Tester la valeur d'une cellule
je souhaiterais faire un check sur le contenu d'une cellule.
Je m'explique:
J'ai les cellule de D7 a D% ou je vais entrer une valeur commençant soit par B_% soit par NB_%
Je voudrais qu'il me jette si mes valeurs ne commence pas par une de ces 2 possibilités.
Voila le code que j'ai pour le moment, ou je voudrais ajouter cette fonctionnalité.
'Fills the field of static with a formatted name
Sub createStaticName()
Dim brickName As String
Dim staticName As String
Dim reg As New VBScript_RegExp_55.RegExp
Dim rw As Integer
'old reg.Pattern = "(B_)((L)INE|(V)IA)([0-9]{0,2})(_[A-Z]*[0-9]*)_([TX-Z][1-9]+)(-[0-9]+)\n*"
reg.Pattern = "(\$[A-Z0-9_]*?)(_(?:USL|LSL|TGT))(N?B)([A-Z0-9_]*?)-[0-9]+\n*"
rw = 7
While Cells(rw, 1).Value <> "" And Cells(rw, 4).Value <> ""
Cells(rw, 1).Value = Replace(Cells(rw, 1).Value, "DENSITY", "DENS")
Cells(rw, 1).Value = Replace(Cells(rw, 1).Value, "RANDOM", "RAND")
If Cells(rw, 6) = "" Then
brickName = Cells(rw, 4).Value
brickName = Replace(brickName, "PATTERNING", "PAT")
brickName = Replace(brickName, "DEFINITION", "DEF")
brickName = Replace(brickName, "RANDOM", "RAND")
brickName = Replace(brickName, "PARAMETRIC", "PAR")
brickName = Replace(brickName, "COLOR", "COL")
brickName = Replace(brickName, "FORMATION", "FORM")
brickName = Replace(brickName, "CLASSIF", "CLAS")
brickName = Replace(brickName, "FILLING", "FILL")
brickName = Replace(brickName, "UCAVITY", "UCAV")
brickName = Replace(brickName, "DRAMBEOL", "DRAMB")
brickName = Replace(brickName, "LINE", "LIN")
brickName = Replace(brickName, "WAF", "WF")
brickName = Replace(brickName, "NAILPROCESSING", "NAILPROC")
brickName = Replace(brickName, "ANNEAL", "ANN")
brickName = Replace(brickName, "CUPILLAR", "CUPIL")
brickName = Replace(brickName, "SPACERZERO", "SPACERZ")
brickName = Replace(brickName, "DEFECT", "DEFT")
brickName = Replace(brickName, "HIK", "HK")
brickName = Replace(brickName, "CTE2BEOL", "CTE2B")
brickName = Replace(brickName, "PASSIVATION", "PASSIV")
brickName = Replace(brickName, "FILTER", "FILT")
brickName = Replace(brickName, "REMOVAL", "REMOV")
brickName = Replace(brickName, "SPACERHVZERO", "SPACHVZ")
staticName = Cells(rw, 1).Value & brickName
staticName = reg.Replace(staticName, "$1$4$2")
If Right(staticName, 3) = "LSL" Then
Cells(rw, 2).Value = "Lower Spec Limit"
ElseIf Right(staticName, 3) = "USL" Then
Cells(rw, 2).Value = "Upper Spec Limit"
ElseIf Right(staticName, 3) = "TGT" Then
Cells(rw, 2).Value = "Target Limit"
Cells(rw, 2).Value = "???"
Cells(rw, 3).Value = "Plan"
Cells(rw, 5).Value = "String"
Cells(rw, 6).Value = staticName
Cells(rw, 7).Value = "Static"
Cells(rw, 8).Value = "T"
rw = rw + 1
Wend
Sub createParamName(ByRef Target As Range)
Dim paramName As String
Dim curCell As Range
Dim nblines As Integer
Dim i As Integer
Dim curRow As Integer
nblines = 0
For Each curCell In Selection
If curCell.Column = 1 And curCell.Row >= 7 Then
nblines = nblines + 1
curRow = Target.Row
For i = 1 To nblines
If Left(Cells(curRow, 1), 1) <> "$" Then
Rows(curRow).Select
Selection.Copy
Selection.Insert Shift:=xlDown
paramName = shortName(Cells(curRow, 1).Value, "-")
Cells(curRow, 1) = "$" & paramName & "_LSL"
Cells(curRow + 1, 1) = "$" & paramName & "_USL"
Cells(curRow, 1).Value = Replace(Cells(curRow, 1).Value, "$DF_", "$DE_")
Cells(curRow + 1, 1).Value = Replace(Cells(curRow + 1, 1).Value, "$DF_", "$DE_")
Cells(curRow, 1).Value = Replace(Cells(curRow, 1).Value, "RANDOM", "RAND")
Cells(curRow + 1, 1).Value = Replace(Cells(curRow + 1, 1).Value, "RANDOM", "RAND")
curRow = curRow + 2
curRow = curRow + 1
Function shortName(item As String, strTokenChar As String) As String
Dim pos As Integer
pos = InStr(1, item, strTokenChar)
If pos > 0 Then
shortName = Left(item, pos - 1)
shortName = item
End Function
Merci pour votre aide.
