[EN] comparision and copy macro
Hi All,
I'm new to VBA macros on Excel and need your help for an important macro that I'm about to do ...
the required macro must do the following :
compare one coulmn in the 1st sheet to another one in the second sheet and with are the same, it will copies all the line to a new sheet... example :
the macro will make a loop to compare sheet1.cellID to 135.Cell ID and they have the same value, the macro will copy the following cells " Subrack No. Slot No. Subsystem No. NodeB ID NodeB name Cell ID Cell name" from 135 sheet and :
"Start Time Period NE Name BSC6900UCell BSC6900UCell cellID DLSPEECH(none)"
from the sheet1 sheet for this cellid value to target format sheet ...
hope its clear for you now ;;;; your fast respose will be highly appreciated !
attached is the workbook in question .
47audit-report-e01.zip (192.00 KB)
Hi Forum
Welcome you as new membres.
Try with this macro.
Sub CompareAndCopy()
Dim dict As Object
Dim CellId As String
Dim Ws1 As Worksheet
Dim Ws2 As Worksheet
Dim Ws3 As Worksheet
Dim Cel As Range
Set dict = CreateObject("Scripting.Dictionary")
Set Ws1 = Sheets("Sheet1")
Set Ws2 = Sheets("135")
Set Ws3 = Sheets("target format")
Ws3.Range("A1").CurrentRegion.Offset(1).ClearContents
For Each Cel In Ws2.Range("H2:H" & Ws2.Cells(Rows.Count, 1).End(xlUp).Row)
  If Not dict.Exists(Cel) Then dict.Add CStr(Cel.Value), Cel.Row
Next Cel
For Each Cel In Ws1.Range("F2:F" & Ws1.Cells(Rows.Count, 1).End(xlUp).Row)
  CellId = CStr(Split(Cel, "=")(1))
    If dict.Exists(CellId) Then
        Ws1.Cells(Cel.Row, "A").Resize(, 7).Copy Ws3.Range("A" & Ws3.Cells(Rows.Count, "A").End(xlUp).Row + 1)
        Ws2.Cells(dict(CellId), "A").Resize(, 7).Copy Ws3.Range("H" & Ws3.Cells(Rows.Count, "H").End(xlUp).Row + 1)
Next Cel
Ws3.Columns("A:N").AutoFit
Set Ws1 = Nothing
Set Ws2 = Nothing
Set Ws2 = Nothing
Set dict = Nothing
Have a nice day
Mytå
Hi Mytå,
amazing ! its working exactly as expected !
thanks a million for your support its really appreciated
engkemo
Hi Forum
Hi Engkemo, hope to help again
Don't forget to end the discussion by checking "Solved"
Mytå
Search for threads similar to "comparision copy macro"
