Erreur d'execution '2147217871
c
bonjour j'ai une erreur d’exécution '2147217871' lorsque j’exécute une requête sql sur base sql server
jai lu quil fallait que j'utilise CoomandTmeout , mais je ne sais pas ou et comment la mettre
voici mon code
Public Rscon
Public sname
Sub CONNBDD()
Dim conn As ADODB.Connection
Dim rs As ADODB.Recordset
Dim sConnString As String
Dim fld As ADODB.Field
Dim Target As Range
' Create the connection string.
'sConnString = "Provider=SQLOLEDB; Data Source=.\SQLEXPRESS;Initial Catalog=ScadaNetDb;User ID=EXTERNE;Password=EXTERNEPCWIN2; Trusted_Connection=no"
sConnString = "Provider=SQLOLEDB;Server=DESKTOP-KBC80U4\SQLEXPRESS;Database=ScadaNetDb1;Trusted_Connection=yes;"
' Create the Connection and Recordset objects.
Set conn = New ADODB.Connection
Set rs = New ADODB.Recordset
' Open the connection and execute.
conn.Open sConnString
Set rs = conn.Execute(" " & Rscon & " ")
Sheets(sname).Cells.ClearContents
With Sheets(sname)
.Rows("2:65536").EntireRow.Delete
Set Target = Sheets(sname).Range("a1")
For Each fld In rs.Fields
Target.Value = fld.Name
Set Target = Target(1, 2)
' Check we have data.
If Not rs.EOF Then
' Transfer result.
Sheets(sname).Range("A2").CopyFromRecordset rs
' Close the recordset
rs.Close
' Else
'MsgBox "Error: No records returned.", vbCritical
' Clean up
If CBool(conn.State And adStateOpen) Then conn.Close
Set conn = Nothing
Set rs = Nothing
End Submerci pour votre aide
