Remplir listview2
j'ai besoin de remplir listview2 en USFFORM multipage "base des livres" mais je n'arrive pas
merci de votre aide
35vba-filtered.xlsm (61.21 Ko)
j'essaie mais c tres complique
Unload Me
'UserForm2.Show
Unload Me
Private Sub MultiPage1_Change()
Private Sub TextBox1_Change()
    Call LVW_Fill(Trim$(TextBox1.Text), ComboBox1.ListIndex)
Private Sub TextBox2_Change()
    Call LVW_Fill(Trim$(TextBox2.Text), ComboBox2.ListIndex)
Private Sub UserForm_Activate()
    Me.Caption = "Bibliotheque"
             Set ListView1.Icons = ImageList1
             Set ListView1.SmallIcons = ImageList1
             Set ListView2.Icons = ImageList2
             Set ListView2.SmallIcons = ImageList2
    Call CBO_Fill
    Call LVW_Fill("", 0)
Private Sub CBO_Fill()
    'Variables locales
    Dim iCnt As Integer
    Dim oRng As Excel.Range
    'Remplit la Combo
    With ComboBox1
    Set oRng = Sheets("Recherche").Cells(1, 1)
    For iCnt = 0 To 13 '-- 14 colonnes
        ComboBox1.AddItem oRng.Offset(0, iCnt)
    Next iCnt
    ComboBox1.ListIndex = 0
    With ComboBox2
    Set oRng = Sheets("base des livres").Cells(1, 1)
    For iCnt = 0 To 12 '-- 13 colonnes
    Next iCnt
Private Sub LVW_Fill(ByVal sFilter As String, ByVal iCol As Integer)
    'Variables locales
    Dim iCnt As Integer
    Dim iRnd As Integer
    Dim oItem As ListItem
    'Initialisation de la ListView
    With ListView1
    ListView1.ColumnHeaders.Clear
    ListView1.FullRowSelect = True
    ListView1.ListItems.Clear
    ListView1.View = lvwReport
    'Remplissage de la ListView
    Do Until oRng.Offset(0, 0).Value = ""
        '-- En-têtes
        If oRng.Row = 1 Then
                ListView1.ColumnHeaders.Add , , oRng.Offset(0, iCnt)
            Next iCnt
        '-- Données
            iRnd = Int((4 * Rnd) + 1)
            If LCase$(Left$(oRng.Offset(0, iCol), Len(sFilter))) = LCase$(sFilter) Then
                Set oItem = ListView1.ListItems.Add(, , oRng.Offset(0, 0), "Key" & iRnd, "Key" & iRnd)
                For iCnt = 1 To 14 '-- 14 colonnes
                    oItem.ListSubItems.Add , , oRng.Offset(0, iCnt)
                Next iCnt
        Set oRng = oRng.Offset(1, 0)
    Loop
    With ListView2
    ListView2.ColumnHeaders.Clear
    ListView2.FullRowSelect = True
    ListView2.ListItems.Clear
    ListView2.View = lvwReport
        '-- En-têtes
                ListView2.ColumnHeaders.Add , , oRng.Offset(0, iCnt)
            Next iCnt
        '-- Données
                Set oItem = ListView2.ListItems.Add(, , oRng.Offset(0, 0), "Key" & iRnd, "Key" & iRnd)
                For iCnt = 1 To 13 '-- 13 colonnes
                Next iCnt
    Loop
amicalement
BONJOUR
je fais plusieurs tentatives mais sans résultat
comment débuter en A1 au lieu de A2
 Dim i As Integer
 Dim maLigne As Long
 Dim DernCol As Integer
 maLigne = Range("A" & Rows.Count).End(xlUp).Row + 1
DernCol = Range("A1").End(xlToRight).Column
'ajout les textbox a la feuille base des livres
With Worksheets("base des livres")
  For i = 1 To DernCol
    Cells(maLigne, i) = Me.Controls("TextBox" & i - 1)
merci de votre aide
34vba-filtered.xlsm (67.08 Ko)
Bonjour Richi2casa
Pour commencer ta liste en A1, tu dois supprimer la ligne des titres qui se trouvent en A1
Le code remonte vers la 1ère ligne non vide et décale de 1 vers le bas
Donc rencontre la ligne des titres et descend de 1 ligne soit A2
Amicalement
Pierrot
rien ne se passe
je ne comprend pas
merci de votre aide
BONJOUR
Au lieu de je commence à A1 je commence à B1
ou est mon erreur?
     Dim i As Integer
     Dim maLigne As Long
        Cells(maLigne, i) = Me.Controls("TextBox" & i )
merci de votre aide
rrr
je trouve une solution
mais reste recherche par filtre qlqu'un peux m'aider ?
 Dim i As Integer
 Dim maLigne As Long
 'Dim DernCol As Integer
  For i = 1 To 14
    Cells(maLigne, i) = Me.Controls("TextBox" & i + 1)
    Me.Controls("TextBox" & i + 1) = ""
Je suis presque terminé l'application
-mais je bloque au niveau du calcul ( stck,sortie entre .........)
merci pour tous
je change l'adresse (titre) simplifier le code
Rechercher des sujets similaires à "remplir listview2"
