Erreur d'execution 9
d
Bonjour à tous, le code ci-dessous me renvoie l'erreur d'execution 9: l'indice n'appartient pas a la selection
Application.Visible = True
cah = UserForm1.cah.Value
ca = UserForm1.ca.Value
rtth = UserForm1.rtth.Value
bonus = UserForm1.bonus.Value
rech = UserForm1.rech.Value
absex = UserForm1.absex.Value
sanssal = UserForm1.sanssal.Value
can = UserForm1.can.Value
chp = UserForm1.chp.Value
'DU
cah_du = UserForm1.cah_du.Value
ca_du = UserForm1.ca_du.Value
rtth_du = UserForm1.rtth_du.Value
bonus_du = UserForm1.bonus_du.Value
rech_du = UserForm1.rech_du.Value
absex_du = UserForm1.absex_du.Value
sanssal_du = UserForm1.sanssal_du.Value
can_du = UserForm1.can_du.Value
chp_du = UserForm1.chp_du.Value
'AU
cah_au = UserForm1.cah_au.Value
ca_au = UserForm1.ca_au.Value
rtth_au = UserForm1.rtth_au.Value
bonus_au = UserForm1.bonus_au.Value
rech_au = UserForm1.rech_au.Value
absex_au = UserForm1.absex_au.Value
sanssal_au = UserForm1.sanssal_au.Value
can_au = UserForm1.can_au.Value
chp_au = UserForm1.chp_au.Value
Worksheets("IMPRIME CP petit modèle").Range("E8") = cah
Worksheets("IMPRIME CP petit modèle").Range("E9") = ca
Worksheets("IMPRIME CP petit modèle").Range("E12") = rtth
Worksheets("IMPRIME cp petit modèle").Range("E14") = bonus
Worksheets("IMPRIME cp petit modèle").Range("E15") = rech
Worksheets("IMPRIME cp petit modèle").Range("E17") = absex
Worksheets("IMPRIME cp petit modèle").Range("E19") = sanssal
Worksheets("IMPRIME cp petit modèle").Range("E10") = can
Worksheets("IMPRIME cp petit modèle").Range("E11") = chp
Worksheets("IMPRIME cp petit modèle").Range("H8") = cah_du
Worksheets("IMPRIME cp petit modèle").Range("J8") = cah_au
Worksheets("IMPRIME cp petit modèle").Range("H9") = ca_du
Worksheets("IMPRIME cp petit modèle").Range("J9") = ca_au
Worksheets("IMPRIME cp petit modèle").Range("H12") = rtth_du
Worksheets("IMPRIME cp petit modèle").Range("J12") = rtth_au
Worksheets("IMPRIME cp petit modèle").Range("H14") = bonus_du
Worksheets("IMPRIME cp petit modèle").Range("J14") = bonus_au
Worksheets("IMPRIME cp petit modèle").Range("H15") = rech_du
Worksheets("IMPRIME cp petit modèle").Range("J15") = rech_au
Worksheets("IMPRIME cp petit modèle").Range("H17") = "Du " & absex_du & " au " & absex_au
Worksheets("IMPRIME cp petit modèle").Range("H19") = "Du " & sanssal_du & " au " & sanssal_au
Worksheets("IMPRIME cp petit modèle").Range("H10") = can_du
Worksheets("IMPRIME cp petit modèle").Range("J10") = can_au
Worksheets("IMPRIME cp petit modèle").Range("H11") = chp_du
Worksheets("IMPRIME cp petit modèle").Range("J11") = chp_au
UserForm1.cah.Value = ""
UserForm1.ca.Value = ""
UserForm1.rtth.Value = ""
UserForm1.bonus.Value = ""
UserForm1.rech.Value = ""
UserForm1.absex.Value = ""
UserForm1.sanssal.Value = ""
UserForm1.can.Value = ""
UserForm1.chp.Value = ""
'DU
UserForm1.cah_du.Value = ""
UserForm1.ca_du.Value = ""
UserForm1.rtth_du.Value = ""
UserForm1.bonus_du.Value = ""
UserForm1.rech_du.Value = ""
UserForm1.absex_du.Value = ""
UserForm1.sanssal_du.Value = ""
UserForm1.can_du.Value = ""
UserForm1.chp_du.Value = ""
'AU
UserForm1.cah_au.Value = ""
UserForm1.ca_au.Value = ""
UserForm1.rtth_au.Value = ""
UserForm1.bonus_au.Value = ""
UserForm1.rech_au.Value = ""
UserForm1.absex_au.Value = ""
UserForm1.sanssal_au.Value = ""
UserForm1.can_au.Value = ""
UserForm1.chp_au.Value = ""
End SubLe débogueur me renvoie sur la ligne Worksheets("IMPRIME CP petit modèle").Range("E8") = cah
Quelqu'un aurait il une explication svp (auquel cas la solution).
D'avance Merci
v
Bonjour djez,
Regarde si la feuille qui s'intitule exactement "IMPRIME CP petit modèle" existe vraiment.
