Mac adress
Après voir fait des recherches sur le forum rine
Je voudrai savoir si quelqu'un pourrait me donner la solution en VBA pour que mon projet puisse récupérer la MAC ADRESS de mon ordinateur.
merci d'avance
Amicalement
Noel
j'ai trouvé ce code à cette
place ce code dans un module
Public Const NCBASTAT As Long = &H33
Public Const NCBNAMSZ As Long = 16
Public Const NCBRESET As Long = &H32
Public Type NET_CONTROL_BLOCK
ncb_command As Byte
ncb_retcode As Byte
ncb_lsn As Byte
ncb_num As Byte
ncb_buffer As Long
ncb_length As Integer
ncb_callname As String * NCBNAMSZ
ncb_name As String * NCBNAMSZ
ncb_rto As Byte
ncb_sto As Byte
ncb_post As Long
ncb_lana_num As Byte
ncb_cmd_cplt As Byte
ncb_reserve(9) As Byte
ncb_event As Long
End Type
Public Type ADAPTER_STATUS
adapter_address(5) As Byte
rev_major As Byte
reserved0 As Byte
adapter_type As Byte
rev_minor As Byte
duration As Integer
frmr_recv As Integer
frmr_xmit As Integer
iframe_recv_err As Integer
xmit_aborts As Integer
xmit_success As Long
recv_success As Long
iframe_xmit_err As Integer
recv_buff_unavail As Integer
t1_timeouts As Integer
ti_timeouts As Integer
Reserved1 As Long
free_ncbs As Integer
max_cfg_ncbs As Integer
max_ncbs As Integer
xmit_buf_unavail As Integer
max_dgram_size As Integer
pending_sess As Integer
max_cfg_sess As Integer
max_sess As Integer
max_sess_pkt_size As Integer
name_count As Integer
End Type
Public Type NAME_BUFFER
name_num As Integer
name_flags As Integer
End Type
Public Type ASTAT
adapt As ADAPTER_STATUS
NameBuff(30) As NAME_BUFFER
End Type
Public Declare Function Netbios Lib "netapi32.dll" (pncb As NET_CONTROL_BLOCK) As Byte
Public Function MACAddress() As String
Dim macAdr As String
Dim ncb As NET_CONTROL_BLOCK
Dim adapter As ASTAT
ncb.ncb_command = NCBRESET
Call Netbios(ncb)
ncb.ncb_command = NCBASTAT
ncb.ncb_lana_num = 0
ncb.ncb_callname = "* "
ncb.ncb_buffer = VarPtr(adapter)
ncb.ncb_length = Len(adapter)
Call Netbios(ncb) 'renvoie entre autre la mac adresse dans une structure
For i = 0 To 5
macAdr = macAdr & Format$(Hex(adapter.adapt.adapter_address(i)), "00") & " "
macAdr = Trim(macAdr) 'Enlève les espces à droite et à gauche de la chaîne
MACAddress = macAdr
End Functionensuite appelle la fonction MACAddress pour avoir ton adresse
msgbox MACAddressBonjour à tous
Autre possibilité avec WMI (testé sur PC: peut-^tre non valable sur MAC)
adresses mac lan et sis
Sub trouver_adresses_mac()
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colAdapters = objWMIService.ExecQuery _
("SELECT * FROM Win32_NetworkAdapterConfiguration WHERE IPEnabled = True")
n = 1
For Each objAdapter In colAdapters
MsgBox "adaptateur réseau n°" & n & vbLf _
& "Description: " & objAdapter.Description & vbLf _
& "Adresse physique MAC: " & objAdapter.MACAddress
n = n + 1
End SubBonjour,
Je vous remercie tous d'avoir répondu à ce fil. Il se fait tard pour pouvoir l'esayer dès demain je m'y attellerai et je vous tiendrai au courant de la situation.
Bonne nuit à tous
amicalement
Noel
-- Mer Sep 01, 2010 6:08 am --
Bonjour Michel et Math
Mon cher Math ton code bug qui soit sous MAC ou PC. Je pense qu'il n'y a pas grand chose il se plante à la fonction :
Public Function MACAddress() As String à la ligne Call Netbios(ncb)Mon cher Michel comme tu l'avais prévu le tien marche bien sous PC.
Ce que je désire c'est de pouvoir récupérer Le MAC ADDRESS de l'ordinateur dans une cellule et puis trouver un code VBA qui puisse comparer lors du lancement du projet si le MAC Address de l'ordinateur correspond à celui qui est enregistré dans une cellule.
J'espère vous relire bientôt
Je vous remercie
Amicalement
Noel
