Bonsoir à Tous
j'utilise un Userform pour modifier une ligne Excel, mon problème c'est que les changements se bloquent au niveau de la cellule H.
TextBox8. je n'arrive pas à trouver l'anomalie.
Merci d'avance sur votre aide
Dim lig As Integer
With Sheets("Feuil1") ' feuille ou sont mes infos d'avance
lig = .Columns("A").Find(What:=ComboBox1, after:=Range("A2"), Lookat:=xlWhole).Row ' chercher dans la colonne a , mon élément de référence
.Cells(lig, "B") = TextBox2
.Cells(lig, "C") = TextBox3
.Cells(lig, "D") = TextBox4
.Cells(lig, "E") = TextBox5
.Cells(lig, "F") = TextBox6
.Cells(lig, "G") = TextBox7
.Cells(lig, "H") = TextBox8
.Cells(lig, "I") = TextBox9
.Cells(lig, "J") = TextBox10
.Cells(lig, "K") = TextBox11
.Cells(lig, "L") = TextBox12
.Cells(lig, "M") = TextBox13
.Cells(lig, "N") = TextBox14
.Cells(lig, "O") = TextBox15
.Cells(lig, "P") = TextBox16
.Cells(lig, "Q") = TextBox17
.Cells(lig, "R") = TextBox18
.Cells(lig, "S") = TextBox19
.Cells(lig, "T") = TextBox20
.Cells(lig, "U") = TextBox21
.Cells(lig, "V") = TextBox22
.Cells(lig, "W") = TextBox23
.Cells(lig, "X") = TextBox24
.Cells(lig, "Y") = TextBox25
.Cells(lig, "Z") = TextBox26
.Cells(lig, "AA") = TextBox27
.Cells(lig, "AB") = TextBox28
.Cells(lig, "AC") = TextBox29
.Cells(lig, "AD") = TextBox30
.Cells(lig, "AE") = TextBox31
.Cells(lig, "AF") = TextBox32
.Cells(lig, "AG") = TextBox33
.Cells(lig, "AH") = TextBox34
.Cells(lig, "AI") = TextBox35
.Cells(lig, "AJ") = TextBox36
.Cells(lig, "AK") = TextBox37
.Cells(lig, "AL") = TextBox38
.Cells(lig, "AM") = TextBox39
.Cells(lig, "AN") = TextBox40
.Cells(lig, "AO") = TextBox41
.Cells(lig, "AP") = TextBox42
.Cells(lig, "AQ") = TextBox43
.Cells(lig, "AR") = TextBox44
.Cells(lig, "AS") = TextBox45
.Cells(lig, "AT") = TextBox46
.Cells(lig, "AU") = TextBox47
.Cells(lig, "AV") = TextBox48
.Cells(lig, "AW") = TextBox49
.Cells(lig, "AX") = TextBox50
.Cells(lig, "AY") = TextBox51
.Cells(lig, "AZ") = TextBox52
.Cells(lig, "BA") = TextBox53
.Cells(lig, "BB") = TextBox54
.Cells(lig, "BC") = TextBox55
.Cells(lig, "BD") = TextBox56
Unload Me
