Erreur de compilation
c
Me voilà bloqué sur un code <avec "ERREUR DE COMPLILATION FONCTION OU VARIABLE ATTENDU"
Je vous joins ici le code. Pourriez-vous m'aider sur ce code.
Sub Simule2() 'Scores Concours
Dim i As Byte, NbrEq As Byte, NbQ As Byte, Nbr As Byte, J As Byte, Cel As Range, Plg
Dim Tablo() As Integer, RDest As Range, Temp As Integer, Existe As Boolean
NbrEq = Range("Total_équipes")
Call ImageSansFormule '####
If NbrEq > 29 Then NbQ = 3
If NbrEq < 30 Then NbQ = 2
If NbrEq <> 8 And NbrEq <> 16 And WorksheetFunction.CountA(Range("Score_Qualif")) / NbQ <> NbrEq Then
MsgBox ("Les qualifications ne sont pas terminées pour la suite")
Exit Sub
Range("Scores").ClearContents
Range("a40:c56").Locked = False
If NbrEq <> 8 And NbrEq <> 16 Then Range("Qualif!n6:n21").Copy Destination:=Range("c40")
If NbrEq = 8 Or NbrEq = 16 Then Range("Qualif!m6:m21").Copy Destination:=Range("c40")
If NbrEq < 16 Then Nbr = 8
If NbrEq > 15 Then Nbr = 16
If NbrEq = 8 Or NbrEq = 16 Then Nbr = NbrEq
ReDim Tablo(Nbr)
Set RDest = Cells(40, 2)
Randomize
For i = 1 To Nbr
Existe = True
While Existe
Temp = Int(Nbr * Rnd + 1)
For J = 1 To Nbr
If Temp = Tablo(J) Then
Existe = True
Exit For
Existe = False
Next J
Wend
Tablo(i) = Temp
For i = 1 To Nbr
RDest(i).Value = Tablo(i)
Range("b40:c56").Sort Key1:=Range("B40"), Order1:=xlAscending, _
Header:=xlNo, OrderCustom:=1, MatchCase:=False
On Error Resume Next
If Nbr > 8 Then
For Each Cel In Range("c40:c56")
Plg = Application.WorksheetFunction.Match(Cel, Range("h5:h35"), 0) + 4
If Range("g" & Plg) = "" Then
Range("g" & Plg) = Int((12 * Rnd) + 1)
Cel.Clear.contents :
Next Cel
i = Range("c35").End(xlDown).Row
For i = i To 56
Range("a40") = Range("c" & i)
Plg = [MATCH(a40,k6:k34,0)] + 5
If Range("j" & Plg) = "" Then
Range("j" & Plg) = Int((12 * Rnd) + 1)
Range("c" & i).Clear.contents
For i = i To 56
Plg = [MATCH(a40,n8:n32,0)] + 7
If Range("m" & Plg) = "" Then
Range("m" & Plg) = Int((12 * Rnd) + 1)
Range("a40") = WorksheetFunction.Max(Range("q12"), Range("q28"))
Range("p" & [MATCH(a40,q12:q28,0)] + 11) = Int((12 * Rnd) + 1)
On Error GoTo 0
Range("a25").Copy Destination:=Range("a40:c56")
Range("a40:c56").Locked = True
Call ImageFormule '####
End SubLe Bug est repéré à la ligne Cel.Clear.contents.
Amicalement
Noel
d
duboisPassionné d'Excel
- Messages
- 9'245
- Excel
- Vista Office 2007FR
- Inscrit
- 08/12/2007
- Emploi
- retraité Sce.Méthodes
Cette instruction n'existe pas !
Clear.contentsétonnant que çà ne bogue pas chez moi, çà s'écrit en un seul mot
Cel.ClearContentsClaude
c
Bonjour Claude,
Dans ton précédent message tu disais je cite :
"Cette instruction n'existe pas !" Clear.contents
Je suis tout à fait d'accord avec toi mais bien sure étant donné que ce code est dans le projet Pétanque, c'est que je n'ai pas osé le modifier mais surtout j'ai pas regardé le code . J'ai rectifié et ça fonctionne très bien.
Je te remercie beaucoup.
Amicalement
Noel
