Macro bug lors du passage de 2003 à 2010
Bonjour a tous et à toute!
Je suis récemment passé de excel 2003 à 2010. Je dispose d'une macro (pas de moi) qui me permettait de mettre en forme mes résultats. Je ne maitrise pas VB. Or depuis ce passage la macro bug à ce niveau:
'ActiveChart.Location Where:=xlLocationAsObject, Name:="LP " & LLp(Lp)
ActiveChart.Location Where:=xlLocationAsObject, Name:=LLp(Lp)
With ActiveChart
.HasTitle = True
.ChartTitle.Characters.Text = TitreG
.Axes(xlCategory, xlPrimary).HasTitle = False
.Axes(xlValue, xlPrimary).HasTitle = False
With ActiveChart
.HasAxis(xlCategory, xlPrimary) = True
.HasAxis(xlValue, xlPrimary) = True
ActiveChart.Axes(xlCategory, xlPrimary).CategoryType = xlAutomatic
With ActiveChart.Axes(xlCategory)
.HasMajorGridlines = False
.HasMinorGridlines = False
With ActiveChart.Axes(xlValue)
ActiveChart.ApplyDataLabels Type:=xlDataLabelsShowValue, LegendKey:=False
ActiveSheet.ChartObjects(1).Name = "Graphe LP"
ActiveSheet.Shapes("Graphe LP").ScaleWidth 1.5, msoFalse, msoScaleFromBottomRight
' ActiveSheet.Shapes("Graphe LP").ScaleHeight 0.72, msoFalse, msoScaleFromTopLeft
' ActiveSheet.Shapes("Graphe LP").ScaleHeight 1.15, msoFalse, msoScaleFromBottomRight
' ActiveSheet.Shapes("Graphe LP").ScaleWidth 1.84, msoFalse, msoScaleFromTopLeft
' ActiveSheet.Shapes("Graphe LP").IncrementLeft -190
ActiveSheet.Shapes("Graphe LP").ScaleWidth Larg, msoFalse, msoScaleFromTopLeft
' ActiveSheet.Shapes("Graphe LP").IncrementTop -3#
If Etude <> 6 Then
'ActiveSheet.Shapes("Graphe LP").ScaleHeight 1.234, msoFalse, msoScaleFromTopLeft
ActiveSheet.Shapes("Graphique 2").ScaleHeight 0.67, msoFalse, msoScaleFromTopLeft
ActiveSheet.Shapes("Graphique 2").ScaleHeight 1.22, msoFalse, msoScaleFromBottomRight
ActiveSheet.Shapes("Graphique 2").ScaleHeight 1.01, msoFalse, msoScaleFromBottomRight
ActiveSheet.Shapes("Graphique 2").ScaleHeight 1.01, msoFalse, msoScaleFromTopLeft
'ActiveSheet.Shapes("Graphe LP").ScaleHeight 1.17, msoFalse, msoScaleFromTopLeft
End IfJe sais qu'il n'est pas facil de repondre sans voir la totalité du code mais celui-ci est confidentiel
Merci de votre aide, dispo si besoin bonne journée!!
Alex
Apres recherche je crois comprendre que :
ActiveChart.Location Where:=xlLocationAsObject, Name:=LLp(Lp)Me permet de donner l'emplacement de mon graphique et Name qui ici est "salades" correspond a la feuille ou doit etre mon graphe...
Je ne vois donc pas pk excel 2010 ne fonctionne pas à ce niveau
Sans le fichier pas facile, en plus les graphiques c'est quoi ?
Pour essayé de faire avancer le schmilblick
Ton graphique est bien sélectionné ?
Quel est le message d'erreur ?
La feuille existe bien ?
Bonjour Banzai,
Le graphique est un histogramme classique.
Comment selectionner mon graphique?
Le message d'erreur apres debodage est l'identificateur sous le curseur n'est pas reconnu.
La feuille va avoir un nom différent selon le fichier elle est correct ici à l'aide de la méthode du pas a pas je peux voir que LLp(Lp)
est salades nom de ma feuille.
