Ajout d'une inbox dans un code VBA existant
Quelqu'un saurait-il ajouter une inbox permettant de choisir le dossier de destination au lieu d'avoir un chemin fixe dans le code :
Sub SplitDataByColToWorkbooks()
' Updateby Extendoffice
Dim lr As Long
Dim ws As Worksheet
Dim vcol, i As Integer
Dim myarr As Variant
Dim title As String
Dim titlerow As Integer
Dim xTRg As Range
Dim xVRg As Range
Dim xWS As Workbook
Dim savePath As String
' Set the directory to save new workbooks
savePath = "C:\Users\AddinsVM001\Desktop\multiple files\" ' Modify this path as needed
Set xTRg = Application.InputBox("Please select the header rows:", "Kutools for Excel", Type:=8)
If TypeName(xTRg) = "Nothing" Then Exit Sub
Set xVRg = Application.InputBox("Please select the column you want to split data based on:", "Kutools for Excel", Type:=8)
If TypeName(xVRg) = "Nothing" Then Exit Sub
vcol = xVRg.Column
Set ws = xTRg.Worksheet
lr = ws.Cells(ws.Rows.Count, vcol).End(xlUp).Row
title = xTRg.Address(False, False)
titlerow = xTRg.Row
ws.Columns(vcol).AdvancedFilter Action:=xlFilterCopy, CopyToRange:=ws.Cells(1, ws.Columns.Count), Unique:=True
myarr = Application.Transpose(ws.Cells(1, ws.Columns.Count).Resize(ws.Cells(ws.Rows.Count, ws.Columns.Count).End(xlUp).Row).Value)
ws.Cells(1, ws.Columns.Count).Resize(ws.Cells(ws.Rows.Count, ws.Columns.Count).End(xlUp).Row).ClearContents
For i = 2 To UBound(myarr)
Set xWS = Workbooks.Add
ws.Range(title).AutoFilter Field:=vcol, Criteria1:=myarr(i)
ws.Range("A" & titlerow & ":A" & lr).SpecialCells(xlCellTypeVisible).EntireRow.Copy
xWS.Sheets(1).Cells(1, 1).PasteSpecial Paste:=xlPasteAll
xWS.SaveAs Filename:=savePath & myarr(i) & ".xlsx"
xWS.Close SaveChanges:=False
ws.AutoFilterMode = False
ws.Activate
End SubMerci!
Bonsoir le fil,
Cpabanal, Ajouter un module et collez-y ce code :
'----------------- ENUMERATION FOR READANDWRITEPARAM
Public Enum vaFileDialogFilterType
AllFile
ExcelFile
HtmlFile
ImagesFile
PdfFile
End Enum
'@Description "Open the folder selector, and save the feedback in the settings."
Public Function GetSavePath(Optional ByVal InitialPath As String = vbNullString, _
Optional ByVal FileDialogType As Office.MsoFileDialogType = msoFileDialogFolderPicker, _
Optional ByVal FilterType As vaFileDialogFilterType = AllFile _
) As String
On Error GoTo Catch
Dim localFileDialog As Office.FileDialog
Set localFileDialog = Application.FileDialog(FileDialogType)
With localFileDialog
.Filters.Clear
.AllowMultiSelect = False
If FileDialogType = msoFileDialogFolderPicker Then
.title = "Sélectionnez un dossier..."
.title = "Sélectionnez le fichier de destination."
Select Case FilterType
Case AllFile
.Filters.Add "Tous les fichiers", "*.*", 1
Case ExcelFile
.Filters.Add "Documents Excel", "*.xls; *.xlsx; *.xlsm; *.xlst; *.xlsb; *.csv", 1
Case ImagesFile
.Filters.Add "Images", "*.gif; *.jpg; *.jpeg; *.png; *.bmp", 1
Case HtmlFile
.Filters.Add "Documents Htm", "*.Htm; *.Html", 1
Case PdfFile
.Filters.Add "Fichiers Adobe PDF", "*.pdf; *.pdx; *.bpdx; *.fcdt; *.fdf", 1
End Select
.InitialView = msoFileDialogViewList
If InitialPath = vbNullString Then
.InitialFileName = ThisWorkbook.Path
.InitialFileName = IIf(Right$(.InitialFileName, 1) <> "\", "\", vbNullString)
If .Show Then
GetSavePath = .SelectedItems(1)
MsgBox "Commande annulée par l'utilisateur!"
