Automatically fill an Excel table via another one
good morning all !
Could you please give me some help ! I attached basically what I woould like to do on excel :
step 1 : from 1No file called "data file.xls" , fill up manually information (I know how to do)
step : 2 : export the information from "data file.xls" to a new file called "supervisor.xls" (I know how to do)
step 3 : I would like that the "supersivor.xls" fill up automaticlly the information coming from "data file.xls" once the variable Note or Date changed ( I do not know how to do !)
I do not know from where to start basically ...
Do you have any tips ?
Thank you very much !
351excel-enquiry-1.pdf (90.83 KB)
Hi benbenben89,
How do you do the step 2 ? With VBA ?
And basically, it's easier for us to help you if you attach an excel file rather a pdf. Tough your pdf is very clear.
And you say that you want the information in supervisor.xls to be filled automatically once the variable Note OR Date changed. Are you sure ? So with the datas of your pdf, if I change the 3 in the Note column, it automatically fills the supervisor file ?
Hi !
To do the step 2 , basically I am using the "connection fonction " located in the excel "data" menu . But may be the best way is to do everything in VBA.
My variable are
I have not create est the supervisor .xls file , as I do not know how to fill it automaticlly
"So with the datas of your pdf, if I change the 3 in the Note column, it automatically fills the supervisor file ?" : yes exacly
I am chasing the program
If you have any idea , please let me know
328data-file.xlsx (14.15 KB)
310excel-enquiry-1.pdf (90.83 KB)
Do you have excel 2008 for Mac ? If yes, using VBA is not possible.
VBA with excel 2008 ; why that is not possible ?
Simply because Microsoft decided not to implement VBA in excel 2008.
sorry excel 2007 ! I have the VBA editor
Ok.
On the sheet named Sheet1 there are 8 columns of datas. Which one do you want to put in the supervisor file ?
And there is always 1 row of datas (on row 5), am I alright ?
the data located in "sheet 1" take the information of the "table sheet" .Indeed , if you change in the "table sheet " the quantity of Status A , Status B etc etc , the quantity is sent to the "sheet1" . That is the first point .
Because I will have in total 5No different data file , I need what I called a supervisor file in order to summarise and get an history about all the information on 1No sheet.
Once I will update the A2 OR B2 located in the " table sheet" , I would like that in the "supervisor" file , 1No row is create and fill up automaticlly with the information located "sheet 1 table "
I have a question : what does "5No", "1No" mean ?
5No means 5 quantity , sorry for the syntax
Ok. Here are the steps to successfully import datas in the supervisor file.
1- Create a file named supervisor.xls in the same directory as the datafile
2- In the data file, right-click on the sheet named table and click on "Visualize the code" or something like that
3- Paste the following code :
    Dim chemin As String
    Dim NoteAndDate, Sttatus
    Dim SupFile As Workbook
    Dim derlign As Long
    If Not Application.Intersect(Target, [a2:b2]) Is Nothing And Target.Count = 1 Then
        chemin = ThisWorkbook.Path & "\"
        NoteAndDate = [a2:b2]
        Sttatus = Application.Transpose([b41:b43])
        Workbooks.Open (chemin & "supervisor.xls") 'open the supervisor file if it is in the same directory as the datafile
        Set SupFile = ActiveWorkbook
        With SupFile.Sheets(1)
            derlign = .Range("a" & .Rows.Count).End(xlUp).Row + 1
            .Range("a" & derlign).Resize(, 2) = NoteAndDate
            .Range("c" & derlign).Resize(, 3) = Sttatus
        SupFile.Close True 'save and close the supervisor file
4- Now change the value in A2 or B2 of the sheet table
5- Datas are imported in the supervisor file which is saved and closed.
that is exacly what i wanted !! thank you so much !
Now i need to found a way to automaticlly trace a graph with the evolution of the status A , status B and not commented (vertical axe) and date (horizontal graph)
i need as well now to ajust the code in order to integrate it into 5 different data file ( data file 1 , data file 2 , data file 3 , data file 4 ,data file 5) which will send into the supervisor file into 5 differents place .
Thank you very much
In the attached supervisor file, if you add a data, the graph will automatically take it into account.
63supervisor.zip (5.00 KB)
You normally just have to adapt the following lines :
Do you mean that the 5 datafile will be at a different place from each other ? The main thing is that you have to know the exact location of the supervisor file and it will be always the same.
Basically the 5No different files will be on a network at 5No different place (folder) .
At least the number of file will increase as in reallity 1No data file = 1No project .
What I would like is to have 1No sheet located in the supervisor file by project . If I do a new project , that will create the table in a new supervisor sheet ?
When I update the data file , I can put a message box saying "supervisor file upfdated " ?
Thank you !
Where should I send you a postcard ?
Can you create 2 datafiles with the real name and attach them here ?
You will have to put each time in the datafile the code I gave you or the new code I'll give you.
It's possible but :
How do I know that there is a new project ? I think that you'll have to create manually a new sheet in the supervisor file with the same name as the project name.
Yes
Where are you from ?
Search for threads similar to "automatically fill table via another one"
