Simplifier code suppression
Bonjour tout le monde, je cherche une solution pour simplifier ce code de suppression de données.
Suppression des données de la feuille CAISSE colonne E à J
Suppression des données de la feuille JOURNAL colonne A à AP
53suppression.xlsm (0.97 Mo)
Private Sub CommandButton5_Click()
Dim rep As Integer
rep = MsgBox("Voulez-vous supprimer l'opération du " & TextBox1, vbQuestion + vbYesNo)
If rep = vbYes Then
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 5).Delete Shift:=xlUp
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 6).Delete Shift:=xlUp
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 7).Delete Shift:=xlUp
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 8).Delete Shift:=xlUp
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 9).Delete Shift:=xlUp
Sheets("CAISSE").Cells(ComboBox1.ListIndex + 4, 10).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 1).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 2).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 3).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 4).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 5).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 6).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 7).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 8).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 9).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 10).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 11).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 12).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 13).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 14).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 15).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 16).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 17).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 18).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 19).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 20).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 21).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 22).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 41).Delete Shift:=xlUp
Sheets("JOURNAL").Cells(ComboBox1.ListIndex + 3, 42).Delete Shift:=xlUp
Pour le principe.
A tester.
Dim rep As VbMsgBoxResult, n As Long
    If rep = vbYes Then
        n = Me.ComboBox1.ListIndex
        Set Ws = ActiveWorkbook.Worksheets("CAISSE")
        With Ws
            .Cells(n + 4, 5).Resize(, 6).Delete Shift:=xlUp
        Set Ws = ActiveWorkbook.Worksheets("JOURNAL")
        With Ws
            .Cells(n + 3, 1).Resize(, 15).Delete Shift:=xlUp
Bonjour, utilise ce type de code :
Sheets("Caisse").Columns("E:J").Delete Shift:=xlToLeft
Sheets("Journal").Columns("A:AP").Delete Shift:=xlToLeft
Au plus simple
EDIT
Dsl j'avais pas ouvert ton fichier. Du coup le code n'est pas adapté à la situation :/
Merci pour vos réponses, je restes celà après le travail, ce soir
je te retourne ton fichier Excel :
36suppression.xlsm (127.32 Ko)
sur la feuille "CAISSE", fais Ctrl e
Alt F11 pour voir le code VBA, puis revenir sur Excel
j'ai fait plein d'modifs, alors regarde partout !
si besoin, tu peux demander une adaptation.
merci de me dire si ça te convient.
dhany
Merci, je regarde ce soir
Merci dhany et Jean-Eric , vos 2 solutions fonctionnent parfaitement
Bon weekend
Citaro
merci pour ton retour ! pour passer le sujet en résolu, clique sur à droite de (coin haut droit du post) ➯
ça permet aussi de clôturer le fil de la discussion (toi seul peut le faire, car c'est toi qui a créé ce sujet).
bon weekend à toi aussi.
dhany
Rechercher des sujets similaires à "simplifier code suppression"
