Sauver et quitter en VBS sans boite de dial
A
Bonjour, j'ai fait le code suivant :
Sub Macro1()
' Macro1 Macro
Set Base = ActiveWorkbook
Workingdir = "F:\Bibliothèque\Desktop\Nouveau dossier (3)"
Workbooks.OpenText Filename:=Range("A1"), Origin:=xlMSDOS, _
StartRow:=1, DataType:=xlFixedWidth, FieldInfo:=Array(Array(0, 1), Array(5, _
1), Array(15, 1), Array(22, 1), Array(31, 1), Array(57, 1), Array(66, 1), Array(72, 1)), _
TrailingMinusNumbers:=True
Set Seco = ActiveWorkbook
Base.Activate
Workbooks.OpenText Filename:=Range("B1"), Origin:=xlMSDOS, StartRow:=1, DataType:=xlDelimited, TextQualifier:=xlDoubleQuote _
, ConsecutiveDelimiter:=False, Tab:=True, Semicolon:=False, Comma:= _
False, Space:=False, Other:=False, FieldInfo:=Array(Array(1, 1), Array(2, 1) _
, Array(3, 1), Array(4, 1), Array(5, 1), Array(6, 1)), TrailingMinusNumbers:=True
Set Tert = ActiveWorkbook
Range("K13").Select
ActiveWindow.SmallScroll Down:=-15
Range("B4").Select
ActiveWindow.WindowState = xlNormal
With ActiveWindow
.Top = 16.75
.Left = 499
Range("B5:E5").Select
Selection.NumberFormat = "0.00"
Range("A5").Select
ActiveCell.FormulaR1C1 = "1"
Range("B5").Select
Seco.Activate
Range("D4").Select
If Range("D4").Value Like "aN" Then
Range("H2").Select
Selection.Copy
ActiveWindow.WindowState = xlMinimized
Range("B5,B5").Select
ActiveSheet.Paste
Base.Activate
Seco.Activate
Range("B6").Select
If Not Range("A6").Value Like "kx=" Then
Range("B7").Select
ElseIf Not Range("A7").Value Like "kx=" Then
Range("B8").Select
ElseIf Not Range("A8").Value Like "kx=" Then
Range("B9").Select
ElseIf Not Range("A9").Value Like "kx=" Then
Range("B10").Select
ElseIf Not Range("A10").Value Like "kx=" Then
Range("B11").Select
ElseIf Not Range("A11").Value Like "kx=" Then
Range("B12").Select
ElseIf Not Range("A12").Value Like "kx=" Then
Range("B13").Select
ElseIf Not Range("A13").Value Like "kx=" Then
Range("B14").Select
ElseIf Not Range("A14").Value Like "kx=" Then
Range("B15").Select
ElseIf Not Range("A15").Value Like "kx=" Then
Range("B16").Select
ElseIf Not Range("A16").Value Like "kx=" Then
Range("B17").Select
ElseIf Not Range("A18").Value Like "kx=" Then
Range("B19").Select
ElseIf Not Range("A19").Value Like "kx=" Then
Range("B20").Select
ElseIf Not Range("A20").Value Like "kx=" Then
Range("B21").Select
ElseIf Not Range("A21").Value Like "kx=" Then
Range("B22").Select
ElseIf Not Range("A22").Value Like "kx=" Then
Range("B23").Select
ElseIf Not Range("A23").Value Like "kx=" Then
Range("B24").Select
ElseIf Not Range("A24").Value Like "kx=" Then
Range("B25").Select
ElseIf Not Range("A25").Value Like "kx=" Then
Range("B26").Select
ElseIf Not Range("A26").Value Like "kx=" Then
Range("B27").Select
ElseIf Not Range("A27").Value Like "kx=" Then
Range("B28").Select
ElseIf Not Range("A28").Value Like "kx=" Then
Range("B29").Select
ElseIf Not Range("A29").Value Like "kx=" Then
Range("B30").Select
ElseIf Not Range("A30").Value Like "kx=" Then
Range("B31").Select
ElseIf Not Range("A31").Value Like "kx=" Then
Range("B32").Select
ElseIf Not Range("A32").Value Like "kx=" Then
Range("B33").Select
ElseIf Not Range("A33").Value Like "kx=" Then
Range("B34").Select
ElseIf Not Range("A34").Value Like "kx=" Then
Range("B35").Select
ElseIf Not Range("A35").Value Like "kx=" Then
