[VBA] , end if sans bloc if
Bonjour à tous, erreur je pense que certains arriveront à corriger sans problème mais à force d'avoir la tête dedans impossible de savoir à quel niveau j'ai cette erreur.
Private Sub createbt_Click()
Dim i As Long
'si sublan est vide je ne fais rien
If Me.sublan24 = "" Then
'si sublan n'est pas vide et lantype=LBH alors
    If lantype = "LBH" Then
                With TS_lan
                i = Application.Match(Me.sublan24, .ListColumns("Subnet IP").DataBodyRange, 0)
                .ListRows(i).Range.Interior.ColorIndex = 43
                .ListColumns("Designation").DataBodyRange(i) = Me.descriplan
                .ListColumns("VLAN").DataBodyRange(i) = Val(Me.vlanlan)
                .ListColumns("Commentaire").DataBodyRange(i) = Me.commfinal3 & "Sans SNAT (LB en GW)"
                Dim Ligne_Inser
                With TS_spine
                Set Ligne_Inser = .ListRows.Add: i = Ligne_Inser.index
                Ligne_Inser.Range.Interior.ColorIndex = 43
                .DataBodyRange(i, "A") = Me.vrflan
                .DataBodyRange(i, "M") = Me.vlanlan
                .DataBodyRange(i, "K") = Me.descriplan
                .DataBodyRange(i, "O") = Me.descriplan
                .DataBodyRange(i, "H") = Me.sublan24
                .DataBodyRange(i, "E") = Me.commfinal3
                .DataBodyRange(i, "C") = Me.vpninst
                .DataBodyRange(i, "B") = "V" & Me.vrflan
                .DataBodyRange(i, "G") = "Compute sans SNAT (LB en GW)"
                .DataBodyRange(i, "N") = "0" & Me.vlanlan
                .DataBodyRange(i, "L") = ""
                .DataBodyRange(i, "S") = ""
                .DataBodyRange(i, "T") = ""
                .DataBodyRange(i, "U") = ""
                .DataBodyRange(i, "V") = ""
                .DataBodyRange(i, "W") = ""
                If dhcp.Value = True Then
                .DataBodyRange(i, "AD") = "10.5.230.48"
                .DataBodyRange(i, "AE") = "Serveur DHCP UNIX"
                .DataBodyRange(i, "AF") = "10.5.224.13"
                .DataBodyRange(i, "AG") = "Serveur DHCP SOLARIS 10"
                .DataBodyRange(i, "AH") = "10.5.224.13"
                .DataBodyRange(i, "AI") = "Serveur DHCP SOLARIS 11"
                With TS_L2
                .DataBodyRange(i, "A") = "0" & Me.vlanlan
                .DataBodyRange(i, "B") = Me.descriplan
                .DataBodyRange(i, "C") = "Compute sans SNAT (LB en GW)"
                .DataBodyRange(i, "D") = "oui"
                .DataBodyRange(i, "E") = "oui"
                .DataBodyRange(i, "F") = "non"
                .DataBodyRange(i, "G") = "oui"
                .DataBodyRange(i, "H") = "non"
                With TS_orion
                .DataBodyRange(i, "C") = "0" & Me.vlanlan
                .DataBodyRange(i, "D") = "0" & Me.vlanlan
                .DataBodyRange(i, "E") = "0" & Me.vlanlan
                .DataBodyRange(i, "F") = Me.descriplan
                .DataBodyRange(i, "G") = Me.commfinal3
                .DataBodyRange(i, "H") = "oui"
                .DataBodyRange(i, "I") = "oui"
                .DataBodyRange(i, "J") = "non"
                .DataBodyRange(i, "K") = "non"
                With TS_lb
                .DataBodyRange(i, "A") = Me.vrflan & Me.vpninst
                .DataBodyRange(i, "C") = Me.vrflan & Me.vpninst
                .DataBodyRange(i, "D") = Me.descriplan
                .DataBodyRange(i, "E") = Me.vlanlan
                .DataBodyRange(i, "K") = ""
                .DataBodyRange(i, "M") = ""
                If MultiPage1.Value + 1 < MultiPage1.Pages.Count Then MultiPage1.Value = MultiPage1.Value + 1
                Call Tri_macro
 'si lantype est différent de LBH alors j'applique le code suivant
            With TS_lan
            Dim Ligne_Inser
            With TS_spine
            .DataBodyRange(i, "L") = "undo shutdown"
            With TS_L2
            .DataBodyRange(i, "C") = Me.commfinal3
            With TS_orion
              Call Tri_macro
A 1ère vue, remplace les 2 End If par End With juste devant les lignes "Call Tri_macro"
Sans filets...
Salut Camarade!
Il semblerait que ce soit bien cela puisque cela fonctionne!
Gracias
Bonjour, Par contre si tu ne fais rien quand c'est vide alors sortir de la macro non ?
Dim i As Long
Exit sub
@Xmenpl milles excuses pour ma réponse tardive. Je viens seulement de la voir! Effectivement cela est une idée. Débutant, j'avoue ne pas maitrisé encore assez toutes les subtilités. Merci pour cette remarque pertinente
Rechercher des sujets similaires à "vba end bloc"
