Réduire code VBA
Rebonjour
comment je peux réduire mon code vba svp
j'arrive pas en effectuant une boucles
merci
Sub MONTANT_INDEMNITE_PRINCIPALE()
    Dim Date_Souscription_Adhésion As Range, Statut_Technique_Sinistre As Range
    Dim Montant_Ind_Principale As Range
    Dim dernligne As Long
    Dim i As Integer
    Dim sa As String
    Dim montant As String
    Dim tt1, tt2, tt3, tt4, tt5, tt6, tt7, tt8, tt9, tt10, tt11, tt12 As Double
    Dim t1, t2, t3, t4, t5, t6, t7, t8, t9, t10, t11, t12 As Double
    'Dim tt13, tt14, tt15, tt16, tt17, tt18, tt19, tt20, tt21, tt22, tt23, tt24 As Double
    Dim tt25, tt26, tt27, tt28, tt29, tt30, tt31, tt32, tt33, tt34, tt35, tt36 As Double
    Dim s As Double
    Dim Mois As Integer
    With Worksheets("Feuil1")
        dernligne = .Range("A" & Rows.Count).End(xlUp).Row
        Set Date_Souscription_Adhésion = .Range("B2:B" & dernligne)
        Set Montant_Ind_Principale = .Range("E2:E" & dernligne)
        Set Statut_Technique_Sinistre = .Range("D2:D" & dernligne)
    i = 2
   For i = 2 To dernligne
        sa = Cells(i, 4)
        montant = Cells(i, 5)
        Mois = Month(Cells(i, 2))
        If sa <> "Terminé - Refusé après instruction" Then
            If Year(Cells(i, 2).Value) = 2015 Then
                Select Case Mois
                    Case Is = 1
                        tt1 = tt1 + CInt(montant)
                    Case Is = 2
                        tt2 = tt2 + CInt(montant)
                    Case Is = 3
                        tt3 = tt3 + CInt(montant)
                    Case Is = 4
                        tt4 = tt4 + CInt(montant)
                    Case Is = 5
                        tt5 = tt5 + CInt(montant)
                    Case Is = 6
                        tt6 = tt6 + CInt(montant)
                    Case Is = 7
                        tt7 = tt7 + CInt(montant)
                    Case Is = 8
                        tt8 = tt8 + CInt(montant)
                    Case Is = 9
                        tt9 = tt9 + CInt(montant)
                    Case Is = 10
                        tt10 = tt10 + CInt(montant)
                    Case Is = 11
                        tt11 = tt11 + CInt(montant)
                    Case Is = 12
                        tt12 = tt12 + CInt(montant)
                End Select
            If Year(Cells(i, 2).Value) = 2016 Then
                Select Case Mois
                    Case Is = 1
                        t1 = t1 + CInt(montant)
                    Case Is = 2
                        t2 = t2 + CInt(montant)
                    Case Is = 3
                        t3 = t3 + CInt(montant)
                    Case Is = 4
                        t4 = t4 + CInt(montant)
                    Case Is = 5
                        t5 = t5 + CInt(montant)
                    Case Is = 6
                        t6 = t6 + CInt(montant)
                    Case Is = 7
                        t7 = t7 + CInt(montant)
                    Case Is = 8
                        t8 = t8 + CInt(montant)
                    Case Is = 9
                        t9 = t9 + CInt(montant)
                    Case Is = 10
                        t10 = t10 + CInt(montant)
                    Case Is = 11
                        t11 = t11 + CInt(montant)
                    Case Is = 12
                        t12 = t12 + CInt(montant)
                End Select
            If Year(Cells(i, 2).Value) = 2017 Then
                Select Case Mois
                    Case Is = 25
                        tt25 = tt25 + CInt(montant)
                    Case Is = 26
                        tt26 = tt26 + CInt(montant)
                    Case Is = 27
                        tt27 = tt27 + CInt(montant)
                    Case Is = 28
                        tt28 = tt28 + CInt(montant)
                    Case Is = 29
                        tt29 = tt29 + CInt(montant)
                    Case Is = 30
                        tt30 = tt30 + CInt(montant)
                    Case Is = 31
                        tt31 = tt31 + CInt(montant)
                    Case Is = 32
                        tt32 = tt32 + CInt(montant)
                    Case Is = 33
                        tt33 = tt33 + CInt(montant)
                    Case Is = 34
                        tt34 = tt34 + CInt(montant)
                    Case Is = 35
                        tt35 = tt35 + CInt(montant)
                    Case Is = 36
                        tt36 = tt36 + CInt(montant)
                End Select
        Sheets("Feuil2").Cells(1, 2).Value = "janvier 2015"
        Sheets("Feuil2").Cells(1, 3).Value = tt1
        Sheets("Feuil2").Cells(2, 2).Value = "fevrier 2015"
        Sheets("Feuil2").Cells(2, 3).Value = tt2
        Sheets("Feuil2").Cells(3, 2).Value = "mars 2015"
