Raccourcir une procédure
je souhaiterais si possible raccourcir la procédure suivante (je dois la répéter 12 fois):
Private Sub CommandButton1_saisie_Click()
If mois1.Value = True Then
Sheets("SAISIE M PLF232").Activate
If TextBox1 = "" Then
TextBox1 = Range("c2")
Range("C2") = TextBox1
If TextBox2 = "" Then
TextBox2 = Range("c3")
Range("C3") = TextBox2
If TextBox3 = "" Then
TextBox3 = Range("c4")
Range("C4") = TextBox3
If TextBox4 = "" Then
TextBox4 = Range("c5")
Range("C5") = TextBox4
If TextBox5 = "" Then
TextBox5 = Range("c6")
Range("C6") = TextBox5
If TextBox6 = "" Then
TextBox6 = Range("c7")
Range("C7") = TextBox6
If TextBox7 = "" Then
TextBox7 = Range("c8")
Range("C8") = TextBox7
If TextBox8 = "" Then
TextBox8 = Range("c9")
Range("C9") = TextBox8
If TextBox9 = "" Then
TextBox9 = Range("c10")
Range("C10") = TextBox9
If TextBox10 = "" Then
TextBox10 = Range("c11")
Range("C11") = TextBox10
If TextBox11 = "" Then
TextBox11 = Range("c12")
Range("C12") = TextBox11
If TextBox12 = "" Then
TextBox12 = Range("c13")
Range("C13") = TextBox12
If TextBox13 = "" Then
TextBox13 = Range("c14")
Range("C14") = TextBox13
If TextBox14 = "" Then
TextBox14 = Range("c15")
Range("C15") = TextBox14
If TextBox15 = "" Then
TextBox15 = Range("c16")
Range("C16") = TextBox15
If TextBox16 = "" Then
TextBox16 = Range("c17")
Range("C17") = TextBox16
If TextBox17 = "" Then
TextBox17 = Range("c18")
Range("C18") = TextBox17
If TextBox18 = "" Then
TextBox18 = Range("c19")
Range("C19") = TextBox18
If TextBox19 = "" Then
TextBox19 = Range("c20")
Range("C20") = TextBox19
If TextBox20 = "" Then
TextBox20 = Range("c21")
Range("C21") = TextBox20
If TextBox21 = "" Then
TextBox21 = Range("c22")
Range("C22") = TextBox21
If TextBox22 = "" Then
TextBox22 = Range("c23")
Range("C23") = TextBox22
If TextBox23 = "" Then
TextBox23 = Range("c24")
Range("C24") = TextBox23
If TextBox24 = "" Then
TextBox24 = Range("c25")
Range("C25") = TextBox24
If TextBox25 = "" Then
TextBox25 = Range("c26")
Range("C26") = TextBox25
If TextBox26 = "" Then
TextBox26 = Range("c27")
Range("C27") = TextBox26
If TextBox27 = "" Then
TextBox27 = Range("c28")
Range("C28") = TextBox27
If TextBox28 = "" Then
TextBox28 = Range("c29")
Range("C29") = TextBox28
If TextBox29 = "" Then
TextBox29 = Range("c30")
Range("C30") = TextBox29
Unload Me
pour vous éclairer j'ai inséré une partie de mon fichier.
merci d'avance
Bonsoir Greg.18
Voici ton code largement optimisé
Dim Col As Integer, Ind As Integer
Col = 0
For Ind = 1 To 12
If Me("mois" & Ind).Value = True Then Col = Ind: Exit For
Next Ind
If Col = 0 Then
MsgBox ("Merci de sélectionner un mois!")