Range("B36").Select
ElseIf Not Range("A36").Value Like "kx=" Then
Range("B37").Select
Selection.Copy
With ActiveWindow
.Top = 76
.Left = -629.75
Base.Activate
Tert.Activate
Range("D5").Select
ActiveSheet.Paste
Base.Activate
Tert.Activate
With ActiveWindow
.Top = -4.25
.Left = 41.5
Range("B6").Select
If Not Range("A6").Value Like "ky=" Then
Range("B7").Select
ElseIf Not Range("A7").Value Like "ky=" Then
Range("B8").Select
ElseIf Not Range("A8").Value Like "ky=" Then
Range("B9").Select
ElseIf Not Range("A9").Value Like "ky=" Then
Range("B10").Select
ElseIf Not Range("A10").Value Like "ky=" Then
Range("B11").Select
ElseIf Not Range("A11").Value Like "ky=" Then
Range("B12").Select
ElseIf Not Range("A12").Value Like "ky=" Then
Range("B13").Select
ElseIf Not Range("A13").Value Like "ky=" Then
Range("B14").Select
ElseIf Not Range("A14").Value Like "ky=" Then
Range("B15").Select
ElseIf Not Range("A15").Value Like "ky=" Then
Range("B16").Select
ElseIf Not Range("A16").Value Like "ky=" Then
Range("B17").Select
ElseIf Not Range("A18").Value Like "ky=" Then
Range("B19").Select
ElseIf Not Range("A19").Value Like "ky=" Then
Range("B20").Select
ElseIf Not Range("A20").Value Like "ky=" Then
Range("B21").Select
ElseIf Not Range("A21").Value Like "ky=" Then
Range("B22").Select
ElseIf Not Range("A22").Value Like "ky=" Then
Range("B23").Select
ElseIf Not Range("A23").Value Like "ky=" Then
Range("B24").Select
ElseIf Not Range("A24").Value Like "ky=" Then
Range("B25").Select
ElseIf Not Range("A25").Value Like "ky=" Then
Range("B26").Select
ElseIf Not Range("A26").Value Like "ky=" Then
Range("B27").Select
ElseIf Not Range("A27").Value Like "ky=" Then
Range("B28").Select
ElseIf Not Range("A28").Value Like "ky=" Then
Range("B29").Select
ElseIf Not Range("A29").Value Like "ky=" Then
Range("B30").Select
ElseIf Not Range("A30").Value Like "ky=" Then
Range("B31").Select
ElseIf Not Range("A31").Value Like "ky=" Then
Range("B32").Select
ElseIf Not Range("A32").Value Like "ky=" Then
Range("B33").Select
ElseIf Not Range("A33").Value Like "ky=" Then
Range("B34").Select
ElseIf Not Range("A34").Value Like "ky=" Then
Range("B35").Select
ElseIf Not Range("A35").Value Like "ky=" Then
Range("B36").Select
ElseIf Not Range("A36").Value Like "ky=" Then
Range("B37").Select
Selection.Copy
With ActiveWindow
.Top = 311.5
.Left = -349.25
Base.Activate
Tert.Activate
Range("E5").Select
ActiveSheet.Paste
Range("F5").Select
ActiveCell.FormulaR1C1 = "0"
Range("E5").Activate
With ActiveWindow
.Top = 9.25
.Left = 233.5
Range("G10").Select
With ActiveWindow
.Top = 16
.Left = -222.5
Seco.Activate
ActiveWindow.Close ([SaveChanges=True])
Application.Wait (Now + TimeValue("0:00:2"))
Tert.Activate
Range("A1:B1").Select
Selection.Delete Shift:=xlUp
Range("G9").Select
End SubEt comme vous le voyez a la fin j'ai pris soin de mettre ActiveWindow.Close ([SaveChanges=True])
mais malgré cela il me demande toujours si je veux enregistrer les modifications ... que faire?
Bonjour AquHydro,
Pour éviter qu'il te pose des questions :
Application.DisplayAlerts=False
Application.DisplayAlerts=TrueSurtout pense bien à le réactiver!
Et ton titre n'est pas très explicite...
A
Désolé pour le titre j'avais d'autres question à posé auquelles j'ai répond tout seul !
Pour merci pour la réponse
