Virgule flotante
Je rencontre un problème de virgule flottante.
Alors j'ai un code qui me permet de copier des données d'un fichier vers en un autre en faisant quelques calculs.
Mon code fonctionne bien, mais par curiosité j'ai décidé de l'envoyer dans Chat GPT pour voir ce qui pouvait en sortir.
Je sais j'ai brisé la règle "if it ain't broken don't fix it".
Bref je post quand même ici si quelqu'un pouvait m'aider à mieux comprendre.
Private Sub FillInvoice2()
    Dim TVA_1 As Single, TVA_2 As Single, HT As Single, TTC As Single, TVA As Single, HT_1 As Single, HT_2 As Single
    Dim TotalDocuments As Integer, i As Integer, y As Integer, PaymentRow As Integer, InvoiceRow As Integer, TVAErrorCount As Integer
    Dim ClientCode As Variant
    Dim HT_Array As Variant, TVA_Array As Variant
    Dim FindString As String
    Dim FoundRange As Range
    TVA_1 = wbmacro.Sheets("Notice").Cells(29, 3).Value
    TVA_2 = wbmacro.Sheets("Notice").Cells(30, 3).Value
    TVA_Array = Array(TVA_1, TVA_2)
    TotalDocuments = wbinvoice.Sheets(1).UsedRange.Rows.Count
    PaymentRow = 2
    InvoiceRow = 2
    TVAErrorCount = 0
    'For i = 2 To TotalDocuments
    For i = 2 To 10
        If Left(wbinvoice.Sheets(1).Cells(i, 2).Value, lenghtfacture) = prefixefacture And wbinvoice.Sheets(1).Cells(i, 6).Value <> 0 Then
        ' Calculate HT and TTC for invoice
        HT = wbinvoice.Sheets(1).Cells(i, 6).Value * 100
        TTC = wbinvoice.Sheets(1).Cells(i, 7).Value * 100
        MsgBox (HT & " fill invoice 2")
            ' Handle zero TVA case
            If TTC - HT = 0 Then
                FillInvoiceRow i, InvoiceRow, HT
                InvoiceRow = InvoiceRow + 1
                CreatePayment i, PaymentRow, TTC
                PaymentRow = PaymentRow + 1
                ' Calculate invoice TVA
                TVA = TTC - HT
                TVA = Round(TVA / HT * 100, 2)
                ' Handle rounded TVA values
                TVA = GetRoundedTVA(TVA, TVA_Array)
                ' Handle single TVA rate case
                If TVA = TVA_1 Or TVA = TVA_2 Then
                    FillInvoiceRow i, InvoiceRow, HT, TVA
                    ' Calculate HT for both TVA rates
                    HT_2 = Round((TTC - (HT * (1 + TVA_1 / 100))) / (TVA_2 / 100 - TVA_1 / 100), 2)
                    HT_1 = HT - CDbl(HT_2)
                    HT_Array = Array(HT_1, HT_2)
                    ' Create multi-rate invoices
                    For y = 0 To 1
                        HT = HT_Array(y)
                        ' Check if calculated TVA equals document TVA
                        If TVA = CDbl(Round(HT_1 * TVA_1 / 100 + HT_2 * TVA_2 / 100, 2)) Then
                            wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 33).Value = TVA_Array(y)
                            wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 33).Value = "TVA à verifier"
                            TVAErrorCount = TVAErrorCount + 1
                    Next y
            If wbinvoice.Sheets(1).Cells(i, 8).Value <> TTC Then
                ' Create payments
    If TVAErrorCount >= 1 Then
        MsgBox ("Des erreurs sont présentes dans la colonne (AG) taux de TVA, pensez à vérifier les factures liées")
Private Function GetRoundedTVA(TVA As Single, TVA_Array As Variant) As Single
    Dim y As Integer
    For y = 0 To 1
        If Abs(TVA - TVA_Array(y)) <= 0.1 Then
            TVA = TVA_Array(y)
    GetRoundedTVA = TVA
End Function
Private Sub FillInvoiceRow(ByVal i As Integer, ByVal InvoiceRow As Integer, ByVal HT As Single, Optional ByVal TVA As Single)
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 1).Value = wbinvoice.Sheets(1).Cells(i, 2).Value
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 2).Value = CDate(wbinvoice.Sheets(1).Cells(i, 3).Value)
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 3).Value = wbinvoice.Sheets(1).Cells(i, 4).Value
    FindClientCode wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 3).Value, wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 4), InvoiceRow
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 12).Value = wbinvoice.Sheets(1).Cells(i, 5).Value
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 18).Value = "A réception"
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 28).Value = "NC"
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 29).Value = 1
    MsgBox (Round(HT, 2))
    wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 31).Value = HT / 100
    If Not IsMissing(TVA) Then
Private Sub FindClientCode(ByVal searchString As String, ByRef outputCell As Range, ByVal InvoiceRow As Integer)
    Dim rngfound As Range
    With wbclient.Sheets(1).Range("C:C")
        Set rngfound = .Find(searchString, LookIn:=xlValues, LookAt:=xlWhole)
        If Not rngfound Is Nothing Then
            outputCell.Value = wbclient.Sheets(1).Cells(rngfound.Row, 1).Value
            wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 4) = outputCell.Value
Private Sub CreatePayment(ByVal i As Integer, ByVal PaymentRow As Integer, ByVal TTC As Single)
        wbgabarit_paiement.Sheets(1).Cells(PaymentRow, 1).Value = wbinvoice.Sheets(1).Cells(i, 2).Value
        wbgabarit_paiement.Sheets(1).Cells(PaymentRow, 2).Value = CDate(wbinvoice.Sheets(1).Cells(i, 3).Value)
        wbgabarit_paiement.Sheets(1).Cells(PaymentRow, 6).Value = "Règlement client"
        wbgabarit_paiement.Sheets(1).Cells(PaymentRow, 7).Value = "Autres"
        wbgabarit_paiement.Sheets(1).Cells(PaymentRow, 8).Value = wbinvoice.Sheets(1).Cells(i, 9).Value
Le problème se situe dans le sub FillInvoiceRow.
Pour les lignes
J'ai placé une msgbox pour être certain de la valeur HT que j'ai à ce moment.
Quand j'attribue la variable HT à ma cellule dans la ligne suivante c'est à ce moment que je rencontre mon problème de virgule flottante.
J'ai essayé de multiplier les données par 100 avant de la diviser par 100, d'arrondir le résultat à 2 chiffres même problème.
Quand je lance ma macro ma première valeur pour le HT est de 63,16 tout le long même dans le msgbox et pourtant dans ma cellule j'obtiens 63,159999998.
Bon j'ai creusé encore avec chat GPT. et la correction est la suivante:
wbgabarit_invoice.Sheets(1).Cells(InvoiceRow, 31).Value = CDbl(format(HT, "0.00"))
Rechercher des sujets similaires à "virgule flotante"
