Reference Same Cell From Multiple Worksheets With VBA Code & Paste it as a
The VBA code below: reference same cell from multiple worksheets.However, How can I modify the code reference to copy "50 worksheets", that has values in both "F2 & G2"and paste the same values into a new workbook as a list on "C2 & D2" downwards"
Here is the code to be modify:
Sub AutoFillSheetNames()
'Update 20131202
Dim ActRng As Range
Dim ActWsName As String
Dim ActAddress As String
Dim Ws As Worksheet
On Error Resume Next
xTitleId = "KutoolsforExcel"
Set ActRng = Application.ActiveCell
ActWsName = Application.ActiveSheet.Name
ActAddress = ActRng.Address(False, False)
xIndex = 0
For Each Ws In Application.Worksheets
If Ws.Name <> ActWsName Then
ActRng.Offset(xIndex, 0).Value = "='" & Ws.Name & "'!" & ActAddress
xIndex = xIndex + 1
essai en remplaçant
par
ActRng.Offset(xIndex, 0).Value = "=!" & ActAddress
Hello. I have replace the code. Nothing happen.
What do you want me to do?
J'ai rien compris mais essaie comme ca
'Update 20131202
Dim ActRng As Range
Dim Ws As Worksheet, nws As Worksheet
Dim LastRow As Long
ThisWorkbook.Sheets.Add(After:=.Sheets(.Sheets.Count)).Name = "NewWorkbook"
Set nws = Sheets("NewWorkbook")
nws.Range("C1").Value = "Values ..."
xIndex = 0
xIndex = xIndex + 1
If Application.WorksheetFunction.CountA(Ws.Range("F2:G2")) = 2 Then
LastRow = nws.Cells(nws.Rows.Count, "C").End(xlUp).Row + 1
Ws.Range("F2:G2").Copy nws.Range("C" & LastRow)
I am stuck. I don't know what to do.
I am not sure if you can help me.
My problem here is this.
I want to extract data from 50 worksheets that have it values in cells "F2 &G2" the name of the workbook is: "Countries Indicators #1 NSB (1)"
I want to paste and lockALL data, "F2 & G2" cells as a list into next workbook name: "Anton Heatwave" in "C2 & D2" respectively.
Please see files below
27anton-heatwave.xlsm (121.66 Ko)
à tester
Sub test()
Dim wbd As Workbook, wbs As Workbook
Dim sh As Worksheet
Dim RngRatedate As Range, RngRate As Range
Dim Lastrow As Long
Set wbd = Workbooks("Anton Heatwave.xlsm")
Set sh = wbd.Sheets("Heat Map ")
Set wbs = Workbooks("Countries Indicators #1 NSB (1).xlsm")
On Error GoTo 0
If wbs Is Nothing Then
    Set wbs = Workbooks.Open("C:\Users\Corey\Desktop\Anton Heatwave\PMI\Countries Indicators #1 NSB (1).xlsm")
wbd.Activate
Lastrow = sh.Cells(sh.Rows.Count, "A").End(xlUp).Row
For i = 2 To Lastrow
sh.Range("C" & i).Value = wbs.Sheets(Range("A" & i).Value).Range("F2").Value
sh.Range("D" & i).Value = wbs.Sheets(Range("A" & i).Value).Range("G2").Value
wbs.Close False
It's working. It's working. It's working.
Thank you, Thank you & Thank you very much
Greatly appreciate your patience and support
Thank you
Rechercher des sujets similaires à "reference same multiple worksheets vba code paste"
