Dans mon exemple Word est référencé :
Sub MajCheckBox(ByVal DocEnCours As Word.Document, ByVal NomCheckBox As String, ByVal Valeur As Boolean)
Dim ControleEncours As Word.InlineShape
With DocEnCours
For Each ControleEncours In .InlineShapes
If ControleEncours.Type = wdInlineShapeOLEControlObject Then
Select Case ControleEncours.OLEFormat.ClassType
Case "Forms.CheckBox.1" '"Forms.ComboBox.1","Forms.ListBox.1", "Forms.Label.1", "Forms.TextBox.1"
With ControleEncours.OLEFormat.Object
If .Name = NomCheckBox Then
.Value = Valeur
Exit For
End Select
Exemple de mise en oeuvre :
Set WordDoc = WordApp.Documents.Open("C:\Users\XXX\Mettre à jour les checkbox.docm")
MajCheckBox WordDoc, "CheckBox1", True
