Erreur d'exécution 5
bonjour,
d'abord merci pour les cours vba, ils sont vraiment très très utile ;)
j'aurai besoin d'un petit coup de pouce pour debugger ma macro.
je coince sur une erreur 5 que je ne comprend pas.
si il y a d'autre bug je suis preneur d'explication
merci d'avance.
Sub Macro4()
' Macro4 Macro
Dim NLIGNES As Integer
Dim DATEFACT As Date
Dim AUJOURDHUI As Date
Dim NMONTANT As Integer
Dim NDATEFACT As Date
    AUJOURDHUI = Date
    For NLIGNES = 10 To 210
    DATEFACT = Cells("NLIGNES,24")
        If DATEFACT = "" And Cells("NLIGNES,25") = "" And Cells("NLIGNES,26") = "" And Cells("NLIGNES,27") = "" And Cells("NLIGNES,28") = "" And Cells("NLIGNES,29") = "" And Cells("NLIGNES,30") = "" And Cells("NLIGNES,31") = "" And Cells("NLIGNES,32") = "" Then
            Rows("NLIGNES").Select
            Selection.Cut
            ActiveSheet("SOLDÉES").Select
            ActiveSheet.past
            ActiveSheet("TABLE").Select
            If DATEFACT >= AUJOURDHUI Then
                Select Case MsgBox("Voulez-vous facturer le cells(NLIGNES,3)?", vbYesNo, "FATURATION")
                    Case vbYes
                    Select Case MsgBox("Facturation de cells(NLIGNES,25)€", vbYesNo, "FACTURACTION cells(NLIGNES,3)")
                        Case vbYes
                        Cells("NLIGNES,24").Select
                        Selection.Cut
                        Cells("NLIGNES,23").Select
                        ActiveSheet.Paste
                        Cells("NLIGNES,18").Select
                        Selection.Cut
                        Range("W6").Select
                        ActiveSheet.Paste
                        Cells("NLIGNES,25").Select
                        Selection.Cut
                        Range("X6").Select
                        ActiveSheet.Paste
                        Range("Y6").Select
                        ActiveCell.FormulaR1C1 = "=RC[-2]+RC[-1]"
                        Range("Y6").Select
                        Selection.Copy
                        Range("Y6,Z6").Select
                        Range("Z6").Activate
                        ActiveSheet.Paste
                            :=False, Transpose:=False
                        Range("Z6").Select
                        Selection.Copy
                        ActiveSheet.Paste
                        With Selection.Interior
                            .Pattern = xlSolid
                            .PatternColorIndex = xlAutomatic
                            .ThemeColor = xlThemeColorAccent6
                            .TintAndShade = 0.599993896298105
                            .PatternTintAndShade = 0
                        Cells("NLIGNES,26:NLIGNES,31").Select
                        Selection.Copy
                        Cells("NLIGNES,24:NLIGNES,29").Select
                        ActiveSheet.Paste
                        Cells("NLIGNES,30:NLIGNES,31").Select
                        Selection.ClearContents
                        Range("W6:Z6").Select
                        Selection.Style = "Normal 2"
                        Cells("NLIGNES,22").Select
                        Selection.Borders(xlDiagonalDown).LineStyle = xlNone
                        Selection.Borders(xlDiagonalUp).LineStyle = xlNone
                        With Selection.Borders(xlEdgeLeft)
                            .LineStyle = xlContinuous
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                        With Selection.Borders(xlEdgeTop)
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                        With Selection.Borders(xlEdgeBottom)
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                        With Selection.Borders(xlEdgeRight)
                            .LineStyle = xlDot
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                        Selection.Borders(xlInsideVertical).LineStyle = xlNone
                        Selection.Borders(xlInsideHorizontal).LineStyle = xlNone
                        Case vbNo
                        NMONTANT = InputBox("Quelle est le nouveau montant a facturer ?", "NOUVEAU MONTANT")
                        Selection.Cut
                        ActiveSheet.Paste
                        Selection.Cut
                        Range("W6").Select
                        ActiveSheet.Paste
                        Range("X6") = NMONTANT
                        Range("Y6").Select
                        Range("Y6").Select
                        Selection.Copy
                        ActiveSheet.Paste
                        Range("Z6").Select
                        Selection.Copy
                        ActiveSheet.Paste
                            .Pattern = xlSolid
                        Selection.Copy
                        ActiveSheet.Paste
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                            .LineStyle = xlDot
                            .ColorIndex = 0
                            .TintAndShade = 0
                            .Weight = xlThin
                        End Select
                    Case vbNo
                    NDATEFACT = InputBox("Nouvelle date de facturation ?", "RECALAGE DE DATE")
                    Cells(NLIGNES, 24) = NDATEFACT
                End Select
Oui normal vous mettez des guillemets dans cette instruction --> DATEFACT = Cells("NLIGNES, 24")
Comme ceci :
DATEFACT = Cells(NLIGNES, 24)
En regardant votre code :
- Il faut mieux préciser la feuille sur laquelle vous exécutez le code. Là on voit bien colonne 24 mais ne sait pas sur quelle feuille vous êtes et on se demande pourquoi vous bouclez jusque 210
- Evitez aussi les Select. Cela vient probablement de l'enregistreur automatique que vous avez utilisé. C'est bien mais après vous pouvez optimiser.
NB : Evitez aussi les accents et espaces dans le nom de vos feuilles quand vous utilisez VBA.
Crdlt
Merci beaucoup ça m'a bien aidé ça m'a permis de changer mon code
Rechercher des sujets similaires à "erreur execution"