Bylbo.
Pourquoi ne pas "simplement" utiliser une Validation de données avec une formule du style:
=(GAUCHE($D7)="B")+(GAUCHE($D7;2)="NB")
j'ai ce message d'erreur
j'ai sélectionné ma colonne, je suis allé dans Data, data validation, j'ai choisi custom et mis la formule donnée.
Et la j'aile message d'erreur de dessus.
Re-bonjour,
Et tu as fait un copier-coller de la formule proposée ou tu l'as saisie (ou modifiée en fonction de tes besoins)? Parce que j'ai fait la même manip que celle que tu décris
Maintenant, si ton Excel est en version anglaise ... tu as pensé à traduire le nom de la fonction?
Je n'avais pas pensé a traduire la fonction en anglais.
Mais le problème ne vient pas de la, j'ai toujours le même message d'erreur.
Mais régional setting sont anglais et ce que ça peut changer quelque chose ?
Voila ce que je peux mettre comme formule:
sans le =
(LEFT($D7)="B")+(LEFT($D7;2)="NB")
avec une '
'=(LEFT($D7)="B")+(LEFT($D7;2)="NB")
Sauf que dans ces 2 cas j'ai une erreur quand je saisie des valeurs commençant par B% ou NB% :
sur un forum excel on met des fichiers excel, pas des photos.
Là on ne sait pas ce que tu as saisi comme formule, ni le contenu exact de la cellule.
eric
Les formules qui sont testés sont celles noté au dessus.
J'essaie de saisir en D7 la valeur NB_PORUE ou B_PORUE
Fichier excel joint.
20test.zip (9.97 Ko)
U.Mulité a oublié un paramètre dans le 1er Gauche() :
=(GAUCHE($D7;1)="B")+(GAUCHE($D7;2)="NB")
eric
Super Merci beaucoup
merci
Désolé, mais je n'ai pas eu le temps de repasser plus tôt. Merci à eriiic d'avoir pris le relais.
À moins qu'il n'existe une subtilité qui m'échappe, la fonction GAUCHE retourne le premier caractère à gauche d'une chaîne, si on ne précise pas le nombre de caractères à extraire. Sur ma machine, la formule proposée avait été testée et donnait le résultat attendu (enfin, il me semble )
J'ai retesté dans le fichier transmis par bylbo7. Dans la validation, il y avait une apostrophe devant la formule. En l'ôtant et en remplaçant LEFT par GAUCHE, il me semble toujours que le résultat est celui demandé.
Je sais que j'arrive un peu tard, mais j'ai joint ce fichier test. Sur la version anglaise, la fonction devrait se traduire automatiquement ... Si quelqu'un pouvait tester et confirmer/infirmer, j'apprécierais
Ah oui, je confirme. Et l'aide aussi :
no_car Facultatif. Indique le nombre de caractères à extraire à l’aide de la fonction GAUCHE.
L’argument no_car doit être supérieur ou égal à zéro.
Si l’argument no_car est supérieur à la longueur du texte, la fonction GAUCHE renvoie l’intégralité du texte.
Si vous ne spécifiez pas l’argument no_car, sa valeur par défaut est 1.
Pourtant j'avais testé et obtenu "". Je devais être dans un état second...
@ bylbo7 : c'est sans doute parce que tu n'avais pas remplacé les ; par une ,
Les séparateurs de liste sont différents selon la langue
Merci pour le retour, eriiic
Pour ce qui est de
je ne veux même pas savoir ce que tu avais fait pour t'y trouver
Promis, pour 2018 je change de dealer. C'est trop de la m... ce que me refile l'actuel
Rechercher des sujets similaires à "tester valeur"
