Userform lent à charger
K
Bonjour chers tous
Mon userform est lent à s'afficher lorsqu'on le lance.
Il contient un listbox qui doit afficher une plage de données.
Je remarque que plus la plage est énorme le userform s'ouvre lentement.
Voici le code dans mon userform
Option Compare Text
Dim tbl
Dim ls, dl, xl As Integer, Loc, i As Long, sh As Worksheet, t, x, w As String, P, p1 As Range
Sheets("Base").Activate
Application.Calculation = xlCalculationManual
Me.startupposition = 0
Me.top = 0
Me.Left = Application.UsableWidth - Me.Width
If Sheets("Exp").Range("A5") <= 0 Then
TextBox5.Enabled = False
Label46.Caption = [TB!B8] & " _ " & UCase(Format([TB!B11], " mmmm yyyy"))
TextBox5.SetFocus
Enregistrer.Locked = True
Annuler_Saisie.Locked = True
Worksheets("Base").Unprotect "2580"
Dim dl As Long
dl = Sheets("Base").Range("A" & Rows.Count).End(xlUp).Row
With Sheets("Base")
.Range("A2:K" & .Range("A" & Rows.Count).End(xlUp).Row + 1).Font.Size = 12
entetes.Column = Application.Transpose(.[A1].Resize(1, 11).Value)
If .Range("A" & Rows.Count).End(xlUp).Row = 1 Then
tbl = .Range("A2:K" & .Range("A" & Rows.Count).End(xlUp).Row + 1).Value
ListBox2.List = tbl
tbl = .Range("A2:K" & .Range("A" & Rows.Count).End(xlUp).Row).Value
ListBox2.List = tbl
For i = 0 To ListBox2.ListCount - 1
ListBox2.List(i, 1) = Format(CDate(ListBox2.List(i, 1)), "mmm-yy")
With Worksheets("Base")
If .Columns("N:AQ").EntireColumn.Hidden = False Then .Columns("N:AQ").EntireColumn.Hidden = True
Dim col As Range
For Each col In .Columns("A:M")
col.AutoFit
If col.ColumnWidth < 12 Then col.ColumnWidth = 12
.Range("A2:A" & .Range("A" & Rows.Count).End(xlUp).Row + 1).NumberFormat = "@"
.Range("K2:K" & .Range("K" & Rows.Count).End(xlUp).Row).NumberFormat = "dd-mmm-yy"
TextBox5 = [TB!D7]
ComboBox10 = 1
ComboBox8 = "Oui"
ComboBox7 = "Non_Stable"
ComboBox6 = "Non"
ActiveSheet.Protect "2580"
Sheets("Ages").Unprotect "2580"
Application.Calculation = xlCalculationAutomatic
A
A quoi tous ces "Application.ScreenUpdating = False", un seul suffit en début de macro.(mais ce n'est pas ça qui joue sur le temps d'exécution).
Je pense que votre problème se situe ici
ListBox2.List = tbl
Ne vous est-il pas possible d'appliquer le format directement sur la plage "A2:K & dernière ligne"? ainsi la boucle qui suit devient inutile.
Cdlt
K
Merci!!!
je revois mon code
