Regrouper 2 macros en 1 seule
Bonjour le forum,
J'aimerais si c'est possible réunir ces deux macros en une seule : le 1er clic pour mettre Congés et le 2ème clic pour remettre la mise en forme, les deux codes (codes réalisés avec l'enregistreur) ci-dessous :
Sub Conges()
Range("B10:G10").Select
With Selection
.VerticalAlignment = xlCenter
.WrapText = True
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
Selection.Merge
Selection.ClearContents
ActiveCell.FormulaR1C1 = "C o n g é s"
With ActiveCell.Characters(Start:=1, Length:=11).Font
.Name = "Arial"
.FontStyle = "Gras"
.Size = 48
.Strikethrough = False
.Superscript = False
.Subscript = False
.OutlineFont = False
.Shadow = False
.Underline = xlUnderlineStyleNone
.ColorIndex = xlAutomatic
.TintAndShade = 0
.ThemeFont = xlThemeFontNone
Range("B10").Select
End SubSub Reinitialiser()
With Selection
.HorizontalAlignment = xlGeneral
.WrapText = True
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = True
Selection.UnMerge
With Selection.Font
.Name = "Arial"
.Size = 14
.Subscript = False
.Shadow = False
.TintAndShade = 0
With Selection
.WrapText = True
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = False
Selection.Borders(xlDiagonalDown).LineStyle = xlNone
Selection.Borders(xlDiagonalUp).LineStyle = xlNone
With Selection.Borders(xlEdgeLeft)
.LineStyle = xlContinuous
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeTop)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeBottom)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeRight)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlInsideVertical)
.TintAndShade = 0
.Weight = xlThin
Selection.Borders(xlInsideHorizontal).LineStyle = xlNone
Selection.ColumnWidth = 16.67
Selection.Font.Bold = True
Range("B10").Select
End SubJe vous joins un fichier pour que celà soit plus explicite.
D'avance merci pour votre aide
A mon avis, il faut remplacer tes deux boutons par un seul, mais de type "ToggleButton" (bouton qui peut rester enfoncé) donc le clic appelle successivement les deux macros. Cela ne me semble pas utile de n'avoir qu'une seule macro, mais c'est possible, il suffit de remplacer le call de la macro par son contenu
Voici un exemple de ce que tu peux faire avec un contrôle de type ToggleButton :
Private Sub ToggleButton1_Click()
Application.ScreenUpdating = False ' Permet de figer l'écran et du même coup accélère l'exécution du code
If ToggleButton1.Value = True Then
Call Conges
ToggleButton1.Caption = "Réinialiser" ' Facultatif
Call Reinitialiser
ToggleButton1.Caption = "Congés" ' Facultatif
Benead
Bonjour Libellule 85 le forum
tu as décidé de regrouper toutes tes macros !!!!!!!!!!!!!!!!!!!!
a+
Papou
Bonjour Benead, re Paritec,
@ Benead : merci pour ta réponse, mais comment lancer cette macro à partir du Ruban ?
@ Paritec : En quelque sorte, car ces macros sont lancées à partir d'un ruban personnalisé, c'est donc pour gagner de la place que j'essaye de regrouper mes macros, car tu comprendras j'en suis sûr qu'avoir 4 boutons au lieu de 8 c'est quand même mieux ! non ? Celles-ci se sont les deux dernières !
Tout d'abord il faut créer la barre d'outil avec un bouton :
' Création de la barre d'outils congés
Sub CreationBOCongés()
Dim CB As CommandBar, CT As CommandBarButton
On Error Resume Next
CommandBars("Barre Conges").Delete
On Error GoTo 0
Set CB = Application.CommandBars.Add("Barre Conges")
Set CT = CB.Controls.Add(msoControlButton)
With CT
.Caption = "Conges"
.FaceId = 500 ' Un bouton au hasard
.OnAction = "PgmConge"
.TooltipText = "Formatage congés"
CB.Visible = True
End SubIdéalement, il faut mettre ce code dans l'évènement WorkBook_Open
et supprimer la barre d'outil dans le WorkBook_Close. De cette façon la barre d'outils n'est utilisable qu'avec le classeur de congés.
Ensuite il faut mettre dans un module du classeur cette macro qui appelle tes deux procédures :
Sub PgmConge()
If CommandBars.ActionControl.State = msoButtonUp Then
Call Conges
CommandBars.ActionControl.Caption = "Réinialiser" ' Facultatif
CommandBars.ActionControl.State = msoButtonDown ' bouton pressé
Call Reinitialiser
CommandBars.ActionControl.Caption = "Congés" ' Facultatif
CommandBars.ActionControl.State = msoButtonUp ' bouton relaché
End SubA+
Benead
Bonjour Benead, le forum,
Super, merci beaucoup pour ta réponse c'est super.
Bonne journée
