Probleme Impression
J'ai un probleme de compilation, dit de Propriété sur la macro suivante :
Sub Impr_EMR()
Range ("BA200:BC303")
ActiveSheet.PageSetup.PrintArea = "$BA$200:$BC$303"
Application.PrintCommunication = False
With ActiveSheet.PageSetup
.PrintTitleRows = ""
.PrintTitleColumns = ""
Application.PrintCommunication = True
.LeftHeader = ""
.CenterHeader = ""
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.LeftMargin = Application.InchesToPoints(0.708661417322835)
.RightMargin = Application.InchesToPoints(0.708661417322835)
.TopMargin = Application.InchesToPoints(0.748031496062992)
.BottomMargin = Application.InchesToPoints(0.748031496062992)
.HeaderMargin = Application.InchesToPoints(0.31496062992126)
.FooterMargin = Application.InchesToPoints(0.31496062992126)
.PrintHeadings = False
.PrintGridlines = False
.PrintComments = xlPrintNoComments
.PrintQuality = 600
.CenterHorizontally = False
.CenterVertically = False
.Orientation = xlPortrait
.Draft = False
.FirstPageNumber = xlAutomatic
.Order = xlDownThenOver
.BlackAndWhite = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 1
.PrintErrors = xlPrintErrorsDisplayed
.OddAndEvenPagesHeaderFooter = False
.DifferentFirstPageHeaderFooter = False
.ScaleWithDocHeaderFooter = True
.AlignMarginsHeaderFooter = True
.EvenPage.LeftHeader.Text = ""
.EvenPage.CenterHeader.Text = ""
.EvenPage.RightHeader.Text = ""
.EvenPage.LeftFooter.Text = ""
.EvenPage.CenterFooter.Text = ""
.EvenPage.RightFooter.Text = ""
.FirstPage.LeftHeader.Text = ""
.FirstPage.CenterHeader.Text = ""
.FirstPage.RightHeader.Text = ""
.FirstPage.LeftFooter.Text = ""
.FirstPage.CenterFooter.Text = ""
.FirstPage.RightFooter.Text = ""
Selection.PrintOut Copies:=1
Quelqu'un a une idée ???
Supprimer toute cette partie
Application.PrintCommunication = TrueA+
Sa m'imprime juste un ptit carré grisé ^^
Re...
Il faut faire plus attention !
Dans ton message il y a( à la deuxième ligne de ta macro) :
C'est ce qui provoque une erreur de compilation.
Cette ligne est à supprimer.
Ensuite tu as :
Puis à nouveau :
...Seule cette dernière partie (et la suite et fin) doit subsister.
Ok ?
j'ai suivi t conseils o pieds de la lettre mais pas moyen sa m'imprime une cellule grisé.
Sub Impr_EMR()
.LeftHeader = ""
.CenterHeader = ""
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.PrintQuality = 600
.Draft = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 1
Dit moi si c bien la macro que tu pensai.
Merci encore
Et si tu supprimes :