Exit Sub
' Mise à jour de la bonne colonne
With Sheets("SAISIE M PLF232")
For Ind = 1 To 29
If Me("TextBox" & Ind) = "" Then
Me("TextBox" & Ind) = .Cells(1 + Ind, 2 + Col)
.Cells(1 + Ind, 2 + Col).Value = Me("TextBox" & Ind).Value
Next Ind
Unload Me
End SubA+
Bonjour BrunoM45
Ma petite contribution
Un truc que je ne comprends pas : Remplir les TextBox pour ensuite fermer l'userform
Dim I As Integer, K As Integer, Colonne As Integer
For K = 1 To 12
If Me.Controls("mois" & K) = True Then
Colonne = K + 2
For I = 1 To 29
If Me.Controls("TextBox" & I) = "" Then
Me.Controls("TextBox" & I) = .Cells(I + 1, Colonne)
.Cells(I + 1, Colonne) = Me.Controls("TextBox" & I)
Next I
Exit For
Next K
If K > 12 Then
Unload Me
End SubSalut l'ami Banzai64
Banzai64 a écrit :Un truc que je ne comprends pas : Remplir les TextBox pour ensuite fermer l'userform
Je t'avoue franchement, moi non plus
Merci beaucoup pour la réactivité!
je vais tester ça de suite et je vous redis!
ensuite je vais tenter de vous expliquer pourquoi remplir les TextBox (je me trompe peut-être à 100% je débute):
supposons que j'ai à modifier un des chiffres saisi (genre mi-février mon C.A à fin janvier à légèrement fluctué suite à des ajustements comptables) je dois donc le ressaisir, si je ne saisi pas les autres TextBox les valeurs précédemment saisies seront écrasées non?
yes!!! ça tourne comme une horloge!
maintenant, si vous le permettez, j'aimerais bien comprendre... si vous êtes dispo bien sur.
merci d'avance
Bonsoir
Pour ma macro et grosso modo
Une boucle sur les OptionButton (Mois) et si un de coché, une boucle sur les TextBox dans la bonne colonne
Si on a fait le tour des OptionButton (mois) sans en trouvé un de coché : K vaudra 13 et message d'erreur
Super!
Merci beaucoup!
je suis navré de vous annoncer que j'ai encore un service à vous demander...
Comme vous pourrez le constater j'ai ajouté quelques éléments au UserForm (OptionButton1:14, CommandButton2 et TextBox35:37), que je souhaiterai lier à tout le reste (sélection du mois à saisir), malgré plusieurs heures passées sur le site dans les cours VBA je suis incapable de le faire moi même...
Si vous pouviez au moins m'aiguiller ce serait vraiment sympa!
Tu n'as rien à faire, comme ta base est vide laisse comme cela
Sérieusement que veux tu faire ?
Tu places quelques données et tu dis quand je fais .... je dois avoir ...... dans ..... etc.....
Moi je ne sais pas
je vais tenter d'être plus précis,
Quand je sélectionne un mois et que je saisi les données dans les 34 premières TextBox je dois avoir celles-ci dans la colonne correspondante (feuille "SAISIE M PLF232" ligne 2 à 35), si une ou plusieurs TextBox ne sont pas saisies il ne faut pas que les données dans les colonnes correspondantes soient écrasées (en cas de saisie en plusieurs fois), si aucun mois (CheckBox) de sélectionné MsgBox : "Merci de sélectionner un mois!", si tentative de cocher deux mois (CheckBox) alors MsgBox : "Un seul choix possible!"
ensuite au click sur le bouton SAISIE les données doivent être incrémentées comme mentionné ci-dessus (jusqu'ici tout fonctionne grâce à ton code de jeudi) et un MsgBox doit apparaître et demander si oui ou non l'utilisateur veut saisir l'affrètement,si non unload si oui il doit choisir quel transporteur via les OptionButton renseigner les trois TextBox (N° 35 36 et 37) et valider avec le bouton saisie affrètement en fonction du transporteur choisi (et du mois choisi dans "sélection du mois à saisir") les données vont dans les cellules correspondantes (ex: transporteur KUEHNE pour janvier C36 C37 C38, transporteur GEFCO pour janvier C39 C40 C41, etc...) et un MsgBox doit demander à l'utilisateur si oui ou non il souhaite continuer de saisir ou non si oui rebelotte si non unload.
J'espère avoir été clair.
A vérifier
J'ai remplacé les CheckBox (Mois) par des OptionButton : Cela évite le module de classe
Super! Merci beaucoup.
