Run-time error '-2147352571 (80020005)
Bonjour le forum!
Voici mon probleme:
Losque je lance ce code qui permet de choisir mon imprimante et d'imprimer mon Userform:
Const HWND_BROADCAST = &HFFFF
Const WM_WININICHANGE = &H1A
Private Declare Function GetPrivateProfileString Lib "Kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
Private Declare Function GetWindowsDirectory Lib "Kernel32" Alias "GetWindowsDirectoryA" (ByVal lpBuffer As String, ByVal nSize As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Integer, ByVal lParam As Any) As Long
Private Declare Function WritePrivateProfileString Lib "Kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long
Dim Chemin As String
Dim NC As Long
Dim Ret As String
Imprdef = ComboBox1
ProcédureImPrimanteParDéfaut (Imprdef)
Me.PrintForm
'ComboBox1.RowSource = "listeImpr"
ComboBox1.AddItem "PDFCreator"
ComboBox1.AddItem "\\adrfp1\ADRPR_CTS3"
ComboBox1.AddItem "ADRPR_CTS3"
'ListBox1 = userformverficacion2.ListBox1
Private Sub ProcédureImPrimanteParDéfaut(Imprdef)
 'http://www.excelabo.net/trucs/imprimante_defaut
   ChangeImprimanteParDéfaut (Imprdef)
  Sub ChangeImprimanteParDéfaut(Nom As String)
 Chemin = String(260, 0)
 Chemin = Left$(Chemin, GetWindowsDirectory(Chemin, Len(Chemin))) + "\win.ini"
 Ret = String(255, 0)
 NC = GetPrivateProfileString("Devices", Nom, "", Ret, 255, Chemin)
 Ret = Left(Ret, NC)
 WritePrivateProfileString "windows", "device", Nom & "," & Ret, Chemin
 SendMessage HWND_BROADCAST, WM_WININICHANGE, 0, "windows"
La fonction est bien réalisée. En revanche, apres mon impression, et après avoir fermé l'UserForm imprimé, aucune de mes macros ne fonctionnent:
si je clique sur un bouton qui lance n'importe quelle Userform, un message d'erreur apparait:
Run-time error '-2147352571 (80020005)':
Could not set the Value property. type mismach.
Si je clique sur debug il me surligne: UserForm.Show
Je n'ai trouvé d'autre solution que de fermer mon fichier et de le rouvrir: Ce qui est tres contraignant si je dois le faire après chaque impression.
J'ai peut être une idée: Existe t'il un code pour remettre les parametres de base de excel par defaut que j'executerai à la fermeture de mon UserForm ou faut il que je modifie mon code?
Merci d'avance.
Cdt Bruno
En suivant les etapes de débug utilisant F8, je me suis apercu qu'il n'y avait pas de probleme pour l'ouverture des UserForm. En faite j'ai un probleme dans 2 boucles différentes.
Ce que je ne comprends pas, c'est que ces boucles marchent bien avant de lancer une impression.
voici les 2 boucles qui possent probleme:
Boucle1:
  TextBox1 = Format(Range("B3"), "dd/mm/yyyy")
  TextBox2 = Format(Range("C3"), "dd/mm/yyyy")
   'TextBox1 = 1
  ' TextBox2 = 2
  'TextBox1 = Range("B3")
 ' TextBox2 = Range("C3")
'Charger liste deroulante
Dim J As Long
Dim Ws As Worksheet
ComboBox1.Clear
If TextBox1.Text = "" Or TextBox2.Text = "" Then Exit Sub
  Set Ws = Sheets("OEP CONTROL")
  With UserformVerificacion.ComboBox1
    .ColumnCount = 2
    .ColumnWidths = "-1;0"
    For J = Ws.Range("D" & Rows.Count).End(xlUp).Row To 11 Step -1
    If Ws.Range("A" & J).Value >= CDate(TextBox1.Text) And Ws.Range("A" & J).Value <= CDate(TextBox2.Text) Then
            If Ws.Range("D" & J) <> "" Then
          .AddItem Ws.Range("D" & J)
          .List(.ListCount - 1, 1) = J
    Next J
Probleme avec: .AddItem Ws.Range("D" & J)
O boucle 2=
TextBox3 = Format(Date, "dd/mm/yyyy")
Dim i As Long
Dim Sh As Worksheet
Dim Chk As MSForms.Control
Dim Bol As Boolean
Dim iTag As Byte
Dim str() As String
Dim strFiltre() As String
Set Sh = ThisWorkbook.Worksheets("OEP CONTROL")
'Vide les listBox
ListBox1.Clear
ListBox2.Clear
ListBox3.Clear
ListBox4.Clear
'Test si saisie des dates
'Boucle sur les lignes de données (de la ligne 11 à la dernière ligne utilisée)
For i = 11 To Sh.Range("A" & Sh.Rows.Count).End(xlUp).Row
'Test le bornage de date
If Sh.Range("A" & i).Value >= CDate(TextBox1.Text) And Sh.Range("A" & i).Value <= CDate(TextBox2.Text) Then
'Boucle sur les Checkboxs
For Each Chk In Me.Controls
If TypeOf Chk Is MSForms.CheckBox Then
Bol = False
If Chk.Value = True And Chk.Tag <> "" Then
str = Split(Chk.Tag, "/")
strFiltre = Split(str(1), "-")
For iTag = 0 To UBound(strFiltre)
If UCase(Sh.Range(str(0) & i).Value) = UCase(strFiltre(iTag)) And Bol = False Then
Bol = True
GoTo Trouve
Next iTag
Trouve:
'Ajoute la référence si ok
If Bol = True Then ListBox1.AddItem Sh.Range("D" & i).Value
If Bol = True Then ListBox2.AddItem Sh.Range("B" & i).Value
If Bol = True Then ListBox4.AddItem Sh.Range("K" & i).Value
Suivant:
"21
Probleme avec la boucle à la 6ème iteration
J'ai tournè le probleme dans tous les sens en ne trouve rien de concret.
Une idée?? Bruno
C'est bon j'ai trouvé une solution:
Metre des
.Value
apres les
.Additem
Merci pour votre aide.
Bruno
Rechercher des sujets similaires à "run time error 2147352571 80020005"
