Affichage de Mail avant envoi
J'aimerai modifier le code suivant:
'Set up the objects required for Automation into lotus notes
Dim Maildb As Object 'The mail database
Dim UserName As String 'The current users notes name
Dim MailDbName As String 'THe current users notes mail database name
Dim MailDoc As Object 'The mail document itself
Dim AttachME As Object 'The attachment richtextfile object
Dim Session As Object 'The notes session
Dim EmbedObj As Object 'The embedded object (Attachment)
If UserFormEMail.ListBox2.ListCount = 0 Then MsgBox "No Hay Proyectos Seleccionados Para Mensaje"
If UserFormEMail.ListBox2.ListCount = 0 Then Exit Sub
'Start a session to notes
Set Session = CreateObject("Notes.NotesSession")
'Get the sessions username and then calculate the mail file name
'You may or may not need this as for MailDBname with some systems you
'can pass an empty string
UserName = Session.UserName
MailDbName = Left$(UserName, 1) & Right$(UserName, (Len(UserName) - InStr(1, UserName, " "))) & ".nsf"
'Open the mail database in notes
Set Maildb = Session.GETDATABASE("", MailDbName)
If Maildb.IsOpen = True Then
'Already open for mail
Maildb.openmail
'Set up the new mail document
Set MailDoc = Maildb.CREATEDOCUMENT
MailDoc.Form = "Memo"
MailDoc.Sendto = "CST_BAntoniol@xxxx.com" 'UserFormEMail.TextBox9.Value
MailDoc.CopyTo = ""
MailDoc.Subject = "essaie d'envoi adresse differentes"
' Construction du corps du message
Set objNotesField = MailDoc.CreateRichTextItem("Body")
With objNotesField
.AppendText "Buenos Dias,"
.AddNewline 2
.AppendText "Usted podrìa enviarme el Order Entry Form del (de los) proyecto(s) sigienete(s):"
.AddNewline 2
For i = 0 To UserFormEMail.ListBox2.ListCount - 1
.AppendText UserFormEMail.ListBox2.List(i) & " --- " & UserFormEMail.ListBox3.List(i)
.AddNewline 2
.AddNewline 2
.AppendText "Un saludo Cordial"
.AddNewline 1
.AppendText "Bruno Antoniol"
.AddNewline 3
MailDoc.SaveMessageOnSend = True
'Set up the embedded object and attachment and attach it
'Send the document
MailDoc.PostedDate = Now() 'Gets the mail to appear in the sent items folder
MailDoc.Send (False)
'Clean Up
Set Maildb = Nothing
Set MailDoc = Nothing
Set AttachME = Nothing
Set Session = Nothing
Set EmbedObj = Nothing
de telle sorte que le mail ne soit pas envoyé directement mais qu'il s'affiche dans Lotus Note (V6.5) pour ainsi pouvoir le modifier si besoin est.
Je cherche depuis bien 5h mais je n'y arrive pas!
Help!
Bruno
Autre variante pour résoudre ce problème:
Voila j'ai un autre code qui lui ouvre bien le message dans Lotus note avant de l'envoyer.
Cette solution me conviendrai excepté le corps du message que je n'arrive pas à mettre sous forme:
Bonjour Monsieur *TextBox1(Prénom)* *ComboBox1(Nom)*,
Je vous écrit concernant les projets: *ListBox1(Nº de projet)*
Afin que vous apportiez les précisions suivante: *(if CheckBox1=true then CheckBox1.Caption)* avant la date suivante: *TextBox2 (date)*
Meilleures Salutations. Bruno
Bientot 8 heure a chercher!!
Je commence à m'arracher les cheveux! Merci de votre aide!
Bruno
Voici le code que j'ai
'---------- API -----------
'pour faire passer au premier plan
Private Declare Function SetForegroundWindow Lib "user32" (ByVal hWnd As Long) As Long
'pour ouvrir la fenêtre
Private Declare Function ShowWindow Lib "user32" (ByVal hWnd As Long, _
                    ByVal nCmdShow As Long) As Long
'pour vérifier si Lotus est ouvert
Private Declare Function FindWindow Lib "user32" Alias _
    "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Dim sSrvr As String 'Le serveur de mail de l'utilisateur courant
Dim MailDbName As String 'Le nom de la base mail de l'utilisateur courant
Dim UserName As String 'Le nom de l'utilisateur courant
Dim retVal As Variant 'La valeur de retour de la fonction
'---------------- fonction ouverture de session Notes -----------
Function CreateNotesSession() As Boolean
    Const notesclass$ = "NOTES"
    Const SW_SHOWMAXIMIZED = 3 'plein ecran
    Const SW_SHOWMMINIZED = 2 'reduire
    Const SW_SHOWWINDOW = 1 'fenetre
    Const SW_SHOW = 5
    Dim Lotus_Session As Object
    Dim rc&
    Dim lotusWindow&
'    lotusWindow = FindWindow(notesclass, vbNullString)
'    sSrvr = Lotus_Session.GETENVIRONMENTSTRING("MailServer", True)
'    MailDbName = Lotus_Session.GETENVIRONMENTSTRING("MailFile", True)
'    UserName = Lotus_Session.UserName
'    DoEvents
    'Ouverture de Lotus Notes
    'Mettre votre chemin d'accès pour notes.exe et notes.ini'