        Sheets("Feuil2").Cells(3, 3).Value = tt3
        Sheets("Feuil2").Cells(4, 2).Value = "avril 2015"
        Sheets("Feuil2").Cells(4, 3).Value = tt4
        Sheets("Feuil2").Cells(5, 2).Value = "mai 2015"
        Sheets("Feuil2").Cells(5, 3).Value = tt5
        Sheets("Feuil2").Cells(6, 2).Value = "juin 2015"
        Sheets("Feuil2").Cells(6, 3).Value = tt6
        Sheets("Feuil2").Cells(7, 2).Value = "juil 2015"
        Sheets("Feuil2").Cells(7, 3).Value = tt7
        Sheets("Feuil2").Cells(8, 2).Value = "aout 2015"
        Sheets("Feuil2").Cells(8, 3).Value = tt8
        Sheets("Feuil2").Cells(9, 2).Value = "sept 2015"
        Sheets("Feuil2").Cells(9, 3).Value = tt9
        Sheets("Feuil2").Cells(10, 2).Value = "oct 2015"
        Sheets("Feuil2").Cells(10, 3).Value = tt10
        Sheets("Feuil2").Cells(11, 2).Value = "nov 2015"
        Sheets("Feuil2").Cells(11, 3).Value = tt11
        Sheets("Feuil2").Cells(12, 2).Value = "dec 2015"
        Sheets("Feuil2").Cells(12, 3).Value = tt12
        Sheets("Feuil2").Cells(13, 2).Value = "janvier 2016"
        Sheets("Feuil2").Cells(13, 3).Value = t1
        Sheets("Feuil2").Cells(14, 2).Value = "fevrier 2016"
        Sheets("Feuil2").Cells(14, 3).Value = t2
        Sheets("Feuil2").Cells(15, 2).Value = "mars 2016"
        Sheets("Feuil2").Cells(15, 3).Value = t3
        Sheets("Feuil2").Cells(16, 2).Value = "avril 2016"
        Sheets("Feuil2").Cells(16, 3).Value = t4
        Sheets("Feuil2").Cells(17, 2).Value = "mai 2016"
        Sheets("Feuil2").Cells(17, 3).Value = t5
        Sheets("Feuil2").Cells(18, 2).Value = "juin 2016"
        Sheets("Feuil2").Cells(18, 3).Value = t6
        Sheets("Feuil2").Cells(19, 2).Value = "juil 2016"
        Sheets("Feuil2").Cells(19, 3).Value = t7
        Sheets("Feuil2").Cells(20, 2).Value = "aout 2016"
        Sheets("Feuil2").Cells(20, 3).Value = t8
        Sheets("Feuil2").Cells(21, 2).Value = "sept 2016"
        Sheets("Feuil2").Cells(21, 3).Value = t9
        Sheets("Feuil2").Cells(22, 2).Value = "oct 2016"
        Sheets("Feuil2").Cells(22, 3).Value = t10
        Sheets("Feuil2").Cells(23, 2).Value = "nov 2016"
        Sheets("Feuil2").Cells(23, 3).Value = t11
        Sheets("Feuil2").Cells(24, 2).Value = "dec 2016"
        Sheets("Feuil2").Cells(24, 3).Value = t12
        'refaire la mm chose pour 2017
bonjour,
à tester
    Dim i As Integer
    Dim sa As String
    Dim tt(2015 To 2017, 1 To 12) As Double
    tmois = Split("janvier,février,mars,avril,mai,juin,juillet,août,septembre,octobre,novembre,décembre", ",")
            sa = .Cells(i, 4)
            montant = .Cells(i, 5)
            annee = Year(.Cells(i, 2).Value)
            Mois = Month(.Cells(i, 2))
                tt(annee, Mois) = tt(annee, Mois) + CDbl(montant)
        For annee = 2015 To 2017
            For Mois = 1 To 12
                j = j + 1
                Sheets("Feuil2").Cells(j, 2).Value = tmois(Mois - 1) & " " & annee
                Sheets("Feuil2").Cells(j, 3).Value = tt(annee, Mois)
            Next Mois
        Next annee
sa marche merciiii
juste une petite question c quoi CDbl ste plais
aude21 a écrit :
sa marche merciiii
cdbl() est un fonction de conversion vers un type double
info ici
https://support.office.com/fr-fr/article/Fonctions-de-conversion-de-types-de-donn%C3%A9es-8ebb0e94-2d43-4975-bb13-87ac8d1a2202
super mercii bcppp
pourquoi quand je l'applique a mon fichier sa ne veut pas marcher
    Dim i As Integer
    Dim sa As String
    With Worksheets("Sinistre_Historique")
        dernligne = .Range("A" & .Rows.Count).End(xlUp).Row
        Set Date_Souscription_Adhésion = .Range("G2:G" & dernligne)
        Set Montant_Ind_Principale = .Range("AB2:AB" & dernligne)
        Set Statut_Technique_Sinistre = .Range("V2:V" & dernligne)
        sa = .Cells(i, 22)
        montant = .Cells(i, 28)
        annee = Year(.Cells(i, 7).Value)
        Mois = Month(.Cells(i, 7))
        For Mois = 1 To 12
            j = j + 1
            Sheets("Feuil4").Cells(j, 6).Value = tt(annee, Mois)
        Next Mois
    Next annee
il ya une erreur au niveaux de
re-bonjour,
sanston fichier, difficile à dire
vérifie si toutes les données dans la colonne montant sont bien des nombres.
vérifie que l'année de chaque date est bien dans comprise de 2015 à 2017.
oui j'ai vérifier y a bien tout ça
je t'ai mis un fichier qui ressemble au mieux
17aideee.xlsx (9.76 Ko)
bonjour,
pas de problème chez moi avec ton fichier sur ma version excel UK.
sans doute un problème dû à la différence entre , et . pour le version UK et FR
essaie ceci
    Dim i As Integer
    Dim sa As String
        sa = .Cells(i, 22)
        montant = Replace(.Cells(i, 28), ".", ",")
        For Mois = 1 To 12
            j = j + 1
        Next Mois
    Next annee
sa marche merciii
Rechercher des sujets similaires à "reduire code vba"
