Extension de boucle
T
Je souhaiterais étendre le code ci-dessous (actuellement réalisé sur la colonne C) aux colonnes 3->14, 16->27, 29->40, 42->53, 55->66.
Pourriez-vous m'aider ?
Thomas
Sub thomas()
Dim deb As Integer, fin As Integer, k As Integer, j As Integer, truc As String
deb = 45
fin = 2131
For k = 4 To 40
For j = deb To fin Step 41
truc = truc + Range("C" & j)
Next j
Range("c" & k) = truc
deb = deb + 1
fin = fin + 1
truc = ""
Next k
E
Sub thomas()
arr=array(15,28,41,54)
For i = 3 to 66
if not isinarray(arr,i) then
deb = 45
fin = 2131
For k = 4 To 40
truc = truc + cells(j,i)
Next j
cells(k,i) = truc
deb = deb + 1
fin = fin + 1
truc = ""
Next k
end if
next i
Function IsInArray(arr As Variant, valueToCheck As String, _
Optional exactMatch As Boolean = True) As Boolean
Dim wordList As String
Dim startPosition As Long
Dim nextCommaPosition As Long
Dim matchedTerm As String
If UBound(Filter(arr, valueToCheck)) > -1 Then
wordList = Join(arr, ",") + ","
' start from the allegedly matched term ....
startPosition = InStr(wordList, valueToCheck)
' get position of the comma after the allegedly matched term ...
nextCommaPosition = InStr(startPosition + 1, wordList, ",")
' the alleged "match" is in between
matchedTerm = Mid$(wordList, startPosition, _
nextCommaPosition - startPosition)
If exactMatch Then
IsInArray = (StrComp(valueToCheck, matchedTerm) = 0)
IsInArray = (StrComp(valueToCheck, matchedTerm) <> 0)
End Function