     'retVal = Shell("C:\Program Files\lotus\notes\notes.exe =C:\Program Files\lotus\notes\notes.ini", vbMaximizedFocus)
    'verifier que Lotus est bien ouvert (recupere le handle)
    If lotusWindow <> 0 Then
        rc = ShowWindow(lotusWindow, SW_SHOW)
        rc = SetForegroundWindow(lotusWindow)
        CreateNotesSession = True
         CreateNotesSession = False
End Function
 Const EMBED_ATTACHMENT As Integer = 1454
    Const EMBED_OBJECT As Integer = 1453
    Const EMBED_OBJECTLINK As Integer = 1452
    Dim s As Object ' use back end classes to obtain mail database name
    Dim db As Object '
    Dim doc As Object ' front end document
    Dim beDoc As Object ' back end document
    Dim workspace As Object ' use front end classes to display to user
    Dim bodypart As Object '
    Dim bodyAtt As Object '
    Dim lbsession As Boolean
    lbsession = CreateNotesSession
    If lbsession Then
        'cree la session Lotus Notes
        Set s = CreateObject("Notes.Notessession")
        'se connecte a sa database
        Set db = s.getDatabase(sSrvr, MailDbName)
        If db.IsOpen = True Then
            'database deja ouvert
            Call db.Openmail
        'cree un document memo
        Set beDoc = db.CreateDocument
        beDoc.Form = "Memo"
         'construction du mail
        Set bodypart = beDoc.CreateRichTextItem("Body")
        'beDoc.From = "Moi" 'inutile
        beDoc.SendTo = UserFormEMail.TextBox9.Value
        beDoc.CopyTo = CCToAdr
        beDoc.BlindCopyTo = BCCToAdr
        beDoc.Subject = UserFormEMail.TextBox10.Value & " Pendiente"
With bodypart
.AddNewline 2
.AddNewline 2
.AddNewline 2
.AddNewline 2
.AddNewline 1
.AddNewline 3
        'Remarque s'il y a des destinataires multiples, il suffit de mettre un tableau
        'd'e-mail dans SendTo (CopyTo,BlindCopyTo)
        'exemple :
        'Dim recip(25) as variant
        'recip(0) = "emailaddress1"
        'recip(1) = "emailaddress2" e.t.c
        'beDoc.sendto = recip
        ' documents joint 1
        If Len(Attach1) > 0 Then
            If Len(dir(Attach1)) > 0 Then
               Set bodyAtt = bodypart.EmbedObject(EMBED_ATTACHMENT, "", Attach1, dir(Attach1))
        ' documents joint 2
        If Len(Attach2) > 0 Then
            If Len(dir(Attach2)) > 0 Then
                Call bodyAtt.EmbedObject(EMBED_ATTACHMENT, "", Attach2, dir(Attach2))
        'Affichage du mail dans Lotus Notes
        Set workspace = CreateObject("Notes.NotesUIWorkspace")
        Call workspace.EditDocument(True, beDoc).FieldSetText("Body", "CORPS DE MESSAGE")
        Set s = Nothing
            MsgBox "Votre Lotus Notes est fermé !"
Bonjour le Forum,
Petite relance car je suis dans une impasse
N'importe quelles idées sont les bienvenues! Je suis prêt á tout tester!
C'est surement une syntaxe que je ne connais pas!
C'est bon voila le code que j'utilise (2 eme code):
   Const SW_SHOW = 5
    Dim rc&
    Dim lotusWindow&
'    DoEvents
End Function
   Dim db As Object '
    If lbsession Then
            Call db.Openmail
        beDoc.Form = "Memo"
With bodypart
.AddNewline 2
.AddNewline 2
.AddNewline 2
.AddNewline 2
.AddNewline 1
.AddNewline 3
       'exemple :
       ' documents joint 1
        ' documents joint 2
Textei = Textei & ListBox2.List(i) & " --- " & ListBox3.List(i) & Chr(10) & Chr(10)
        Call workspace.EditDocument(True, beDoc).FieldSetText("Body", "Bonjour Monsieur " & TextBox1 & " " & ComboBox1 & "," & Chr(10) & Chr(10) & _
"Je vous écrit concernant les projets: " & Listei & Chr(10) & Chr(10) & _
"Afin que vous apportiez les précisions suivantes: " & CheckBox1.Caption & _
" avant la date suivante: " & TextBox2 & Chr(10) & Chr(10) & Chr(10) & " Meilleures Salutations.Bruno")
        Set s = Nothing
Merci, Bruno
j'ai utilisé votre dernier code qui marche parfaitement bien (après 20000 recherches sur Internet, le votre correspond vraiment à mon problème), mis à part pour les pièces jointes.
Je n'arrive pas à intégrer les pièces jointes au mail créé avec cette macro.
Pouvez vous m'expliquer comment vous déclarez les éléments "attach1" et "attach2".... car je n'y arrive pas...
Merci pour votre aide
      ' documents joint 1
        ' documents joint 2
Je tente d'utiliser votre code qui semble être vraiment intéressant seulement il bug sur la toute première partie.
je n'arrive donc pas à lûtiliser.
Des pistes pour moi ?
Merci !
Thomas
Rechercher des sujets similaires à "affichage mail envoi"