GetSavePath = vbNullString
Finally:
' // Cleaning of the memory.
If Not localFileDialog Is Nothing Then Set localFileDialog = Nothing
Exit Function
Catch:
MsgBox "Erreur " & Err.Number & " (" & Err.Description & ")" & vbCrLf & _
"Dans la procédure 'ReadAndWriteParam' du Module 'modFunctions'"
Resume Finally
End FunctionVous pourrez ensuite changer l'appel dans votre procédure comme ceci :
'// Set the directory to save new workbooks
On Error GoTo Catch
'// ------------ L'APPEL SE FAIT ICI ------------
savePath = GetSavePath(InitialPath:="C:\Users\AddinsVM001\Desktop\multiple files", _
FileDialogType:=msoFileDialogFolderPicker) ' Modify this path as needed
Dim xTRg As Range
Dim xVRg As Range
Dim vcol As Variant
vcol = xVRg.Column
Dim ws As Worksheet
Dim lr As Long
Dim title As String
titlerow = xTRg.Row
Dim i As Integer
Dim xWS As Workbook
ws.Activate
Finally:
Exit Sub
Catch:
If Err.Number > 0 Then
' // Do something.
MsgBox "Oupss... Nous avons rencontré une erreur : " & Err.Number & _
" (" & Err.Description & ") dans la procédure SplitDataByColToWorkbooks du Module Module1"
Resume Finally
End SubQuand vous utilisez 'Application.EnableEvents ou Application.DisplayAlert prenez soin de l'encadrer dans une gestion d'erreur.
Certaines parties du code me paraissent bizarres, mais ça c'est une autre histoire...
Bonne programmation.
Bonjour et merci pour votre réponse rapide, je vais tester ça.
Pour les bizarreries détectées, j'avoue ne pas avoir l'expertise pour les repérer, j'ai récupéré ce code sur un site internet, il correspondait à mon besoin hormis le choix du dossier de destination.
Bonjour le fil,
Bon apparemment mon dernier message n'est pas passé...
En regardant de plus près le code que j'ai fourni, j'ai remarqué un petite boulette sur la ligne : .InitialFileName = IIf(Right$(.InitialFileName, 1) <> "\", "\", vbNullString) gardée tel quel elle renvoie une valeur erronée. De plus les bloc IIf peuvent ne pas fonctionner comme il se doit donc préférez lui un bloc If tout simple. Remplacer la ligne par ce bloc :
.InitialFileName = ThisWorkbook.Path & "\"
If Right$(InitialPath, 1) = "\" Then
.InitialFileName = InitialPath
.InitialFileName = InitialPath & "\"
End IfVous remarquerez aussi que cette fonction est générique elle est capable de s'adapter à l'ouverture soit d'un fichier soit d'un répertoire. En effet tous les paramètres sont facultatifs, par défaut le sélecteur de répertoire sera sélectionné. Exemple :
Public Sub Test102()
Dim SavePath As String
SavePath = GetSavePath '// Ici c'est le sélecteur de dossier qui sera ouvert.
If SavePath > vbNullString Then
End SubPetites points subsidiaires.
Il est plus rapide et plus normal de tester directement si "xTRg" est à Nothing que de passer par TypeName.
Donc ceci :
Dim xTRg As Range
If TypeName(xTRg) = "Nothing" Then Exit SubPeut être avantageusement remplacé par cela :
Dim xVRg As Range
If xVRg Is Nothing Then Exit SubPareil pour "xVRg"...
Bonne programmation...
J'ai fait les modifs suggérées, ça fonctionne parfaitement. Merci bcp!
Cpabanal, n'oubliez pas de marquer le sujet résolu. Et un petit vote fait toujours plaisir...
