New workbook from the existing one with data
I would like the Macro to do the following:
When I open the file and select, for example, A7
Then I run the macro
In the macro, I have a setting that if I first selected a cell from row 7, then the macro places the 1st, 3rd, 5th and 7th cells from row 7 in a new workbook in the following way
1. in A1
3. in A2
5. in A3
7. in A4
Also, I would like to choose the save location
macro 03
Hello and welcome to the forum
Try with the code herein
Sub Macro1()
Dim newwb As Workbook
Dim r As Integer
Dim TS As ListObject
Set TS = ThisWorkbook.ActiveSheet.ListObjects(1)
On Error Resume Next
r = TS.ListRows(ActiveCell).Range.Row - TS.HeaderRowRange.Row
If r = 0 Then MsgBox "No cell selected in table !", vbCritical, "Wrong selection": Exit Sub 'if selected cell in not in table range
On Error GoTo 0
Set newwb = Workbooks.Add
With ActiveWorkbook.ActiveSheet
    .Range("A1") = TS.DataBodyRange(r, 1).Value
    .Range("A2") = TS.DataBodyRange(r, 3).Value
    .Range("A3") = TS.DataBodyRange(r, 5).Value
    .Range("A4") = TS.DataBodyRange(r, 7).Value
rem : Please think to update the reference of your excel version in your account as "English" does not help. Use excel 2008, 2016,;... or if you are a MacUser --> MAC2011, MAC20xx
Sincerely
I think I get what you're aiming for with the macro. So, when you open the file and select a cell like A7, you want the macro to grab certain cells from that row (like A7, C7, E7, G7) and paste them into a new workbook, right?
Search for threads similar to "new workbook existing one data"
