Simplifier code VBA
Bonsoir Je fais un code vba pour mon projet
je vois ce code peux moins simplifier et courte pour tout les autres lignes
ce code au desous est pour seulement 2 lignes, mais j'ai 13 lignes
merci d'avance
Private Sub TextBox1_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
Dim B1 As Integer
Dim C1 As Integer
If TextBox1.Value <> "" And TextBox13.Value <> "" And TextBox37.Value <> "" And TextBox121.Value <> "" And TextBox25.Value <> "" And TextBox49.Value <> "" Then
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
B1 = TextBox25.Value
C1 = TextBox49.Value
D = TextBox121.Value
TextBox61.Value = (A - B) + ((0.5 * D) - C)
TextBox73.Value = (A - B1) + ((0.5 * D) - C1)
Private Sub TextBox25_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox1.Value <> "" And TextBox25.Value <> "" And TextBox49.Value <> "" And TextBox121.Value <> "" Then
A = TextBox1.Value
Private Sub TextBox49_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
A = TextBox1.Value
Private Sub TextBox13_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
If TextBox1.Value <> "" And TextBox13.Value <> "" And TextBox37.Value <> "" And TextBox121.Value <> "" Then
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
Private Sub TextBox37_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
Private Sub TextBox2_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox14.Value <> "" And TextBox38.Value <> "" And TextBox121.Value <> "" And TextBox26.Value <> "" And TextBox50.Value <> "" Then
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
B1 = TextBox26.Value
C1 = TextBox50.Value
TextBox62.Value = (A - B) + ((0.5 * D) - C)
TextBox74.Value = (A - B1) + ((0.5 * D) - C1)
Private Sub TextBox26_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox26.Value <> "" And TextBox50.Value <> "" And TextBox121.Value <> "" Then
A = TextBox2.Value
Private Sub TextBox50_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
A = TextBox2.Value
Private Sub TextBox14_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox14.Value <> "" And TextBox38.Value <> "" And TextBox121.Value <> "" Then
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
Private Sub TextBox38_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
mark test 1
pour simplifier moi je mettrai une listbox de 7 colonnes x 13 lignes
eric
Merci eriic mais comment ?
voila mon travail comment avec ton aider de simplifier le tableau
merci d'avance
22p-b-vba-01.xlsm (29.12 Ko)
Rechercher des sujets similaires à "simplifier code vba"
