ERREUR DE COMPILATION : Projet ou bibliotheque introuvable code VBA
A
Bonjour chers excelliens. svp sujet d'une extreme urgence. cloture comptable mensuel en suspens....
Sub consoBank()
'consolidation Macro
MsgBox ("Cette operation peut durer quelques minutes compte tenu du volume des données à analyser. ")
Feuil15.Select
Sheets("0120").Select
Range("A2:J839").Select
Selection.Copy
Sheets("CONSO").Select
Range("A1").Select
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=831
Range("A839").Select
Sheets("0220").Select
Range("A3").Select
Range(Selection, Selection.End(xlToRight)).Select
Range(Selection, Selection.End(xlDown)).Select
Selection.Copy
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=840
Range("A1676").Select
Sheets("0320").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=828
Range("A2513").Select
Sheets("0420").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=837
Range("A3350").Select
Sheets("0520").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A4187").Select
Sheets("0620").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A5024").Select
Sheets("0720").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A5861").Select
Sheets("0820").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=843
Range("A6698").Select
Sheets("0920").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
ActiveWindow.SmallScroll Down:=834
Range("A7535").Select
Sheets("1020").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A8372").Select
Sheets("1120").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A9209").Select
Sheets("1220").Select
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A1:J10045").Select
Selection.Borders.Value = 1
Columns("I:I").EntireColumn.AutoFit
Columns("J:J").EntireColumn.AutoFit
Columns("D:D").EntireColumn.AutoFit
Columns("E:F").Select
Range("F1").Activate
Selection.EntireColumn.Hidden = True
Cells.Select
ActiveWorkbook.Worksheets("CONSO").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("CONSO").Sort.SortFields.Add ey:=Range("B2:B10045") _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
ActiveWorkbook.Worksheets("CONSO").Sort.SortFields.Add(Range("D2:D10045"), xlSortOnFontColor, xlAscending, , xlSortNormal).SortOnValue.Color = RGB(0, 0, 0)
With ActiveWorkbook.Worksheets("CONSO").Sort
.SetRange Range("A1:J10045")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Dim Dern_Ligne As Integer
Dern_Ligne = Range("A" & Rows.Count).End(xlUp).Row
i = 1
boucle:
While Cells(i, 1) <> ""
If Cells(i, 10).Value = 0 Then
Cells(i, 10).EntireRow.Delete
i = i - 1
i = i + 1
Wend
If Cells(i + 1, 1) <> "" Then
i = i + 1
GoTo boucle
Else: Exit Sub
MsgBox ("CONSOLIDATION TERMINEE. ")A
Sub consoBank()
Feuil15.Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Range("A3").Select
Selection.Copy
ActiveSheet.Paste
Cells.Select
.Header = xlYes
.MatchCase = False
.Apply
i = 1
boucle:
i = i - 1
i = i + 1
Wend
i = i + 1
GoTo boucle
Else: Exit Sub
je viens de mettre le code sous balise. Pouvez vous m'aidez pour editer mon message
