Aide
Hello everyone,
I'm new in VBA and i want to solve the following problem:
- Write a sub that creates an array of 20 random integer numbers ranging from 1 to 100, and sorts it using a bubble sort.
- Note that at the end of a loop the last element is always sorted. Use this fact to optimize the sort program.
- Modify the program such that the size of the array is given by the user (in an input box). Use dynamic arrays.
And i wrote the following code but it doesn't work. Please, correct what i've wrote
' Return a random integer number between two bounds
' It is assumed that lower <= upper.
Function Random(lower As Long, upper As Long) As Long
Random = Int((upper - lower + 1) * Rnd() + lower)
End Function
Sub subblesort()
'Create an array of 20 random integer number
Dim i As Double
Dim nb As Double
Dim myarray() As Variant
nb = 20
For i = 1 To nb
myarray(i) = Random(1, 100)
'Sort this array using bubblesort
Dim intTemp As Integer
Dim blnExchangeMade As Boolean
blnExchangeMade = True
Do While blnExchangeMade
blnExchangeMade = False
For i = LBound(myarray) To (UBound(myarray) - 1)
If myarray(i) > myarray(i + 1) Then
' exchange the items
intTemp = myarray(i)
myarray(i) = myarray(i + 1)
myarray(i + 1) = intTemp
Loop
'This procedure allows the user to choose the size of array
nb = InputBox("Please choose the size of your array wanted")
ReDim myarray(nb)
Call bubblesort
En Français c'est mieux
A tester
In French it is better
A test
End Function
Sub subblesort()
Dim i As Double
Dim nb As Double
nb = 20
nb = InputBox("Please choose the size of your array wanted", Default:=nb)
ReDim myarray(nb)
For i = 1 To nb
Loop
End SubMerci beaucoup pour votre aide, sa marche maintenant
