Test les conditions if
Bonjour le forum.
SVP le code suivant me permettra d'envoyer des sms.
Dim Recipient As Variant
    Dim Message As String
    Dim i As Integer
    Dim rowname, x As String
    Dim rownumber As String
    Dim rowdatenextpresta As String
    Dim rowdatelastcall As String
    Dim rownextpresta As Variant
    Dim datecall As String
    Dim datepresta As String
    Dim rowdatelastvisite As String
    Dim datelastsms As Date
    With Worksheets("CLIENTS")
        datelastsms = Cells(i, 46).Value
        If datelastsms + 10 < Now - Time Then
            Debug.Print
                Cells(i, 46).Value = Now
            Debug.Print
        If Weekday(Date, 2) = 2 And Now - Date > TimeSerial(9, 30, 0) Then
            x = "237"
          'For i = 35 To 5000
        For i = 35 To .Cells(Rows.count, 3).End(xlUp).Row
        rowdatelastvisite = Worksheets("CLIENTS").Cells(i, 7).Value
        rowdatenextpresta = Worksheets("CLIENTS").Cells(i, 13).Value
        rowdatelastcall = Worksheets("CLIENTS").Cells(i, 15).Value
        rownextpresta = Worksheets("CLIENTS").Cells(i, 14).Text
        datecall = Format(rowdatelastcall, "dd/mm/yyyy")
        datepresta = Format(rowdatenextpresta, "dd.mm.yyyy")
        datevisite = Format(rowdatelastvisite, "dd.mm.yyyy")
                    ''''''If (Day(.Cells(i, 13).Value + 10) < Day(Date) And Month(.Cells(i, 5).Value) = Month(Date)) Then
            If (((datepresta + 10) <= datevisite) And ((datecall + 10) <= (Now - Time))) Then
                ' anniversaire
                rownumber = .Cells(i, 4).Value
                If rownumber < 700000000 Then
                    'numéro valable
                    rowname = .Cells(i, 3).Value
                    Message = "Dear  " & rowname & ", It was desirable that you renew your " & rownextpresta & " no later than " & datepresta & ". It is with real pleasure that we invite you to call this number 699736671 so that we can schedule your appointment."
                    Recipient = x & CStr(rownumber)
                        ''''Message à envoyer
                    If MsgBox("Souhaitez-vous notifier Mr/Mme   rowname   par SMS pour l'inciter à, prendre un RDV ?" & Chr(13) & "Est-ce ok?", vbYesNo, "Envoi du SMS") = vbYes Then
                          GoTo 100
INFOS API..................................................................................................................
            'End If
100
CI-dessous mes difficultés
Je voudrais que dans la colonne AT de chaque ligne, soit stocké la date du dernier envoi des sms, pour de d'envoyer à nouveau le sms à la même personne dans une période.
Apres les recherches, j'ai produit ce code à cet effet, mail il ne marche pas.
            Debug.Print
            Debug.Print
En suite, je voudrais additionner 10 jours à dateviste et datepresta pour que cette condition soit ok.
Enfin je voudrais dans ce msgbox avoir le choix de notifier pas sms un client ou pas
Cdlt
Rechercher des sujets similaires à "test conditions"
