Appliquer macro à tout les fichier Excel d'un repertoire
Je travaille tous les mois sur des fichier excel que je dois mettre en forme et protéger de manière identique.
Pour cela j'utilise la macro suivante
Sub Variables()
' Variables Macro
' Touche de raccourci du clavier: Ctrl+l
Columns("A:I").Select
Columns("A:I").EntireColumn.AutoFit
Range("E3").Select
ActiveCell.FormulaR1C1 = "=IF(RC4="""","""",IF(R2C="""","""",0))"
Range("E3").Select
Selection.AutoFill Destination:=Range("E3:I3"), Type:=xlFillDefault
Range("E3:I3").Select
Selection.AutoFill Destination:=Range("E3:I200"), Type:=xlFillDefault
Range("E3:I200").Select
Selection.Copy
:=True, Transpose:=False
With Selection.Validation
.Delete
.Add Type:=xlValidateDecimal, AlertStyle:=xlValidAlertStop, Operator _
:=xlBetween, Formula1:="0", Formula2:="9999"
.IgnoreBlank = True
.InCellDropdown = True
.InputTitle = ""
.ErrorTitle = ""
.InputMessage = ""
.ErrorMessage = ""
.ShowInput = True
.ShowError = True
Selection.FormatConditions.Add Type:=xlExpression, Formula1:= _
"=NBCAR(SUPPRESPACE(E3))=0"
Selection.FormatConditions(Selection.FormatConditions.Count).SetFirstPriority
Selection.FormatConditions(1).Borders(xlLeft).LineStyle = xlNone
Selection.FormatConditions(1).Borders(xlRight).LineStyle = xlNone
Selection.FormatConditions(1).Borders(xlTop).LineStyle = xlNone
Selection.FormatConditions(1).Borders(xlBottom).LineStyle = xlNone
With Selection.FormatConditions(1).Interior
.Pattern = xlNone
.TintAndShade = 0
Selection.FormatConditions(1).StopIfTrue = True
With ActiveSheet.PageSetup
.PrintTitleRows = "$1:$2"
.PrintTitleColumns = ""
ActiveSheet.PageSetup.PrintArea = ""
.LeftHeader = "&D"
.CenterHeader = "&F"
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.LeftMargin = Application.InchesToPoints(0.78740157480315)
.RightMargin = Application.InchesToPoints(0.78740157480315)
.TopMargin = Application.InchesToPoints(0.984251968503937)
.BottomMargin = Application.InchesToPoints(0.984251968503937)
.HeaderMargin = Application.InchesToPoints(0.511811023622047)
.FooterMargin = Application.InchesToPoints(0.511811023622047)
.PrintHeadings = False
.PrintGridlines = False
.PrintComments = xlPrintNoComments
.CenterHorizontally = True
.CenterVertically = True
.Orientation = xlLandscape
.Draft = False
.PaperSize = xlPaperA4
.FirstPageNumber = xlAutomatic
.Order = xlDownThenOver
.BlackAndWhite = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 4
.PrintErrors = xlPrintErrorsDisplayed
.OddAndEvenPagesHeaderFooter = False
.DifferentFirstPageHeaderFooter = False
.ScaleWithDocHeaderFooter = True
.AlignMarginsHeaderFooter = False
.EvenPage.LeftHeader.Text = ""
.EvenPage.CenterHeader.Text = ""
.EvenPage.RightHeader.Text = ""
.EvenPage.LeftFooter.Text = ""
.EvenPage.CenterFooter.Text = ""
.EvenPage.RightFooter.Text = ""
.FirstPage.LeftHeader.Text = ""
.FirstPage.CenterHeader.Text = ""
.FirstPage.RightHeader.Text = ""
.FirstPage.LeftFooter.Text = ""
.FirstPage.CenterFooter.Text = ""
.FirstPage.RightFooter.Text = ""
Columns("A:D").Select
Selection.Locked = True
Selection.FormulaHidden = False
Range("A:J").SpecialCells(xlCellTypeBlanks).EntireRow.Hidden = True
lignefin = [A:J].Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious, LookIn:=xlValues).Row
ActiveSheet.PageSetup.PrintArea = Range("a1", Cells(lignefin, 9)).Address
Range("A:J").EntireRow.Hidden = False
ActiveSheet.Protect Password:="PAIE"
ActiveWorkbook.Save
ActiveWorkbook.Close
Application.Quit
J'aimerai appliquer cette macro à tous les fichiers se trouvant dans le dossier suivant
Z:\Région IDF Val de Loire PACA BOURGOGNE\BOURGOGNE\grille com 08.13
J'ai regarder pas mal de forum mais n'y est pas trouver de commande qui s'applique à mon projet.
Pourriez vous m'aider?
Merci d'avance,
Laurent
teste cette macro :
Sub parcourirFichiers()
Dim chemin As String, Fichier As String
Dim wb As Workbook
Set wb = ThisWorkbook
chemin = wb.Path + "\"
Fichier = Dir(chemin & "*.xl*") ' 1er fichier
Do While (Len(Fichier) > 0)
If Fichier <> ThisWorkbook.Name Then
Workbooks.Open chemin & Fichier
' traitement
Variables
Fichier = Dir() ' fichier suivant
Loop
End SubLe fichier doit être dans le répertoire à traiter. Elle ouvre tous les fichiers du répertoire où elle se trouve et lance ta macro.
eric
Whaooo super merci
Par contre je suis vraiment pas très doué
pouvez vous m'indiquer comment l'intégré à ma macro?
Dois-je copier ce texte avant ou après? ou intercallé ma macro dans ce code?
dois-je modifier certaine information? du style remplacé chemin par "Z:\Région IDF Val de Loire PACA BOURGOGNE\BOURGOGNE\grille com 08.13" dans
C'est une autre macro qui appelle la tienne, la coller au-dessus, séparément.
Copie le fichier xls dans le répertoire que tu dois traiter, ouvre-le et lance cette macro.
eric
j'ai donc ceci
Dim wb As Workbook
' traitement
Variables
Loop
Sub Variables()
' Variables Macro
Range("E3").Select
Range("E3").Select
Selection.Copy
.Delete
.IgnoreBlank = True
.InputTitle = ""
.ErrorTitle = ""
.InputMessage = ""
.ErrorMessage = ""
.ShowInput = True
.ShowError = True
.Pattern = xlNone
.TintAndShade = 0
.LeftHeader = "&D"
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.Draft = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 4
Range("A2").Select
ActiveWorkbook.Save
cela exécute normalement ma macro sur le fichier ouvert mais pas sur le reste du dossier.
Merci beaucoup pour votre aide
Il faut exécuter parcourirFichiers(), pas la tienne.
eric
je suis pas sur de saisir.
Mais merci de ton aide
Je ne peux pas expliquer autrement.
C'est ce que tu as demandé. C'est une macro qui ouvre successivement tous les fichiers xls, xlsx, xlsm du répertoire où elle est, et qui lance ta macro qui s'appliquera donc sur la feuille active puisque tu n'y as pas spécifié de feuille.
Par contre je viens de voir que ta macro se termine avec un ActiveWorkbook.Close. Il faut l'enlever puisque c'est géré par ma macro.
eric
