Simplification de macro
j'ai la macro suivante, qui est très répétitive:
Sub LD2()
Dim TF As Variant
Dim L As String
Dim PL1 As Range
Dim PL2 As Range
Dim PL3 As Range
Dim PL4 As Range
Dim CEL As Range
TF = Array("min", "h", "s")
L = "h, min, s"
Set PL1 = Sheets("Tr").Range("Y1:Y" & Range("Y" & Rows.Count).End(xlUp).Row) 'Déclaration de la plage PL1
For Each CEL In PL1
     For i = 0 To UBound(TF)
    If InStr(1, CEL.Value, TF(i), vbTextCompare) <> 0 Then
        With CEL.Validation
            .Delete
            .Add Type:=xlValidateList, Formula1:=L
Next CEL
Set PL2 = Sheets("Tm").Range("Y1:Y" & Range("Y" & Rows.Count).End(xlUp).Row)
For Each CEL In PL2
        With CEL.Validation
            .Delete
Next CEL
Set PL3 = Sheets("Mes").Range("Y1:Y" & Range("Y" & Rows.Count).End(xlUp).Row)
For Each CEL In PL3
        With CEL.Validation
            .Delete
Next CEL
Set PL4 = Sheets("Regul").Range("Y1:Y" & Range("Y" & Rows.Count).End(xlUp).Row)
For Each CEL In PL4
        With CEL.Validation
            .Delete
Next CEL
J'aimerais en faire une macro plus "générique", et moins lourde.
Merci d'avance,
FGR
à tester,
Sub LD2()
Dim TF As Variant
Dim L As String
Dim PL As Range
Dim CEL As Range
Dim i As Integer, y As Integer
sh = Array("Tr", "Tm", "Mes", "Regul")
L = "h, min, s"
For y = 0 To 3
 Set PL = Sheets(sh(i)).Range("Y1:Y" & Range("Y" & Rows.Count).End(xlUp).Row) 'Déclaration de la plage PL1
  For Each CEL In PL
        With CEL.Validation
            .Delete
  Next CEL
Next y
Rechercher des sujets similaires à "simplification macro"
