The Object is not responding because the source application
Salut ,
je suis entrain d'essayer une application VBA qui s'en charge d'envoyer des courriels d'une maniere automatique a partir d'un user form , où il se trouyver un bouton parcourir pour choisir la template de la lettre . sauf que ca fait 2 journees que ce message d'erreur ne s'arrete pas de sortir
error message (The Object is not responding because the source application may be busy ) ou (Excel is Waiting for another Application to complete OLE Action.....). quand je fais OK j'aurais cette fenêtre :Automation error ,call was rejected by callee
voici un petit aperçu de mon code
Sub Emails_Screening_Manual_PV()
'Déclaration des variable
Dim wdDoc As Object
Dim wdFileName As Variant
Dim ws As Worksheet
Dim wb As Workbook
Dim WApp As Object
Dim OutApp As Outlook.Application
Dim OutMail As Outlook.MailItem
Dim VAR_Message As String
Dim VAR_Message_Eng As String
Dim VAR_Message_FR As String
Dim i As Integer
Dim Nbre_Line As Integer
Dim VAR_TO As String
Dim VAR_CC As String
Dim VAR_BCC As String
Dim VAR_Subject As String
Dim VAR_Beginning As String
Dim VAR_End As String
Dim ABody As String
Dim qualification_EN As String
Dim qualification_FR As String
Dim Exp As Byte
Dim bodymessage(0 To 19) As String
Dim fr(1 To 20) As String
Dim signature As String
Dim significant_FR As String
Dim Significant_EN As String
Dim Recent_EN As String
Dim Recent_FR As String
Dim qualification_cma As String
Dim qualification_cmf As String
Dim cma(1 To 20) As String
Dim cmf(1 To 20) As String
wdFileName = UserForm1.txtExcelDatasheet.Value
Set wb = ThisWorkbook
Set ws = wb.Sheets("Process Info")
Set WApp = CreateObject("Word.Application")
If wdFileName = False Then Exit Sub
Set wdDoc = WApp.Documents.Open(wdFileName)
With wdDoc
Nbre_Line = Sheets("SBR").Range("A456541").End(xlUp).Row
'Boucle pour tous les lignes du feuille numéro 2
For i = 8 To Nbre_Line
'Initialisation des variables
qualification_EN = ""
qualification_FR = ""
bodymessage(0) = ""
bodymessage(1) = ""
bodymessage(2) = ""
bodymessage(3) = ""
bodymessage(4) = ""
bodymessage(5) = ""
bodymessage(6) = ""
bodymessage(7) = ""
bodymessage(8) = ""
bodymessage(9) = ""
bodymessage(10) = ""
bodymessage(11) = ""
bodymessage(12) = ""
bodymessage(13) = ""
bodymessage(14) = ""
bodymessage(15) = ""
bodymessage(16) = ""
bodymessage(17) = ""
bodymessage(18) = ""
bodymessage(19) = ""
fr(1) = ""
fr(2) = ""
fr(3) = ""
fr(4) = ""
fr(5) = ""
fr(6) = ""
fr(7) = ""
fr(8) = ""
fr(9) = ""
fr(10) = ""
fr(11) = ""
fr(12) = ""
fr(13) = ""
fr(14) = ""
fr(15) = ""
fr(16) = ""
fr(17) = ""
fr(18) = ""
fr(19) = ""
fr(20) = ""
cma(1) = ""
cma(2) = ""
cma(3) = ""
cma(4) = ""
cma(5) = ""
cma(6) = ""
cma(7) = ""
cma(8) = ""
cma(9) = ""
cma(10) = ""
cmf(1) = ""
cmf(2) = ""
cmf(3) = ""
cmf(4) = ""
cmf(5) = ""
cmf(6) = ""
cmf(7) = ""
cmf(8) = ""
cmf(9) = ""
cmf(10) = ""
Significant_EN = ""
significant_FR = ""
Recent_EN = ""
Recent_FR = ""
Dim Flag_1etoile As Boolean
Dim Flag_2etoiles As Boolean
'Condition pour la qualification
If Sheets("SBR").Cells(i, 67) = "OUT" And Sheets("SBR").Cells(i, 68) = "OUT" And Sheets("SBR").Cells(i, 69) <> "OUT" And Sheets("SBR").Cells(i, 70) <> "OUT" And Sheets("SBR").Cells(i, 1) <> "" And Sheets("SBR").Cells(i, 3).Text Like "?*@?*.?*" Then
For Exp = 1 To 20
Select Case Exp
Case 1 To 20
'Condition pour les critéres du mérite
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EDU1" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B19").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E19").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EDU2" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B20").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E20").Text & "<br/>"
'Éxpériences
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP1" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B23").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E23").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP2" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B24").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E24").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP3" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B25").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E25").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP4" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B26").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E26").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP5" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B27").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E27").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP6" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B28").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP7" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B29").Text & "<br/>"
