Soit le tableau structuré "t_Indices" ci-dessous.
En A10 et B10 deux listes de validation contenant la formule =INDIRECT("t_Indices[Indices]")
Et la fonction ValeurCommuneMini
Function ValeurCommuneMini(ByVal AireIndices As Range, ByVal Indice1 As String, ByVal Indice2 As String) As Variant
Dim I As Integer, J As Integer
Dim Continuer As Boolean
Dim Aire1 As Range, Aire2 As Range
ValeurCommuneMini = "Aucune valeur commune"
For I = 1 To AireIndices.Count
If AireIndices(I) = Indice1 Then Set Aire1 = Range(AireIndices(I).Offset(0, 1), AireIndices(I).Offset(0, 6))
If AireIndices(I) = Indice2 Then Set Aire2 = Range(AireIndices(I).Offset(0, 1), AireIndices(I).Offset(0, 6))
Next I
Continuer = True
For I = 1 To Aire1.Count
For J = 1 To Aire2.Count
If Aire1(I) = Aire2(J) Then
ValeurCommuneMini = Aire1(I)
Continuer = False
Next J
If Continuer = False Then Exit For
Next I
Set Aire1 = Nothing: Set Aire2 = Nothing
End Function
