Hi all,
I've just started to learn about coding in VBA and I have an error in the following code that I don't know how to resolve.
I want to use a CheckBox, the first part If block is working as it should but the second one is not.
When I run the code the error 91 appear saying "Object Variable or With block variable not set".
ActiveSheet.Range("A10:A30").Find("Mr. G").Select
Does anyone know how to resolve this issue ?
Thank you !
Private Sub CheckBox1_Click()
If CheckBox1.Value = True Then
ActiveSheet.Range("A10:A30").Find("").Select
Range(ActiveCell, ActiveCell.Offset(0, 2)).BorderAround _
ColorIndex:=1, Weight:=xlThin
Range(ActiveCell, ActiveCell.Offset(0, 2)).Merge
Range("A10:C10").BorderAround _
ColorIndex:=1, Weight:=xlMedium
ActiveCell.Value = "Mr. G"
ActiveCell.Font.Name = "Arial"
Range(ActiveCell, ActiveCell.Offset(0, 2)).HorizontalAlignment = xlCenter
Range(ActiveCell, ActiveCell.Offset(0, 2)).VerticalAlignment = xlCenter
If CheckBox1.Value = False Then
ActiveCell.ClearContents
