Selectionne date du jour
Bonjour, dans ma macro je voudrais qu'a la fin il me selectionne la date de jour que se trouve dans la ligne c
merci
Sub Workbook_Open()
Application.EnableEvents = False 'désactive les évènements
Workbooks.Open Filename:= _
        "\\atlas.edf.fr\CO\45dam-dpn\restreint.007\ps.004\Pap_pcp\LISTES\Planning_EP.xlsm"
   Windows("Planning equipe 3x8 2019.xlsm").Activate
     Range("C13:NR13").Select
    Selection.ClearContents
    With Selection.Interior
        .Pattern = xlNone
        .TintAndShade = 0
        .PatternTintAndShade = 0
    ActiveWindow.ScrollColumn = 365
    ActiveWindow.ScrollColumn = 350
    ActiveWindow.ScrollColumn = 317
    ActiveWindow.ScrollColumn = 287
    ActiveWindow.ScrollColumn = 270
    ActiveWindow.ScrollColumn = 268
    ActiveWindow.ScrollColumn = 267
    ActiveWindow.ScrollColumn = 266
    ActiveWindow.ScrollColumn = 261
    ActiveWindow.ScrollColumn = 239
    ActiveWindow.ScrollColumn = 231
    ActiveWindow.ScrollColumn = 228
    ActiveWindow.ScrollColumn = 208
    ActiveWindow.ScrollColumn = 194
    ActiveWindow.ScrollColumn = 171
    ActiveWindow.ScrollColumn = 150
    ActiveWindow.ScrollColumn = 135
    ActiveWindow.ScrollColumn = 134
    ActiveWindow.ScrollColumn = 121
    ActiveWindow.ScrollColumn = 103
    ActiveWindow.ScrollColumn = 88
    ActiveWindow.ScrollColumn = 84
    ActiveWindow.ScrollColumn = 74
    ActiveWindow.ScrollColumn = 47
    ActiveWindow.ScrollColumn = 6
    Selection.Copy
    Range("C23").Select
    ActiveSheet.Paste
    Range("C33").Select
    ActiveSheet.Paste
    ActiveWindow.SmallScroll Down:=21
    Range("C43").Select
    ActiveSheet.Paste
    ActiveWindow.SmallScroll Down:=15
    Range("C53").Select
    ActiveSheet.Paste
    Range("C63").Select
    ActiveSheet.Paste
   Application.Run "'Planning equipe 3x8 2019.xlsm'!ep2019_33100"
   Application.Run "'Planning equipe 3x8 2019.xlsm'!ferme_ep"
Application.EnableEvents = True 'désactive les évènements
Me.Activate
UserForm1.Show
Bonsoir chris45,
Tu a écrit :
je voudrais qu'à la fin il me sélectionne la date du jour qui se trouve dans la ligne c
dans quelle ligne ? les lignes sont des numéros, c'est les colonnes qui sont des lettres !
alors dans quelle ligne de la colonne C ?
dhany
de la ligne c3:ag3
c'est déjà mieux ! mais sans ton fichier, c'est pas facile !
à supposer que la date du jour que tu veux sélectionner est par exemple en E3,
alors pour sélectionner cette cellule E3, voici au choix 4 instructions :
Range("E3").Select
[E3].Select
Cells(3, "E").Select
Cells(3, 5).Select
pour ces 4 instructions, ça revient au même résultat : la cellule
sera sélectionnée... si la feuille est active (sinon, plantage !)
dhany
Non je veux qu’il me mettre sur la case ou y a la date
Tu a écrit :
Non je veux qu’il me mette sur la case où y'a la date
* au singulier, donc une cellule ; et t'avais indiqué dans ton post précédent cette plage : c3:ag3
* alors en ligne 3 : ok ; mais quelle colonne ? y'a l'choix, de C à AG ! comment tu la choisis ?
dhany
je voudrais lorsque j'ouvre le fichier que la vue se mette à la date du jour soit aujourdhui en G0
ci joint les photos
capture capture2
staple1600 m'a ecrit ca mais ca marche pas
Sub FindDate_Light_Bis()
Dim r As Range
On Error Resume Next
Set r = ActiveSheet.Rows(3).Find(Date): r.Select
On Error GoTo 0
If r Is Nothing Then MsgBox "Pas de date du jour dans cette colonne!", vbCritical, "Erreur"
pourtant les date sont bien sur la ligne3 de c3:ag3
merci
Bonjour chris45,
merci de joindre ton fichier (sans données confidentielles) plutôt que des images ou juste du code VBA. pour cela, utilise le bouton « Ajouter des fichiers » qui est situé juste sous la fenêtre d'édition de ton post.
pour faire ta demande, il faudrait aussi l'année ; or on ne la voit pas sur tes images jointes ➯ si elle est dans ton classeur, je l'utiliserai ; sinon, j'utiliserai à la place l'année de la fonction AUJOURDHUI().
dhany
bonjour, voila macro5 mais je voudrais que cela ce fasse a l'ouverture et pas une marco detaché
21planning-equipe.xlsm (211.72 Ko)
dur de trouver la date du jour sur un calendrier 2019
Maurice
putain je suis con c'est vrai
ca marche sur un planning 2018
merci
voila une macro pour 2018 HI
Sub Test()
  Set Cel = Rows(3).Cells.Find(DateValue(Now), LookAt:=xlWhole)
    If Cel Is Nothing Then
        MsgBox "Date non trouv?e ????"
        Application.Goto Cells(2, Cel.Column), True
Maurice
Rechercher des sujets similaires à "selectionne date jour"
