Calcul textbox
Je recherche la façon de calculer deux textbox
J'ai déjà un code qui fonctionne très bien mais je voudrais lui apporter une modification
Mon code.
Private Sub T14_AfterUpdate()
T14.Value = Format(T14.Value, "00.00 €")
Private Sub T16_AfterUpdate()
T16.Value = Format(T16.Value, "00.00 €")
Private Sub T18_AfterUpdate()
T18.Value = Format(T18.Value, "00.00 €")
Private Sub T34_AfterUpdate()
T34.Value = Format(T34.Value, "00.00 €")
Private Sub TextBox8_AfterUpdate()
TextBox8.Value = Format(TextBox8.Value, "00.00 €")
Function calc() As Double
calc = Val(T14) - Val(T16) - Val(T18) + Val(T34)
End Function
Private Sub T14_Change()
T19 = Format(calc, "# ##0.00 €")
TextBox8.Value = T14.Value + T34.Value
Private Sub T16_Change()
Private Sub T18_Change()
Private Sub T34_Change()
TextBox8.Value = Val(T14.Value) + Val(T34.Value)
Private Sub CheckBox16_Change()
If CheckBox16.Value = True Then
CheckBox17.Value = False
TTC = Val(Replace(TextBox8, ",", "."))
TVA = TTC / 1.196
TextBox6.Visible = False
Label280.Visible = False
TextBox5.Visible = True
Label9.Visible = True
TextBox7.Text = Format(TVA, "# ##0.00 €")
TextBox5.Text = Format(TTC - TVA, "# ##0.00 €")
Private Sub CheckBox17_Change()
If CheckBox17.Value = True Then
CheckBox16.Value = False
TVA = TTC / 1.055
TextBox5.Visible = False
Label9.Visible = False
TextBox6.Visible = True
Label280.Visible = True
TextBox6.Text = Format(TTC - TVA, "# ##0.00 €")
'Copie T19 vers TextBox4
Private Sub T19_Change()
TextBox4.Value = T19.Value
Private Sub TextBox8_Exit(ByVal Cancel As MSForms.ReturnBoolean)
TextBox8.Value = Format(Replace(TextBox8.Value, ".", ","), "#0.00 €")
Private Sub TextBox5_Change()
TextBox9.Value = TextBox5.Value + TextBox6.Value
Private Sub TextBox6_Change()
TextBox9.Value = Val(TextBox5.Value) + Val(TextBox6.Value)
End SubJe joint mon fichier avec mon explication
Je vous remercie d'avance
Max
Bonjour Banzai
Je te remercie Nickel
Bonne journée
Max
