Traduction de formule
Est ce que quelqu'un pourrais me traduire cette macro
J'aimerais changer des données en JAUNE mais je ne comprends pas .
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""BETTY"",""X"")"
et J'aimerais changer les données en BLEU en indiquant une cellule
PLAN Macro
ActiveWindow.ScrollWorkbookTabs Position:=xlLast
Sheets("PLAN DE CHARGEMENT ").Select
Range("A4").Select
Range("A5").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""ALIK"",""X"")"
Range("A6").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""YO"",""X"")"
Range("A7").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""DIDIER"",""X"")"
Range("A8").Select
Range("A9").Select
Range("A10").Select
Range("A11").Select
Range("A12").Select
Range("A13").Select
Range("A14").Select
Range("A15").Select
Range("A16").Select
Range("A17").Select
Range("A18").Select
Range("A19").Select
Range("A20").Select
Range("A21").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""LOLO"",""X"")"
Range("A22").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[11]=""x"",""LYE"",""X"")"
Range("A23").Select
Range("A24").Select
Range("A25").Select
Range("A26").Select
Range("A27").Select
Range("A28").Select
Range("A29").Select
Range("A30").Select
Range("A31").Select
Range("A32").Select
Range("A33").Select
Range("B4").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[10]=""X"",'02'!R[12]C[2],""X"")"
Range("B4").Select
Selection.AutoFill Destination:=Range("B4:B33"), Type:=xlFillDefault
Range("B4:B33").Select
ActiveWindow.ScrollWorkbookTabs Position:=xlFirst
Range("C4").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[9]=""X"",'02'!R[12]C[2],""X"")"
Range("C4").Select
Selection.AutoFill Destination:=Range("C4:C33"), Type:=xlFillDefault
Range("C4:C33").Select
ActiveWindow.SmallScroll Down:=-40
Range("E4").Select
ActiveCell.FormulaR1C1 = "=IF('02'!R[12]C[7]=""X"",'02'!R[12]C[9],""X"")"
Range("E4").Select
Selection.AutoFill Destination:=Range("E4:E33"), Type:=xlFillDefault
Range("E4:E33").Select
Range("H4").Select
Range("A3:E3").Select
Selection.AutoFilter
ActiveSheet.Range("$A$3:$E$33").AutoFilter Field:=1, Criteria1:="X"
Range("A4:E33").Select
Selection.EntireRow.Delete
ActiveSheet.Range("$A$3:$E$14").AutoFilter Field:=1
Range("I3").SelectEdit moderation : code mis entre balises code "</>" voir barre de menu. merci d'y penser à l'avenir quand tu mets du code.
R[12]C[11] fait référence à la cellule qui se trouve 12 ligne plus bas et 11 colonne à droite de la cellule qui contient la formule.
Donc pour "=IF('02'!R[12]C[11]=""x"" ... '02'!R[12]C[11] fait référence à la cellule L16 de la feuille 02
tu pourrais plus simplement écrire ta formule ainsi, en supposant que tu veuilles remplacer le texte BETTY par une référence à la cellule Z5
Sheets("PLAN DE CHARGEMENT ").Range("A4").Formula = "=IF('02'!L16=""x"",Z5,""X"")"Bonjour,
J'ai bien compris votre solution mais cela ne fonctionne pas.
voici ma nouvelle macro
Sheets("PLAN DE CHARGEMENT ").Sellect
Range("A4").Formula = "=IF('02'!M16=""X"",E16,""X"")"
Range("A5").Formula = "=IF('02'!M17=""X"",E17,""X"")"
Range("A6").Formula = "=IF('02'!M18=""X"",E18,""X"")"
Range("A7").Formula = "=IF('02'!M19=""X"",E19,""X"")"
Range("A8").Formula = "=IF('02'!M20=""X"",E02,""X"")"
Range("A9").Formula = "=IF('02'!M21=""X"",E21,""X"")"
Range("A10").Formula = "=IF('02'!M22=""X"",E22,""X"")"
Range("A11").Formula = "=IF('02'!M23=""X"",E23,""X"")"
Range("A12").Formula = "=IF('02'!M24=""X"",E24,""X"")"
Range("A13").Formula = "=IF('02'!M25=""X"",E25,""X"")"
Range("A14").Formula = "=IF('02'!M26=""X"",E26,""X"")"
Range("A15").Formula = "=IF('02'!M27=""X"",E27,""X"")"
Range("A16").Formula = "=IF('02'!M28=""X"",E28,""X"")"
Range("A17").Formula = "=IF('02'!M29=""X"",E29,""X"")"
Range("A18").Formula = "=IF('02'!M30=""X"",E30,""X"")"
Range("A19").Formula = "=IF('02'!M31=""X"",E31,""X"")"
Range("A20").Formula = "=IF('02'!M32=""X"",E32,""X"")"
Range("A21").Formula = "=IF('02'!M33=""X"",E33,""X"")"
Range("A22").Formula = "=IF('02'!M34=""X"",E34,""X"")"
Range("A23").Formula = "=IF('02'!M35=""X"",E35,""X"")"
Range("A24").Formula = "=IF('02'!M36=""X"",E36,""X"")"
Range("A25").Formula = "=IF('02'!M37=""X"",E37,""X"")"
Range("A26").Formula = "=IF('02'!M38=""X"",E38,""X"")"
Range("A27").Formula = "=IF('02'!M39=""X"",E39,""X"")"
Range("A28").Formula = "=IF('02'!M40=""X"",E40,""X"")"
Range("A29").Formula = "=IF('02'!M41=""X"",E41,""X"")"
Range("A30").Formula = "=IF('02'!M42=""X"",E42,""X"")"
Range("A31").Formula = "=IF('02'!M43=""X"",E43,""X"")"
Range("A32").Formula = "=IF('02'!M44=""X"",E44,""X"")"
Range("A33").Formula = "=IF('02'!M45=""X"",E45,""X"")"
Range("A34").Formula = "=IF('02'!M46=""X"",E46,""X"")"
Range("B4").Select
Range("C4").Select
Range("C4").Select
Range("E4").Select
Range("E4").Select
Range("H4").Select
Range("I3").Select
End SubJ'ai bien compris votre solution mais cela ne fonctionne pas.
désolé que cela ne fonctionne pas, je ne peux malheureusement fournir aucune aide sur base d'un "ça ne fonctionne pas".
Y a-t-il un message d'erreur ?
Bonjour Bettina et H2so4
je suis encore en train de chercher les données en jaune et en bleu.
Par contre je vois dès les premières lignes de code :
Sheets("PLAN DE CHARGEMENT ").Sellect avec 2 L je ne penses pas.
Bonjour Xmenpl,
Je suis encore en train de chercher les données en jaune et en bleu
J'ai mis le code entre balises et de ce fait, la mise en forme du texte a été perdue. C'est corrigé.
Vu
