(Workbooks(File), Target_Worksheet) + 1
If Not Start Then FirstLine = FirstLine + 1
Start = False
LastLine = LookforLastline(Workbooks(File), Target_Worksheet)
FirstColumn = LookforFirstColumn(Workbooks(File), Target_Worksheet)
LastColumn = LookforLastColumn(Workbooks(File), Target_Worksheet)
LastLineTarget = LookforLastline(ThisWorkbook, "Actual GB AAA") + 1
'No copy of the header if not the first file copied
With Workbooks(File).Sheets(Target_Worksheet)
.Range(.Cells(FirstLine, FirstColumn).Address & ":" & .Cells(LastLine, LastColumn).Address).Copy Destination:=ThisWorkbook.Sheets("Actual GB AAA").Range("A" & LastLineTarget)
'Deletes named cells
For Each Name In ThisWorkbook.Names
Name.Delete
Start = False
Worksheet.Protect Password:="FCII"
Workbooks(File).Close False
File = Dir
Loop
'Breaks Links
Dim Link As Variant
For Each Link In ActiveWorkbook.LinkSources
ActiveWorkbook.BreakLink Name:=Link, Type:=1
'Deletes Data/Validation
Sheets("Actual GB AAA").Select
Cells.Validation.Delete
'Deletes Conditional Formatting
Cells.FormatConditions.Delete
'Sorts data by Name & First Name
Cells.Select
ActiveWorkbook.Worksheets("Actual GB AAA").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Actual GB AAA").Sort.SortFields.Add Key:=Range( _
"l2:l1048576"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortNormal
"m2:m1048576"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortNormal
With ActiveWorkbook.Worksheets("Actual GB AAA").Sort
.SetRange Rows("1:01048576")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
' Filters
Range("A1").Select
Range(Selection, Selection.End(xlToRight)).Select
Range(Selection, Selection.End(xlDown)).Select
Selection.AutoFilter
Sheets("Updates").Select
' Re-activates Display Alerts
' Re-activates screen update
End IfSub HC_Global()
Dim Name As Name
tab(1)="Actual GB AAA"
tab(2)="Actual GB BBB"
tab(2)="Actual GB CCC"
For i = 1 to 3
Target_Worksheet = tab(i)
Start = True
If Path <> "" Then
Do While File <> ""
Start = False
Name.Delete
Start = False
File = Dir
Loop
'Breaks Links
Dim Link As Variant
Cells.Select
xlSortNormal
xlSortNormal
.Header = xlYes
.MatchCase = False
.Apply
' Filters
Range("A1").Select
next iMerci pour cette reponse
mais j'ai le message suivant quand je lance ma macro "compile error syntax error"
alors je me demandais s'il faut que je change quelque chose si oui quoi ?
car j'ai fait un copier coller de votre macro
en gros quand je rajoute ceci a ma macro
cette partie là reste en rouge. et c'est que vient le probleme je pense.
d'ailleurs pour "tab(2)="Actual GB CCC" ce serait pas par hasard "ta(3)=..." ?
merci d'avance!
En effet définit ton tableau alors
Dim tab
juste a la suite de "Dim FirstColumn As Long, LastColumn As Long" je met quoi "Dim tab As Worksheet" c'est bien ça?
Dim tab
tout court ou alors
dim tab(1 to 3) as string
bonjour,
selon moi tab est un mot réservé et ne peut pas être utilisé comme nom de variable.
Merci encore mais une fois de plus ces lignes se mettent toujours en rouge et j'ai toujours le meme message d'erreur
Dim tab
tab(3)="Actual GB CCC"
c'est quoi la difference entre Dim tag et Dim tab?
car quand je remplace tab par tag les lignes deviennent normales mais la variable i reste un probleme
Dim tabl
tabl(1)="Actual GB AAA"
tabl(2)="Actual GB BBB"
tabl(3)="Actual GB CCC"
For i = 1 to 3
Target_Worksheet = tabl(i)merci ça suppose donc que partout ou j'ai "Actual GB AAA" je remplace par tabl(i) ou je met tous les noms separé de ";"?
remplace par
Target_Worksheet
bonjour,
voila au juste ce que j'ai au final mais helas ça ne marche toujours pas
voila le message d'erreur que j'ai "subscript out of range"
ci dessous ma macro
quelqu'un decele t-il un probleme?
merci d'avance pour votre aide
Sub HC_Global()
Dim Name As Name
Dim tabl(1 To 3) As String
Dim i
tabl(1) = "Actual GB AAA"
tabl(2) = "Actual GB BBB"
tabl(3) = "Actual GB CCC"
For i = 1 To 3
Start = True
If Path <> "" Then
Do While File <> ""
Start = False
LastLineTarget = LookforLastline(ThisWorkbook, Target_Worksheet) + 1
.Range(.Cells(FirstLine, FirstColumn).Address & ":" & .Cells(LastLine, LastColumn).Address).Copy Destination:=ThisWorkbook.Sheets(Target_Worksheet).Range("A" & LastLineTarget)
Name.Delete
Start = False
File = Dir
Loop
'Breaks Links
Dim Link As Variant
Sheets(Target_Worksheet).Select
Cells.Select
ActiveWorkbook.Worksheets(Target_Worksheet).Sort.SortFields.Clear
ActiveWorkbook.Worksheets(Target_Worksheet).Sort.SortFields.Add Key:=Range( _
xlSortNormal
xlSortNormal
With ActiveWorkbook.Worksheets(Target_Worksheet).Sort
.Header = xlYes
.MatchCase = False
.Apply
' Filters
Range("A1").Select
End Sub.SetRange Rows("1:01048576")
Ici problème
et que dois je faire precisement de ce .SetRange Rows("1:01048576")
merci d'avance
enlever ce zéro avant ton 1
j'avais deja essayé sans ce zero devant le 1 mais ca ne fonctionne pas alors je me dis que le probleme est ailleurs.
et sincerement je ne vois pas
salut tout le monde!
je n'est toujours pas de solution a mon probleme
quelqu'un pour m'aider please?
sur quelle instruction reçois-tu ce message d'erreur ?
alors juste quand je lance ma macro j'ai ce message " Subscript out of range" rien d'autre
