VBA Obfuscator doesn't work On 03/06/2024 at 15:19SSpeeD72NewcomerPosts3Excel365 PTRegistered03/06/2024 Hi to allthe VBA Obfuscator on this site doesn't work even with the code it makes a example of.What am i oding wrong?Is this thing working?thanks a lotJorgeOn 03/07/2024 at 09:44 DanModeratorPosts16,445Files3Excel2016, Mac 2011Downloads10,551Registered04/27/2007JobRetraitéHi,Effectively this option returns an error 404.Did you try using the link --> https://www.excel-pratique.com/fr/astuces_vba/proteger-code-vbaRegardsEdit : EN version is available here --> https://www.excel-pratique.com/en/tools/vba-obfuscatorPlease note that correction by forum Adminstration is on process.If this solves your problem, think toOn 03/07/2024 at 10:25SSpeeD72NewcomerPosts3Excel365 PTRegistered03/06/2024HiNone of them works. At this point it simply dont return any CodeThanks a lotJorgeOn 03/07/2024 at 11:40SébastienAdministratorPosts3,129Files118ExcelFR, Sheets, CalcDownloads1,838,033Registered12/04/2004Hi,You need to enter your VBA code here (for example, the sample code): Then, list the names to be replaced below: And you will then get the obfuscated code: On 03/07/2024 at 12:00SSpeeD72NewcomerPosts3Excel365 PTRegistered03/06/2024 Hi..OK. ill try it now!ThsnkJorgeSearch for threads similar to "vba obfuscator doesn work"ForumsExcel - VBAVBA Obfuscator doesn't work