cmf(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E29").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP8" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B30").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E30").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP9" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B31").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E31").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP10" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B32").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E32").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP11" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B33").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E33").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP12" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B34").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E34").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP13" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B35").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E35").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP14" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B36").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E36").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP15" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B37").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E37").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP16" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B38").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E38").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP17" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B39").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E39").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP18" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B40").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E40").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP19" Then
cma(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B41").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E41").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "EXP20" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B42").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E42").Text & "<br/>"
' Competencies
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "Comp1" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B93").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E93").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "Comp2" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B94").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E94").Text & "<br/>"
'Abilities
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "A1" Then
cma(Exp) = cma(Exp - 1) & vbNewLine & " - " & Sheets("Process Info").Range("B69").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E69").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "A2" Then
cma(Exp) = cma(Exp - 1) & vbNewLine & " - " & Sheets("Process Info").Range("B70").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E70").Text & "<br/>"
'Personal Suitability
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "PS1" Then
cma(Exp) = cma(Exp - 1) & vbNewLine & " - " & Sheets("Process Info").Range("B81").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E81").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "PS2" Then
cma(Exp) = cma(Exp - 1) & vbNewLine & " - " & Sheets("Process Info").Range("B82").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E82").Text & "<br/>"
'Asset Education
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "AEDU1" Then
cma(Exp) = cma(Exp - 1) & vbNewLine & " - " & Sheets("Process Info").Range("B114").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E114").Text & "<br/>"
'Experience / Expérience
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "AEXP1" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B119").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E119").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "AEXP2" Then
cma(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B120").Text & "<br/>"
cmf(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E120").Text & "<br/>"
If Sheets("SBR").Cells(i, 16 + Exp).Value = "DNM" And Sheets("SBR").Cells(4, 16 + Exp) = "AEXP3" Then
cmf(Exp) = cma(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("B121").Text & "<br/>"
cma(Exp) = cmf(Exp) & vbNewLine & " - " & Sheets("Process Info").Range("E121").Text & "<br/>"
End Select
Next Exp
'Alimentation des variables qualification_EN & qualification_FR
qualification_EN = "<br/>" & "*** Stream 1 - Screening *** " & "<br/>" & bodymessage(0) & bodymessage(1) & bodymessage(2) & bodymessage(3) & bodymessage(4) & bodymessage(5) & bodymessage(6) & bodymessage(7) & bodymessage(8) & bodymessage(9) & "<br/>" & "*** Stream 2 - Screening *** " & "<br/>" & bodymessage(10) & bodymessage(11) & bodymessage(12) & bodymessage(13) & bodymessage(14) & bodymessage(15) & bodymessage(16) & bodymessage(17) & bodymessage(18) & bodymessage(19)
qualification_FR = "<br/>" & "*** Volet 1 - Présélection ***" & "<br/>" & fr(1) & fr(2) & fr(3) & fr(4) & fr(5) & fr(6) & fr(7) & fr(8) & fr(9) & fr(10) & "<br/>" & "*** Volet 2 - Présélection ***" & "<br/>" & fr(11) & fr(12) & fr(13) & fr(14) & fr(15) & fr(16) & fr(17) & fr(18) & fr(19) & fr(20)
qualification_cma = "<br/>" & "*** Common streams - Screening ***" & "<br/>" & cma(1) & cma(2) & cma(3) & cma(4) & cma(5) & cma(6) & cma(7) & cma(8) & cma(9) & cma(10)
qualification_cmf = "<br/>" & "*** Volets communs - Présélection ***" & "<br/>" & cmf(1) & cmf(2) & cmf(3) & cmf(4) & cmf(5) & cmf(6) & cmf(7) & cmf(8) & cmf(9) & cmf(10)
'Alimentation du variable VAR_Message_Eng (la partie anglais du message du corps d'email)