Je test actuellement une autre solution qui est:
With ActiveChart
.Name = LLp(Lp)
.HasTitle = True
End WithPas concluant débodage au niveau du HasTitle
Merci pour votre aide
PS: Je vous joins la partie au dessus du premier code qui me permet de construire le graphique:
Sheets(LLp(Lp)).Select
' Sheets("LP " & LLp(Lp)).Select
If Etude = 6 Then
'pour libelle graphique
If NbGroup = 7 Then
Range("B27:D27").Select
Selection.UnMerge
With Selection
.HorizontalAlignment = xlCenterAcrossSelection
.VerticalAlignment = xlCenter
Range("E27:G27").Select
Selection.UnMerge
With Selection
If NbGroup = 5 Then
Range("B27:C27").Select
Selection.UnMerge
With Selection
Range("D27:E27").Select
Selection.UnMerge
With Selection
If ok2 > 0 Then
'Set Abscisse = Range(Cells(ok2 - 1, 2), Cells(ok2 - 1, (NbGroup - 1) / 2 + 1))
'Set abscisse2 = Range(Cells(ok2 - 1, (NbGroup - 1) / 2 + 2), Cells(ok2 - 1, NbGroup))
'Set Titre = Range(Cells(28, 2), Cells(28, (NbGroup - 1) / 2 + 1))
TitreG = Cells(ok2 - 1, 1) & " DE LA LIGNE '" & Trim(Cells(28, 1)) & "'"
Set Abscisse = Range(Cells(ok1 - 1, 2), Cells(ok1 - 1, (NbGroup - 1) / 2 + 1))
Set abscisse2 = Range(Cells(ok1 - 1, (NbGroup - 1) / 2 + 2), Cells(ok1 - 1, NbGroup))
TitreG = Cells(ok1 - 1, 1) & " DE LA LIGNE '" & Trim(Cells(28, 1)) & "'"
'If LargCol = 8.57 Then Conv = 0.164
'If LargCol = 8 Then Conv = 0.153
'Larg = 1.01 + (NbGroup - 1) * Conv
Larg = 0.35 + (NbGroup - 1) * Conv
If ok2 > 0 Then
'Range(Cells(ok2 - 1, 1), Cells(ok2 - 1, (NbGroup - 1) / 2 + 1)).Select
Range(Cells(ok1 - 1, 1), Cells(ok1 - 1, (NbGroup - 1) / 2 + 1)).Select
'Charts.Add
'ActiveChart.ChartType = xlColumnClustered
'ActiveChart.SeriesCollection(1).Values = Abscisse
'ActiveChart.SeriesCollection(1).XValues = Titre
'ActiveChart.SeriesCollection.NewSeries
'ActiveChart.SeriesCollection(2).Values = abscisse2
'ActiveChart.SeriesCollection(2).XValues = Titre
i = 29
OK = 0
Do While Cells(i, 1) <> "" And OK = 0
If Ajust = 1 Then
If (InStr(Trim(Cells(i, 1)), "VMH VALEUR AJUST") = 1 Or _
InStr(Trim(Cells(i, 1)), "VMM VALEUR AJUST") = 1) Then
OK = i
If Ajust = 0 Then
If (InStr(Trim(Cells(i, 1)), "VMH VALEUR") = 1 Or _
InStr(Trim(Cells(i, 1)), "VMM VALEUR") = 1) Then
OK = i
i = i + 1
Loop
Set Abscisse = Range(Cells(OK, 2), Cells(OK, NbGroup))
Set Titre = Range(Cells(28, 2), Cells(28, NbGroup))
'TitreG = "VMH VALEUR AJUSTEES DE LA LIGNE '" & Trim(Cells(28, 1)) & "'"
TitreG = Cells(OK, 1) & " DE LA LIGNE '" & Trim(Cells(28, 1)) & "'"
'If LargCol = 10 Then Conv = 0.19
'If Largcol = 8 Then Conv = 0.17
'larg = 1.01 + (NbGroup - 1) * Conv
Larg = 0.3 + (NbGroup - 1) * Conv
Range(Cells(OK, 1), Cells(OK, NbGroup)).Select
Charts.Add
End IfJe viens de trouver l'erreur: la sécurité de mon excel
Bonsoir
Je me suis mal exprimé
Banzai64 a écrit :en plus les graphiques c'est quoi ?
Voulait dire que je n'y connais pratiquement rien dans les graphiques
J'ai essayé de débloquer la situation en posant des questions
Et une nouvelle question arrive
Alex64140 a écrit :l'identificateur sous le curseur n'est pas reconnu
Sur quelle ligne ?
Donc d'après ce que je comprends la 1ère ligne qui buggait venait du fait que ta page était protégée ?
Juste pour info j'ai essayé un truc comme ça (pour voir)
Sub bb()
Dim TitreG As String
TitreG = "Banzai64"
Charts.Add After:=Worksheets("Feuil1")
With ActiveChart
.Name = "hello" 'LLp(Lp)
.HasTitle = True
.Location Where:=xlLocationAsObject, Name:="feuil2"
End SubPas de plantage après avoir ajouté la partie surlignée
Mais sans ton fichier, ou du moins 1 copie, avec ta macro qui plante, je n'irai pas plus loin
Je suis à la limite max avec ce que connais des graphiques
Merci pour votre aide la macro est réparrer pour les pages que l'on désirait.
A titre perso et pour achever completement cette macro il me manque une derniere page qui est peu utilisé par ma boite mes dont je voudrais venir a bout: je vous joins le code ci dessous:
Sheets("SYNTHESE").Select
ActiveSheet.Shapes("Drop Down 3").Select
Selection.OnAction = Macro & "!MarcheCig_QuandChangement"
With Selection
.ListFillRange = "'Vues 1'!$A$1:$A$" & i
.LinkedCell = "'Vues 1'!$D$1"
.DropDownLines = i
.Display3DShading = False
ActiveSheet.Shapes("Drop Down 4").Select
With Selection
.ListFillRange = "'Vues 2'!$A$1:$A$" & j
.LinkedCell = "'Vues 2'!$D$1"
.DropDownLines = j
End Withcette partie fonctionne parfaitement sur les ordis équipés en excel 2003 mais pas ceux de 2010...
Il faut apparament recuperer le nom de mes shapes:
Worksheets("EDT GENERAL").Shapes(Worksheets("EDT GENERAL").Shapes.Count).Name
ActiveSheet.Shapes(X).Select Si quelqu'un maitrise ce genre de manip
En tout cas merci de ton aide banzaiii et bonne apres midi a tous
