Worksheet & Workbook recognition error
Hello,
I hope you are well.
Please, I've been having problems for a while with my VBA compiler. It no longer recognizes the Worksheet and workbook objects and returns an Error as you can see in the photo below.
excel vba error9of workbook
I tried to debug but can't since.
excel vba error9of workbook debugtesting
I read a comment about resetting VBA settings in Excel(Rétablir Interface VBA par défaut (excel-pratique.com)) but it seems I didn't do it right, since the problem hasn't been solved.
I need your help please.
Hi Giaco1234 and Welcome on Excel-Pratique
For your concern, you can try
With ThisWorkbook.Sheets("Test")
  .Range("B1") = .Range("A1")
Thank you BrunoM455 for your prompt feedback.
Search for threads similar to "worksheet workbook recognition error"