VAR_Message_Eng = "<b>" & wdDoc.Tables(1).Cell(1, 0).Range & "</b>" & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(2, 0).Range & "</b>" & Sheets("Process Info").Cells(4, 2) & ", " & Sheets("Process Info").Cells(8, 2) & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(3, 0).Range & "</b>" & Sheets("Process Info").Cells(4, 2) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(4, 0).Range & "</b>" & Sheets("Process Info").Cells(6, 2) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(5, 0).Range & "</b>" & Sheets("Process Info").Cells(7, 2) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(6, 0).Range & "</b>" & Sheets("Process Info").Cells(8, 2) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(7, 0).Range & "</b>" & Sheets("Process Info").Cells(9, 2) & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(8, 0).Range & "<br/>" _
& wdDoc.Tables(1).Cell(9, 0).Range & "<br/>" & "<br/>" _
& "<b>" & qualification_EN & qualification_cma & Significant_EN & Recent_EN & "</b>" & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(11, 0).Range & Sheets("Process Info").Cells(10, 2) & "<br/>" _
& wdDoc.Tables(1).Cell(12, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(13, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(14, 0).Range & Sheets("Process Info").Cells(11, 2) & "<br/>" _
& wdDoc.Tables(1).Cell(15, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(16, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(17, 0).Range & "<br/>" & "<br/>"
'Alimentation du variable VAR_Message_FR (la partie française du message du corps d'email)
VAR_Message_FR = "<b>" & wdDoc.Tables(1).Cell(18, 0).Range & "</b>" & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(19, 0).Range & "</b>" & Sheets("Process Info").Cells(4, 5) & ", " & Sheets("Process Info").Cells(8, 5) & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(20, 0).Range & "</b>" & Sheets("Process Info").Cells(4, 5) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(21, 0).Range & "</b>" & Sheets("Process Info").Cells(6, 5) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(22, 0).Range & "</b>" & Sheets("Process Info").Cells(7, 5) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(26, 0).Range & "</b>" & Sheets("Process Info").Cells(8, 5) & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(24, 0).Range & "</b>" & Sheets("Process Info").Cells(9, 5) & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(25, 0).Range & "<br/>" _
& wdDoc.Tables(1).Cell(26, 0).Range & "<br/>" & "<br/>" _
& "<b>" & qualification_FR & qualification_cmf & significant_FR & Recent_FR & "</b>" & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(28, 0).Range & Sheets("Process Info").Cells(10, 5) & "<br/>" _
& wdDoc.Tables(1).Cell(29, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(30, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(31, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(32, 0).Range & Sheets("Process Info").Cells(11, 5) & "<br/>" _
& wdDoc.Tables(1).Cell(33, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(34, 0).Range & "<br/>" & "<br/>" _
& wdDoc.Tables(1).Cell(35, 0).Range & "<br/>" & "<br/>"
'Alimentation du variable VAR_Message (pour le corps d'email)
VAR_Message = VAR_Message_Eng & VAR_Message_FR
Set OutApp = CreateObject("outlook.application")
Set OutMail = OutApp.CreateItem(olMailItem)
With OutMail
.display
signature = OutMail.HTMLBody
'Setting of Email
VAR_TO = Sheets("SBR").Cells(i, 3)
VAR_CC = Sheets("Process Info").Cells(13, 2)
VAR_BCC = Sheets("Process Info").Cells(14, 2)
VAR_Subject = Sheets("SBR").Range("Q1") & ", " & Sheets("Process Info").Cells(4, 2) & ", " & Sheets("Process Info").Cells(8, 2)
'VAR_Beginning = ""
'VAR_End = ""
ABody = VAR_Message
With OutMail
.To = VAR_TO
.CC = VAR_CC
.BCC = VAR_BCC
.Subject = VAR_Subject
.HTMLBody = ABody & signature
.display
.Save
'.Send
On Error GoTo 0
Set OutMail = Nothing
Set OutApp = Nothing
'Close the Word document with saving
wdDoc.Close False
Set wdDoc = Nothing
'wdFileName = Dir
End Suble probleme que si ca sort je dois créer un autre fichier word aussi c'est chiant. j'ai essayé le ficher sur une autre machine , ça fonctionne super bien
toutes vos suggestions seront les bienvenues
Je ne serai d'aucune aide mais si tu réfléchis un peu, comment veux-tu que les gens te disent où est l'erreur sans voir le fichier, le tester et dire où ça plante , simplement en lisant des dizaines de lignes de code ?
Quand il est conseillé d'envoyer un fichier, c'est pas pour rien
P.
Bonjour r4944
En vérifiant ton code, il y a apparemment des début et fin de boucles anormales
Essaye avec ce code corrigé
Dim wdDoc As Object
Dim ws As Worksheet
Dim wb As Workbook
Dim WApp As Object
Dim i As Integer, J As Integer
Dim ABody As String
Dim Exp As Byte
' Application.ScreenUpdating = False ' NE PAS METTRE pour VERIFICATION
For J = 0 To 19: bodymessage(J) = "": Next J
For J = 1 To 20: fr(J) = "": Next J
For J = 1 To 10: cma(J) = "": Next J
For J = 1 To 10: cmf(J) = "": Next J
Significant_EN = ""
significant_FR = ""
Recent_EN = ""
Recent_FR = ""
For Exp = 1 To 20
Select Case Exp
Case 1 To 20
'Éxpériences
' Competencies
'Abilities
'Asset Education
End Select
Next Exp
With OutMail
.display
'Setting of Email
'VAR_Beginning = ""
'VAR_End = ""
ABody = VAR_Message
With OutMail
.To = VAR_TO
.CC = VAR_CC
.BCC = VAR_BCC
.display
.Save
'.Send
'End If
wdDoc.Close False
Set wdDoc = Nothing
'wdFileName = Dir
End SubA+
Merci Bruno pour ton initiative , je viens de l'essayer il m'affiche une erreur ici '' wdDoc.Close False'' y'a til une façon de forcer la fermeture d'un document word ?
r4944 a écrit :Merci Bruno pour ton initiative , je viens de l'essayer il m'affiche une erreur ici '' wdDoc.Close False'' y'a til une façon de forcer la fermeture d'un document word ?
Sans fichier, difficile de tester
